embarrassing power figures
- jules21
Postby jules21 » Fri Sep 26, 2014 10:24 am
i only just bought a power meter (Vector pedals) so had no idea what i was pushing out previously. i've actually had a couple of vaguely-decent race results this year, with a top-ten at Mt Baw Baw road race (Masters C grade) and a couple of similar results.
is my power meter under-reading or do i just need to pull my finger out?
i'm told that it should get a bit higher by doing it on the road, instead of the sauna-inducing ergo test i did..
Re: embarrassing power figures
Postby dalai47 » Fri Sep 26, 2014 10:43 am
- jules21
Postby jules21 » Fri Sep 26, 2014 11:05 am
- g-boaf
Postby g-boaf » Fri Sep 26, 2014 11:06 am
How did you prepare for it? Adequate hydration, eating enough, plenty of sleep the night before?
Adequate cooling helps too. If I'm doing trainer sessions, I need a fan blasting away directly at me or I overheat and feel terrible (and don't do well).
If the preparation was good, then you'll just need to do more work. Generally from what I've seen, it involves:
- 5x5 intervals at 55-65rpm (88-92% FTP) with 3min easy spinning (30-50% of FTP) in between them
- 3x10min intervals 55-65rpm (88-92% FTP) with 4min easy spinning (30-50% FTP) at low power in between them
- 5x5 intervals at 110% FTP - 100-120rpm with with 3min easy spinning (30-50% of FTP) in between them
- 3x10min intervals at 110% FTP - 100-120rpm with with 3min easy spinning (30-50% of FTP) in between them
What I've suggested above is basically what I was doing with good results until I got injured. Now I'm trying to pick it back up. I didn't prepare the above, it was suggested by someone else who is vastly better at this stuff than I am. But it's all pretty common stuff.
A few dips at the early stages, was it fatigue a bit and then picked it back up again? You obviously did rev it up at the end pretty well. Some days it just doesn't work at all and you feel like crap.jules21 wrote:i can probably do better.. i didn't load up enough at the start..
- jules21
Postby jules21 » Fri Sep 26, 2014 11:14 am
but you can see the average is too low at the start. i can get that up a bit, but i'm a long way below what would be a good FTP
thanks for the tips G. i've actually just got a coach who is a club-mate. i'll be working on getting these up
- g-boaf
Postby g-boaf » Fri Sep 26, 2014 11:25 am
Ah, okay - that explains it. The ones I'm experienced with are computrainers. You have to recalibrate them after they've warmed up, but after it you essentially just find a nice RPM and gear combo and then hopefully don't die. All that said, the FTP is just a number - but it's nice to have a good FTP figure, and it's frustrating when it isn't as high as you want. At the end of the day we are all competitive animals - so I understand what you are thinking. And indeed, these tests on stationary trainers are just miserable torture tests.jules21 wrote:those short dips are gear changes. the fluid trainer i'm using increases the resistance as it warms up, forcing me to down-shift.
- jules21
Postby jules21 » Fri Sep 26, 2014 11:41 am
- g-boaf
Postby g-boaf » Fri Sep 26, 2014 11:46 am
I'm not one either - so we are in the same boat. It's damn hard work to bump up the power by 20w.jules21 wrote:i'm not a sprinter. i don't really enjoy being that guy who hides all day and then jumps out at the end. i tend do better in races of attrition, so having a good FTP seems necessary.
Postby Cul » Fri Sep 26, 2014 1:50 pm
In addition, go find a hill to do your FTP testing on if you want a real world result to use in day to day riding / racing! If you are like me you will find your results will vary by quite a significant margin, my 20min result on a local climb is 28w higher than I can manage for 20min on the trainer. Alex Simmons has written quite extensively about the effects of training on the wind/fluid/turbo trainer in the past... http://alex-cycle.blogspot.com.au/2009/ ... ining.html
Mate that is a real sufferfest, I bet doing those once or twice a week "pulls" the FTP up in a real hurry!!!3x10min intervals at 110% FTP - 100-120rpm with with 3min easy spinning (30-50% of FTP) in between them
- jules21
Postby jules21 » Fri Sep 26, 2014 2:16 pm
Postby r2160 » Fri Sep 26, 2014 2:16 pm
You shouldnt either.
Glenn
"Pain is temporary. It may last a minute, or an hour, or a day, or a year, but eventually it will subside and something else will take its place. If I quit, however, it lasts forever" Lance Armstrong
Postby dalai47 » Fri Sep 26, 2014 2:20 pm
As a Masters cyclist, my preference is to push rather than pull so I can recover quicker for the next session...Cul wrote:Mate that is a real sufferfest, I bet doing those once or twice a week "pulls" the FTP up in a real hurry!!!
I wouldn't necessarily use a hill for FTP effort unless you will be doing all your FTP efforts on climbs. My FTP is 20-30 Watts higher climbing, so will use the climbing FTP on hill repeats and for flat intervals use my flat lander FTP.
- jules21
Postby jules21 » Fri Sep 26, 2014 2:22 pm
damn it, you're right Glenn! i'm comfortable in my own FTP. if people don't find it attractive, that's their problemr2160 wrote:Why is it embarrassing. It is the power you put out. That is pretty much my FTP. I am not ashamed of it. Why should I be.
- g-boaf
Postby g-boaf » Fri Sep 26, 2014 2:25 pm
It hurts enough. Probably easy for someone else I suppose. It's pretty demoralising seeing someone else smash 350w for 19min and then blast at 450w for the final minute of a 20minute effort. Can only be happy that my w/kg was similar.Cul wrote:Mate that is a real sufferfest, I bet doing those once or twice a week "pulls" the FTP up in a real hurry!!!3x10min intervals at 110% FTP - 100-120rpm with with 3min easy spinning (30-50% of FTP) in between them
- toolonglegs
Postby toolonglegs » Fri Sep 26, 2014 3:10 pm
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri Sep 26, 2014 6:37 pm
Postby Hugor » Fri Sep 26, 2014 8:34 pm
My FTP had been making fairly steady improvements to a respectable value then it seemed to drop by close to 20% in a week.
Everytime I looked down at my garmin I was depressed by my output compared to my perceived effort.
Despite training very hard for a months holiday in Europe was leaving at a real trough in my fitness.
My current power curve had the identical shape as my best but it was 20% lower.
In my case in turned out to be a garmin firmware upgrade.
The bike settings page on your garmin has a crank length menu which only becomes visible when your vectors are detected.
The default setting is 145mm and the head unit setting overrides whatever length you specified in your vector firmware.
It was using this in its power calculation rather than the 175mm which I specified in my vector setup.
As the power calculation is directly proportional to crank length it follows that it was underestimating my output by almost 20%.
My FTP improved overnight!! Unfortunately it was only after my european holiday that I made this realisation.
- trailgumby
Postby trailgumby » Fri Sep 26, 2014 9:30 pm
Now I know where to start with my efforts.
Postby Roub » Fri Sep 26, 2014 11:29 pm
Postby piledhigher » Fri Sep 26, 2014 11:54 pm
- toolonglegs
Postby toolonglegs » Sat Sep 27, 2014 1:17 am
What is embarrassing is knowing what your FTP was 3 or so years ago and knowing where it is now ... while also piling on the kilos ... I have gone from 4 wpkg to under 3.5 ... still think I have 4.25 hidden away somewhere but that would take a lot of work!.
Postby macca33 » Sat Sep 27, 2014 7:30 am
Postby march83 » Sat Sep 27, 2014 8:53 am
- trailgumby
Postby trailgumby » Sat Sep 27, 2014 9:09 am
But in a race you would go 5% harder, so it kind of balances out.Roub wrote:FTP calc should be 0.95 x 20min effort power too
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Sep 27, 2014 3:27 pm
It's unusual to be that high relative to 20-min power. That assumes the 20-min power was maximal, which is this case may not be the case for a few reasons.Roub wrote:FTP calc should be 0.95 x 20min effort power too
