How do I warmup?
Walsh95
How do I warmup?
Postby Walsh95 » Thu Jun 06, 2013 3:30 am
Ok, so I've been riding for a while and am making some good progress, but I constantly forget to warmup, meaning I'll go out and kill myself for half and hour, come home and collapse, feeling nauseous. This usually happens after hill training, (8 repeats of 1km at 7%), and I never get it from flat road riding, it's a pain because I should be feeling good about the way I'm riding, but all I'm feeling is lactic, lactic, lactic.
So how do I fix it?
MREJ
Re: How do I warmup?
Postby MREJ » Thu Jun 06, 2013 6:50 am
Er, warm up maybe? It can take me 20 minutes before I've shaken the stiffness out and am no longer feeling the legs complaining. I just do it by treating the first part of the ride as the warm-up, with mostly moderate pace but some hard efforts. Same before races - I like to get at least 15 minutes warm-up.
You could also get some yoga or stretching routines, or some rollers. For me, I'd rather be on the road.
2016 S-Works Tarmac, 2014 Wabi Lightning SE, 2012 Felt F75, 2011 Genesis Equilibrium 20, ancient Avanti Pista track bike
Walsh95
Postby Walsh95 » Thu Jun 06, 2013 1:34 pm
Ok, cool, but what sorts of intensities r we talking, heart rates wise?
nescius
Postby nescius » Thu Jun 06, 2013 4:22 pm
I usually do about 15 or 20 minutes warmup before starting my session proper, and like to do closer to 30 minutes before a race. Generally I start off really easy, small chainring 100rpm to get the legs to wake up, heart rate for this would be recovery so very easy. After a few minutes of that (whenever my legs feel ok) I'll start pushing a bigger gear and get my HR into E1, still spinning around 95-100rpm, do this for about 5 minutes. Then introduce a few efforts, moderate to start with, maybe 30 seconds at E2 sort of intensity, building up to some short E3 sprint type efforts, back to E1 in between efforts (make sure it's E1 not recovery). Just play around and see what works for you, by the end of the warm up you should feel warm (a light sweat) but not tired.
It will also make you feel better afterwards if you do a decent cool down ride, basically spin the legs for 15 minutes after you finish your session (E1 down to RE heart rate, small chainring for most of it probably)
Heart Rate Zones
Scott Spark 900 RC | Rocky Mountain Instinct BC Edition | Trek Madone 4.5 | Look 695 SR ipack
cyclotaur
Postby cyclotaur » Thu Jun 06, 2013 5:26 pm
It always takes me at least 20 mins or so to warm up. Cycling's essentially a low impact/low intensity exercise in the first instance. I wouldn't attempt 7% hill repeats straight out the front door. :shock: I try to avoid any hills until I'm good and warmed up in any case.
Throw away the gadgets and stats and just go ride for 30 mins or so before you do anything serious in the way of intensity/repeats or climbing. If you don't have an hour to spare you're probably doing more harm than good, physically and mentally.... in my opinion..... doing such intense stuff from the get-go.
"Riding not racing...."
Leiothrix
Postby Leiothrix » Sun Jun 09, 2013 5:32 pm
I think gadgets are great. if i don't warm up i get a heart rate of 230+ (which is obviously not good). After 10 minutes of being gentle though no problems.
FWIW I'm a reasonably fit person, it's just that my body has to get used to the idea of moving before peddling hard.
clackers
Postby clackers » Mon Jun 10, 2013 7:21 am
Leiothrix wrote:I think gadgets are great. if i don't warm up i get a heart rate of 230+ (which is obviously not good). After 10 minutes of being gentle though no problems.
You're a tachycardia sufferer, Leiothrix?
Leiothrix
Postby Leiothrix » Mon Jun 10, 2013 3:04 pm
No, everything is normally fine (well, AFAIK anyway). I just need a warmup first. Resting HR is around 70 FWIW.
kb
Postby kb » Mon Jun 10, 2013 5:19 pm
Have you tried measuring that by taking your pulse? I've had readings like that at the start of a ride that were just from conduction problems with the monitor. Once there's a bit of light sweat it settled.
Leiothrix
Postby Leiothrix » Mon Jun 10, 2013 5:44 pm
I normally lick the pad (well, lick my finger and wipe the pad) on the strap before I put it on.
I use the same strap for jogging and that doesn't give any problems with that.
Below shows a graph generated by Endomondo & my Garmin Edge 500 from my last ride. Around Lake Illawarra for anyone who knows that area.
kb
Postby kb » Mon Jun 10, 2013 6:15 pm
Hmm.. doesn't look much like a spike. That's impressive!
Edit: although starting at 0bpm is a bit odd.
vander
Postby vander » Mon Jun 10, 2013 6:46 pm
Definitely a spike, you get it while riding because of the speed which is very different to running you see you are doing 40+ right at the start.
boss
Postby boss » Mon Jun 10, 2013 8:28 pm
Your heart rate isn't actually beating at 230bpm... This is a known issue with the Garmin strap when cycling...
winstonw
Postby winstonw » Mon Jun 10, 2013 8:49 pm
That 230+ is definitely a technical issue. I'd suggest you pair your gamin to another HR strap, and see if you get normal readings.
i.e.
http://hillfarmhouse.wordpress.com/2012 ... -readings/
Leiothrix
Postby Leiothrix » Tue Jun 11, 2013 8:39 pm
I'm not really sure it's a technical issue as far as spiking goes, mostly because the graph is pretty smooth and follows the amount of effort I put in.
Just after I get on the bike there is a downhill section, and being keen to move I pedal to go fast (because it's fun!). If I remember to take it easy at the start there isn't the big spike at the beginning.
I use the same strap with a forerunner 310XT for running and get the same average readings, but I always walk for around a km before starting to run so I'm properly warmed up.
I haven't actually confirmed the reading by counting when exercising, but sitting here just now it's reading ~70 which my counting agrees with.
boss
Postby boss » Tue Jun 11, 2013 10:20 pm
boss wrote:Your heart rate isn't actually beating at 230bpm... This is a known issue with the Garmin strap when cycling...
kb
Postby kb » Tue Jun 11, 2013 10:27 pm
Leiothrix wrote:I'm not really sure it's a technical issue as far as spiking goes, mostly because the graph is pretty smooth and follows the amount of effort I put in.
I haven't used Endomondo but I'd say it's probably smooth because it's been smoothed. Maybe see what it looks like under Garmin Connect, Strava or using a tool like fitdump.
Bah77
Postby Bah77 » Tue Jun 11, 2013 10:39 pm
I get the same thing with my garmin now its getting colder, basically in summer i sweat enough that i get good contact straight away, in winter i have to wet the pads.
Was a bit Say What though when it first happened, but seeing as i wasn't breathing hard it was pretty obviously the garmin and not me.
g-boaf
Postby g-boaf » Sat Jun 15, 2013 6:50 pm
I ended up doing away with the Garmin HR strap. I got a Powercal - it's not a good power monitor but it is a really good HR monitor - I get none of the troubles I had with the Garmin strap.
230bpm is a known Garmin anomaly.
