Weight training for cyclists
Re: Weight training for cyclists
Postby vander » Tue Feb 17, 2015 9:08 pm
Postby zill » Tue Feb 17, 2015 10:10 pm
You said your FTP has increased by 30W. Even though it's meant to be an hour, I presume you test yourself over 20 min?Xplora wrote:
Absolute power for what time?
Postby zill » Tue Feb 17, 2015 10:12 pm
I definitely seem to be more of a volume guy.vander wrote:
Getting a little off topic here; but Zill I know of riders that do 500km every week and are no faster than some blokes that ride only 200 per week – there is no answer to “is that enough riding” because it will vary person to person, and on a number of circumstances. What I can tell you from personal experience though is you will struggle to get in a “good” 500kms a week, gym sessions, work full time and still recover adequately! You WILL be compromising your training sessions and run the risk of some pretty bad burnout if not careful.
Postby Overspeed » Tue Feb 17, 2015 10:53 pm
They develop more explosive power and squat a tonne every day, so better longevity on the body vs rip's powerlifting
- Xplora
Postby Xplora » Tue Feb 17, 2015 11:55 pm
- g-boaf
Postby g-boaf » Wed Feb 18, 2015 10:40 am
Is it supposed to be over an hour though? I know of a lot of places that simulate it as 20 minutes over 2% gradient. If it was a full hour, then forget it - I wouldn't even bother. 20 minutes is long enough to be able to measure a number and check how you are going. Even a MAP test is reasonable enough too - a lot shorter as well.zill wrote:You said your FTP has increased by 30W. Even though it's meant to be an hour, I presume you test yourself over 20 min?Xplora wrote:
X's idea on hill repeats is reasonable enough - reasonably quick workout and does the job.
I've done a 330TSS on a ride. It was hard, but not too bad. About 170km. Sure I was tired after it, but not completely ruined. On the topic of the CTL - not increasing too much, that's meaning that it shouldn't increase too quickly or? I know some things about that, but I'm not an expert with that stuff.vander wrote:X they often train too hard and rarely train hard enough is more to the point. CTL allows you to make sure you are not increasing too much which is helpful. A 400TSS day is massive I would expect about 8 hours on the bike for that!
- Xplora
Postby Xplora » Wed Feb 18, 2015 11:06 am
My TSS busts the model regularly because I can launch a lot of Z6-Z7 efforts over a couple hours, which distorts your TSS enormously. Part of living in the "Hills District" I guess
CTL is a great way of monitoring your baseline fitness level change. If you increase by 5 per week without drama, you might end up injured and sick doing 7-8 a week. You'll end up in a massive hole doing 300TSS rides every day, but we can see from the record attempt that 300km rides every day is very sustainable once you have adapted to it.
- kb
Postby kb » Wed Feb 18, 2015 3:53 pm
Postby dalai47 » Wed Feb 18, 2015 4:48 pm
http://alex-cycle.blogspot.com.au/2008/ ... -sins.htmlg-boaf wrote: Is it supposed to be over an hour though? I know of a lot of places that simulate it as 20 minutes over 2% gradient. If it was a full hour, then forget it - I wouldn't even bother. 20 minutes is long enough to be able to measure a number and check how you are going. Even a MAP test is reasonable enough too - a lot shorter as well.
Common suggestion is FTP = 95% of the 20 minute average power from the test. Some questions of what the exact percentage is, but for me this is pretty accurate. I have done some 40km TT's and the figure matches nicely 95% of the last 20 minutes from 20km TT's.
- Xplora
Postby Xplora » Wed Feb 18, 2015 5:40 pm
Postby vander » Wed Feb 18, 2015 9:51 pm
Your wanting to stick with the loweer CP model is probably why you are getting massive 400TSS days.Xplora wrote:I'm pretty much convinced the FTP model doesn't cover me too well. I get much better results following the Golden Cheetah "estimated CP" curve. It tracks my FTP quite a bit lower than the Training Peaks NP/TSS modelling and direction. I pull a CP of around 270, and that's much easier for me to maintain - I spent a bunch of time at 330W NP in the race last night and I was RUINED during those laps
@G-boaf - thats where TSB comes in. I am happy to admit I am not an expert either but keeping it less that -20 most the time seems to be working well.
- g-boaf
Postby g-boaf » Wed Feb 18, 2015 10:55 pm
Postby vander » Wed Feb 18, 2015 11:05 pm
Postby CKinnard » Thu Feb 19, 2015 9:08 am
- Xplora
Postby Xplora » Thu Feb 19, 2015 10:00 am
Vander - I have been getting these 400TSS days with the FTP set higher than I tested, to try and suppress it. I use BikeScore instead of TSS to reduce the load as well.
I'm approaching the old weight training differently next season, will aim for more superset work next time around. These sessions are taking almost 2 hours, just can't afford the time.
- g-boaf
Postby g-boaf » Thu Feb 19, 2015 10:28 am
Thanks. I'm working with it at 300/310w at the moment. This is hard, but not so hard that I fail. As long as I'm properly rested, I manage that well enough. Two of us are doing similar training, we push each other a bit.vander wrote:When you next change you FTP stabilise for a bit. The CTL wont show the riding as harder but it will be.
TSB is good, it corresponds well to how I'm feeling. When it is very low - I know, I feel that.
Postby donncha » Thu Feb 19, 2015 4:18 pm
Personally, I aim to hit -20 TSB early in a block and then stay around that area. If I end up below -30 then I take the next day off, as history shows I've an increased risk of getting a cold. Towards the end of a block I take a few easier days until TSB comes back to around 0 to -5ish. Seems to be working OK so far. I also know I can dig a massive TSB hole (like -98 after TDU) as long as it's a one-off and I take plenty of time to recover afterwards.
Key point is you need to figure out how your TSB values correspond to your fatigue levels and work from there.
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu Feb 19, 2015 6:05 pm
What method were you using to establish FTP?Xplora wrote:I'm pretty much convinced the FTP model doesn't cover me too well. I get much better results following the Golden Cheetah "estimated CP" curve. It tracks my FTP quite a bit lower than the Training Peaks NP/TSS modelling and direction.
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu Feb 19, 2015 6:18 pm
Assuming you TSS is being correctly calculated, then changing the CTL time constant won't have much impact - it's pretty insensitive that that. Changing the ATL time constant has more impact. If you feel that you take longer to recover then you might want to stretch it out to closer to 10 days, or if you recover more quickly then shorten it to say 5 days.Xplora wrote:I need to tweak the recovery periods - 42 days longterm and 7 days short term don't seem to cut the mustard.
You can set up multiple PM charts with different time constants, overlay your power or performance bests on those and then see which one better matches when your actual performance is good/bad/indifferent.
Here's a post and video explaining these things some more and in particular the difference in sensitivity of the chart to changes with the time constants:
http://alex-cycle.blogspot.com.au/2013/ ... lysis.html
- Xplora
Postby Xplora » Fri Feb 20, 2015 12:39 am
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri Feb 20, 2015 7:50 am
Yes, need to be very careful when attempting to mix training loads from different exercise modalities. They are not linearly additive, nor have the same impacts on rates of fitness and fatigue development, and the cross impacts are, well, I'm not sure I'd bother beyond a very top level overview...Xplora wrote:Funny you mention this Alex. I started a new file today that was missing the TSS for weights. Very strong correlation between anaerobic PBs and weights.
- Xplora
Postby Xplora » Fri Feb 20, 2015 8:27 am
