Truth on diet and weight control
PawPaw
Re: Truth on diet and weight control
Postby PawPaw » Wed Feb 22, 2012 10:43 pm
sogood wrote:There are always new research papers being published on the matter of calorie/weight control. Here's a good one and one that makes good sense.
http://www.smh.com.au/lifestyle/diet-an ... 1tjef.html
The associated new calculator is at,
http://bwsimulator.niddk.nih.gov/
IME, dietitians realize a consistent weight loss rate is reliant on a consistent Calorie deficit, as bodyweight declines.
I've never heard an Australian dietitian give advice such as reduce your food intake by one latte per day to attain a consistent rate of wt loss.
sogood
Postby sogood » Wed Feb 22, 2012 10:53 pm
PawPaw wrote:IME, dietitians realize a consistent weight loss rate is reliant on a consistent Calorie deficit, as bodyweight declines.
I would think that NIH scientists/doctors carry some weight in their area of expertise.
PawPaw
Postby PawPaw » Wed Feb 22, 2012 11:29 pm
Like the article says, the calculator hasn't taken the world by storm. And it isn't rocket surgery to realize you stop a Calorie deficit when you want to stop wt loss. Therefore, you have one Calorie intake for wt loss and another once you reach your goal and want to maintain the lower weight. If you want to lose a lot of weight, say 15kg or more, then at some point (say after losing 7kg), you'd revise your Calorie intake down to meet the reduced Calorie needs of a lighter body, and maintain the same Calorie deficit.
Indeed, how on earth does straight line weight loss, as depicted in the NIH simulator, on the same Calorie intake (after an initial short faster loss of glycogen), fit with anything said in the SMH article?
Users browsing this forum: thatmdee, Top_Bhoy
