Power meter usage, every ride?
Postby Strawburger » Mon Nov 05, 2012 9:24 am
Hi All,
Hopefully a quick question. Do you track every ride you do with a power meter or only power specific rides?
Why I ask is I vary my rides (commute, training, racing) so I'm wondering if I should log everything or just specific training and racing rides? Does not tracking commutes throw out CTL significantly?
SB
n=8 (2011 road, 2004 road, 2010 track, 2009 foldup, 1990 hybrid, 1992 indoor trainer, 2007 road now a rental, 1970's step through)
Strawburger
by Forum Ads » Mon Nov 05, 2012 9:40 am
Re: Power meter usage, every ride?
Postby ZepinAtor » Mon Nov 05, 2012 9:40 am
Coaches orders !!! EVERY ride !!!
As far as I know your T.S.B (training stress balance), C.T.L (chronic training load--long term) & A.T.L (active training load--short term) are all effected to some degree by every ride you do.
If you don't track every ride the accuracy of your recovery periods would be thrown out as would everything else for that matter.
A good example would be if you had a tough TT session planned for the evening (say 5 x 10 min flat out) & you did a 50km commute on the same day your results could look quite poor or down on the norm.
If your 50km commute was taken into account your daily session would most probably be changed to 50km endurance & 2 x 10 min TT that evening.
Depends how serious you are about the whole thing really ?
ZepinAtor
Postby twizzle » Mon Nov 05, 2012 9:44 am
Log everything.
I ride, therefore I am.
twizzle
Postby Alex Simmons/RST » Mon Nov 05, 2012 9:53 am
Strawburger wrote:Hi All,
SB
Commuting is part of CTL.
Alex Simmons/RST
Postby Strawburger » Mon Nov 05, 2012 10:08 am
Great! That confirms what I had thought. Thank you all for your help.
For people logging every ride, what solutions do they use for multiple bikes (ie road, tt & track)? Do they invest in multiple pm's? Eg. crank based for road/tt (easy swap) and hub based for track?
Thanks again
Strawburger
Postby Nobody » Mon Nov 05, 2012 10:36 am
Just wait until they are cheap enough to put on every bike. By then, it might not matter anymore and you've saved a lot of money. Just a thought. OK I'll get out off this thread now and let you get back to spending.
Nobody
Postby twizzle » Mon Nov 05, 2012 12:08 pm
Strawburger wrote:Great! That confirms what I had thought. Thank you all for your help.
Thanks again
I have two PowerTaps one built into an open-pro (yuck!), one build into a Deep-V (heavy). jcjordan has a Power2Max crank, it takes him about ten minutes to swap it between bikes. Given that PT's aren't cheap any more (no base "Comp" model any more), a crank based might make more sense... but you still end up with a seperate "track" setup, and there's always the temptation to have spare setups to ensure you don't have any down time. I'm not sure about this "left crank only" power meter which is coming out shortly, most people favour one leg, and the %'age of difference probably changes between endurance / sprint / climbing. Rotor is bringing out 'dual' crank arms soon, looks nicely thought out.
twizzle
Postby ZepinAtor » Mon Nov 05, 2012 2:55 pm
Strawburger wrote:
For people logging every ride, what solutions do they use for multiple bikes ?........ Do they invest in multiple pm's?
Unfortunately yes.
Otherwise you can play the swap the PT wheel from bike to bike game.
I was really looking forward to the release of the pedal based (Vector) system which is on hold indefinitely.
Although when looking at the Vector system it looked like the individual batteries/transmitters on each crank arm needed quite a bit of frame clearance + there wasn't any mention of an MTB style pedal. Which come to think of it would be interesting when crunching the occasional rock or log.
ZepinAtor
Postby Alex Simmons/RST » Mon Nov 05, 2012 4:51 pm
You can of course simply estimate TSS for non-power meter rides - much depends on what you are using the data for, and what proportion of the data will be estimated versus actual.
Alex Simmons/RST
Postby ZepinAtor » Mon Nov 05, 2012 5:16 pm
Has anybody had any experience with the ibike Newton ?
I have no idea about this devise, but I have a friend who's interested.
ZepinAtor
Postby twizzle » Mon Nov 05, 2012 8:39 pm
ZepinAtor wrote:Has anybody had any experience with the ibike Newton ?
Still shite.
Sent from my iThingy...
twizzle
Postby Ross » Tue Nov 06, 2012 6:45 pm
The Polar Look Keo pedals are available but are around $1700 and aren't ANT+ compatible
Ross
Postby jcjordan » Tue Nov 06, 2012 8:31 pm
And based on every review I have seen so far is less reliable then their older system.
Sent from my HTC Sensation Z710a using Tapatalk 2
James
jcjordan
Postby Strawburger » Thu Nov 08, 2012 8:16 pm
Thanks again for all your info. Looks like a costly exercise if I'm to put pm's on the road/tt and track bike if going for new equipment (slightly better for 2nd hand). Don't see many 2nd hand powertaps around for the track.
Polar is out (I'm decked out in ant+), haven't heard good things about the stageone, ibike is also not flash so may have to get a crank pm now (srm/quark/p2m) and wait for the vector sometime in the next 10 years :lol:
Strawburger
Postby toolonglegs » Thu Nov 08, 2012 8:26 pm
I am still thinking of getting another power meter. But racing in cyclocross, TT, MTB and road there is no way I will be putting a meter on every bike. I think once you have spent a bit of time training to a power meter then you know what feels right for an effort anyway. If I do get a powertap then it will only be used for testing... just a confirmation that everything is going to plan.
Although Strava has a habit of telling me if I am on plan as well. My 5 second power is genetic... all the rest 1,5,20 and hour power I can easily test on a climb or a loop and compare to when I know I was riding strong.
But then I seem to ride better on feel than looking at numbers.
Postby nickobec » Thu Nov 08, 2012 10:17 pm
Yes track everything, particularly my commute aka training rides. Those done with out a power meter ie my singlespeed and six speed I estimate my TSS, usually based on HR, perceived exertion, time and weather conditions on a known route with lots of existing data.
Have Elite+ Powertap laced to mavic open pro rim as my training wheelset, ended up rebuilding it after 5 broken spokes, complete wheelset (front & rear) weights over 3kg.
So got a G3 PT and laced that to 50mm lightweight chinese carbon rim, depending if I use 60mm or 38mm matching front wheelset is close to 900m lighter for my racing wheelset. Having some issues with transmitting data, if the new firmware does not fix my powercap (not the whole wheel or hub) is off to Wisconsin.
2nd hand power meters from the UK (this is where I bought my Elite+ wheel from) : http://www.cyclepowermeters.com/used-ex-rental-powermeters-141-c.asp
And if you are after G3 PT hub, little over $1k from the US
nickobec
Postby twizzle » Fri Nov 09, 2012 8:22 am
nickobec wrote:So got a G3 PT...
*sigh*
I'm jealous.
twizzle
Postby toolonglegs » Fri Nov 09, 2012 8:24 am
*sigh*
I'm jealous.
Why?... you make 360 w ish at ftp :P .
Postby twizzle » Fri Nov 09, 2012 10:49 am
toolonglegs wrote:
*sigh*
I'm jealous.
My "comp" models are getting a little old. Pawls sticking in the freehubs, replacement freehubs only seem to come in alloy, not steel. The wiring harness is a bit fragile, the wires fatigue and die. The docking station suffers from the pins sticking... A G3 in 28 spoke with a carbon rim and a Garmin 800 are high on my wish list. Right after "lose another 9Kg".
93.4Kg - weight has plateaued again. :(
twizzle
Postby snedden9485 » Sun Dec 30, 2012 8:59 pm
Power2max. $1100 AU and swaps between bikes in 3 min. Easy.
Chris
2011 Giant TCR Advanced SL
2011 Malvern Star Oppy TT9 Time Trial
2011 Giant Omnium Track
2012 Giant XTC Composite 29
snedden9485
Postby toolonglegs » Sun Dec 30, 2012 10:08 pm
twizzle wrote:
toolonglegs wrote:
twizzle wrote:[quote="nickobec"]So got a G3 PT...
*sigh*
I'm jealous.
93.4Kg - weight has plateaued again. :([/quote]
Cyclepowermeters.com have or are going to do ti freewheel bodies.
Postby mikesbytes » Sun Dec 30, 2012 11:01 pm
Has anyone investigated the power meters that work within pedals? I too are wondering about the swap between bikes situation.
I do see you can get a crank set that can be used with one track ring or 2 road rings (AT) BCD144, which limits your small ring to ? 42
I've got stuff on ebay
mikesbytes
Postby orbeas » Mon Dec 31, 2012 2:02 am
:idea: :) im suprised their isnt an Iphone app for that or is their
Orbea Euskaltel:Ultegra,Durace,RS80
Orbea Erandio Hybrid
orbeas
Postby clackers » Mon Dec 31, 2012 3:01 am
orbeas wrote::idea: :) im suprised their isnt an Iphone app for that or is their
That makes up "power" numbers without the necessary sensors, Orbeas? I'm sure there is! :smile:
clackers
Postby toolonglegs » Mon Dec 31, 2012 3:06 am
It's called Strava ;-)
Return to Training
