RideWithGPS Question
Krank
Postby Krank » Sun Sep 18, 2016 2:07 pm
Hello all.
I have created a map/route on 'RidewithGPS' that I want to write the GPX file to Garmin Connect.
Is paying money to subscribe the only way to achieve this with this software?
Krank
JetRangerMike
Re: RideWithGPS Question
Postby JetRangerMike » Sun Sep 18, 2016 3:15 pm
Do you want to load into Garmin Connect or get into onto your Garmin device?
The reason I ask, what I normally do to get onto my Garmin 520 is export from RidewithGPS as TCX and then load directly onto the device through the USB connection into the NewFiles folder. Which then loads into Courses.
I'm not sure how to load a course into Garmin connect, as a GPX or any other format for that matter.
Krank
Postby Krank » Mon Sep 19, 2016 8:46 pm
Thanks.
i would export from RidewithGPS onto IMAC, then move file into NewFiles folder under Garmin USB drive, which then shows up in courses.
Why do you prefer TCX over GPX?
Differences?
Krank
JetRangerMike
Postby JetRangerMike » Mon Sep 19, 2016 10:37 pm
I'm not 100% sure of the differences between TCX & GPX - but had a funny feeling to get the turn-by-turn navigation needed to use TCX, and then have just kept using it. Alas, just a creature of habit ... if it ain't broke don't fix it! :)
Postby RonK » Mon Sep 19, 2016 11:36 pm
Krank wrote:i would export from RidewithGPS onto IMAC, then move file into NewFiles folder under Garmin USB drive, which then shows up in courses.
You don't need a subscription to export a route.
