got gouche rash
I'm not a doctor but…
Cycling injury, recovery and health issues.
got gouche rash
Postby Brian Giant » Tue May 17, 2011 8:19 pm
Hey ppl,
Im quite new to riding and as my fitness improves my rides have been getting longer, which has caused me to get quite a sore gouche to the point where I cant go for a ride untill it heels, which is quite fustrating cause it limits me to ride two or three times a week, I have tried Vaseline doesnt seem to help
I ride a giant defy with the standard giant seat should i change the seat or get new knicks my current ones have seat padding,
I have no idea been a newbie to it all so any advice will help
Cheers!!!
Brian Giant
by Forum Ads » Wed May 18, 2011 7:05 am
Re: got gouche rash
Postby greyhoundtom » Wed May 18, 2011 7:05 am
There can be several reasons for getting abrasions in that area.
Bike fit:
If the saddle is too high it causes you to rock from side to side just fractionally, increasing the chance of saddle sores.
The front of the saddle too high, same problem. The saddle should be just about level.
Wrong size saddle: the saddle should be wide enough so that your weight is supported on your sit bones.
Wearing undies under your padded knicks can cause problems as these often have a stitched seam that will cause abrasions.
If the cause is none of the above, a seat with a cut out centre section can often relieve these problems, and if all else fails Aussie butt cream liberally applied.
greyhoundtom
Re: got gouche rash
Postby wookie661 » Wed May 18, 2011 7:50 am
I find the but cream is the best. You want an anti fungal Rash cream. Or even nappy Rash cream.
My seat can't be level. If you lean forward to reach the bars your seat should actually nose down a bit to relieve that area.
wookie661
Re: got gouche rash
Postby Redbull » Wed May 18, 2011 8:05 am
The trouble with jogging is that the ice falls out of your glass
Redbull
Re: got gouche rash
Postby skull » Wed May 18, 2011 11:12 am
greyhoundtom wrote: a seat with a cut out centre section can often relieve these problems
I found those seats to be the worst for saddle soreness.
Bum cream and a fizik Airone on my roadie and a fizik gobi on my mtn bike works for me
skull
Re: got gouche rash
Postby ColinOldnCranky » Wed May 18, 2011 11:23 am
As a unicyclist, irritation of the groin is the common bane. Though with time I have toughened up a lot, I still have to give some attention from time to time.
I use, when needed, Resolve in a squeeze tube. It is available from chemists for around $15 from memory which is far better than some of the snake oils directed at the trendy-cyclist market.
There are two variants. You'd need to check with the pharmacist, but my recollection is that one includes an antigungal and one includes a silicone based sealant of some sort, which needs to be put on only after the skin has dried well, not immediately after stepping out of the shower.
ColinOldnCranky
Re: got gouche rash
Postby gorilla monsoon » Wed May 18, 2011 12:35 pm
Chamois Glide. Noice.
Some days you are a big, strutting rooster, some days you are a bit chicken and some days you are just a complete cocque. Roger Ramjet: 2009 Giant CRX3 Spockette: 2009 Trek FX 7.3 (WSD, property of Mrs Monsoon) Lady Penelope: 2011 Avanti Cadent 1.0 TdF
gorilla monsoon
Re: got gouche rash
Postby Karati » Wed May 18, 2011 12:39 pm
Investing in a decent pair of bibs or nicks is also a must!
I started out in a pair of cheapy no name nicks and after buying a few pairs of high quality bibs its made a huge difference. I dont use any of the bum creams etc.
Karati
Re: got gouche rash
Postby Mulger bill » Wed May 18, 2011 2:53 pm
Nobody else has said it yet...
BROOKS saddle :wink:
A good slather of Bepanthen nappy rash cream won't go astray either.
Re: got gouche rash
Postby rustychisel » Thu May 19, 2011 4:15 pm
gouche? :?: :?: :?: :?:
rustychisel
Re: got gouche rash
Postby rockviewau » Thu May 19, 2011 5:28 pm
rustychisel wrote:gouche? :?: :?: :?: :?:
between the testes and anus
Lucas Hayden
Current Ride: BMC SSX01
rockviewau
Re: got gouche rash
Postby triangle » Thu May 19, 2011 6:25 pm
Ahhh .. you mean the twernt.
Cause if it twernt there your guts would fall out.
triangle
Re: got gouche rash
Postby Mulger bill » Thu May 19, 2011 7:05 pm
I have found the answer!
There's a Choob too :wink:
Re: got gouche rash
Postby grantw » Thu May 19, 2011 10:42 pm
Mulger bill wrote:I have found the answer!
I almost believe it
grantw
Re: got gouche rash
Postby Eugene » Tue May 31, 2011 6:43 am
Mulger bill wrote:A good slather of Bepanthen nappy rash cream won't go astray either.
+1
this stuff is the best, $6 a tube, lasts forever, put in when dry, or just before a ride, rash is gone in the morning, I have used on pushy, jetski, dirt bike, and when at feild days selling equipment for 4 days in 40 deg heat, dont leave home without. however, after dropping 15+ kg, I have not required, there is now a gap between my thighs that has not been there for a while. :D
Eugene
Re: got gouche rash
Postby Eugene » Tue May 31, 2011 6:45 am
on a femme, its the twitter, you know between the Tw*t and Shi**er.
Eugene
Re: got gouche rash
Postby Semar » Tue May 31, 2011 9:59 pm
Being both experimental and tight, I use this product. It takes the heat out of it really quickly.
It’s more like our thoughts are thinking us than we are thinking them.
Semar
Re: got gouche rash
Postby gorilla monsoon » Wed Jun 01, 2011 12:25 pm
The taint. Because it taint one nor the other. :D
gorilla monsoon
Re: got gouche rash
Postby Brian Giant » Fri Jun 03, 2011 10:25 am
problem solved all i had to do was put the seat down by about 15mm and no more sore gouche :lol:
Im quite surprised that such a painfull problem was such a simple fix,
Cheers on all the helpful replies
Brian Giant
Re: got gouche rash
Postby greyhoundtom » Sat Jun 04, 2011 8:17 am
Brian Giant wrote:problem solved all i had to do was put the seat down by about 15mm and no more sore gouche :lol:
:mrgreen:
Due to personal experience gained by solving the very same problem :oops:
greyhoundtom
Return to Cycling Health
