Postural blood pressure problem
uad782
Postby uad782 » Fri Dec 07, 2018 9:59 pm
‪I would appreciate people’s advice. ‬
‪The other night I sat on the bed and leaned forward to tie shoe laces. I got a loud sound in one ear and felt really dizzy. This probably lasted for about a minute. Raced to local ED who did bloods and diagnosed it as probably postural hypotension. I had had a dizzy spell the week before too just before going to sleep but nothing very serious. They were also concerned as my heart rate was 46. I am around 50 yo.‬
‪I have been dieting and cycling around 10 hrs, 2 x 3.5 hours sessions and a 2.5 hour session ,per week of very hilly courses. Lost around 8kg in 2 months. I don’t use any supplements and just drink water for cycling.‬
‪Went and saw my GP the next day and he said not to worry about it and see if it happens again.‬
‪I have two opinions from two doctors, should I get a third?‬
Baalzamon
Re: Postural blood pressure problem
Postby Baalzamon » Fri Dec 07, 2018 11:27 pm
You most like have salt
Baalzamon
Postby Baalzamon » Fri Dec 07, 2018 11:28 pm
You most like have salt low
cyclotaur
Postby cyclotaur » Fri Dec 07, 2018 11:46 pm
Put one scoop (not the recommended 2 or 3) of Staminade in one bidon of water on your rides. Just top it up with water as you go. That’s enough for most rides of 2-3 hours.
If you’ve lost 8 kgs you have less on-board reserves, and are probably riding better (read harder) than before as well. You need to keep your energy and fluid levels up though.
**This is just my experience under similar scenario.
"Riding not racing...."
RhapsodyX
Postby RhapsodyX » Sat Dec 08, 2018 9:14 am
Symptoms:
Hypotension or orthostatic hypotension.
Bradycardia or tachycardia.
... taken from...
Wikpedia - anorexia nervosa
Not saying you have anorexia. But you might want to eat more given your body is (to a degree) shutting down. Been there, done that...
Baalzamon
Postby Baalzamon » Sat Dec 08, 2018 11:49 am
Because you only are drinking water, you are flushing out electrolytes. ie potassium, magnesium and sodium.
Next time you see you doc, ask them to check your blood electrolytes.
RhapsodyX
Postby RhapsodyX » Sat Dec 08, 2018 12:03 pm
Baalzamon wrote:Because you only are drinking water, you are flushing out electrolytes. ie potassium, magnesium and sodium.
Except, as per first post, they did that at ED - they would have picked up any gross electrolyte issues. Not saying that some salts in the drinks isn't a bad idea, depending on input/output... but it's fairly hard to cause issues *unless* you are drinking stupid amounts of fluid - and that would have shown up in the blood tests (I hope!).
At a rough guess... to lose 8Kg in two months means a calorie deficit of around 900kCal a day. Of course, a stack of that could be glycogen & associated water, heck I've had at least two periods where I've dropped 6 - 8Kg in a month! But given the OP is doing 3.5h rides on hilly terrain... sounds "trained", and probably just losing weight too quickly and the body is retaliating.
uad782
Postby uad782 » Sat Dec 08, 2018 12:06 pm
Thanks everyone. I will let you know the results
RhapsodyX
Postby RhapsodyX » Sat Dec 08, 2018 12:18 pm
uad782 wrote:Thanks everyone. I will let you know the results
BTW - over the years, I've had EXACTLY the same symptoms (tinnitus, postural), usually when losing weight and it goes away when I'm putting weight back on (damn it!). Discussed with doctors... no real outcomes.
You know you are over-doing it (calorie deficit) when you start nodding off when sitting down because the HR drops off. I have a sit-stand desk at work - hard to fall asleep standing, and the standing brings the HR up by around 10 BPM. But meetings are a real struggle.
nickobec
Postby nickobec » Sat Dec 08, 2018 4:51 pm
The first time is scary, got out of bed, stood up and hit the floor.
That was over 30 years ago, naturally low blood pressure and being sick at the time.
Since then, learnt the signs and move more slowly when I am sick or the body is recovering (from sickness or riding).
Never had the ear thing.
nickobec
Postby nickobec » Sat Dec 08, 2018 11:01 pm
ps I am almost 60, my resting HR is a little higher than yours, but well under 60. Recently, similar hours, no hills instead intervals, my diet is less structured than yours, now riding with just water, increase intensity and moderate increase in volume, dropped 7kg in 5 months and yes my orthostatic hypotension is playing up more than usual (ie getting dizzy)
Ivanerrol
Postby Ivanerrol » Sat Dec 08, 2018 11:37 pm
Do you get night cramps?
JPB
Postby JPB » Sun Dec 09, 2018 12:03 am
Ivanerrol wrote:Do you get night cramps?
Yes. Plus dizzy sometimes when crouched down with my neck forward like when looking at something on a bottom shelf and then standing up.
But i have moderate high blood pressure.
