Foot cramps, some pins and needles.
I'm not a doctor but…
Cycling injury, recovery and health issues.
Postby lump_a_charcoal » Sat Apr 14, 2012 7:11 pm
Hey all -
I have found that I tend to get a cramp in the arch of my foot at times when cycling, and sometimes it becomes pins and needles.
My shoes fit well also.
Does it sound like bad technique, bad setup or just overtightened shoes?
lump_a_charcoal
by Forum Ads » Sat Apr 14, 2012 7:22 pm
Re: Foot cramps, some pins and needles.
Postby foo on patrol » Sat Apr 14, 2012 7:22 pm
Can be a combo of all! Try a process of elimination by starting with you shoes. Loosen them off a bit when you go out next and work back from there. :idea:
Foo
Goal 6000km
foo on patrol
Postby lump_a_charcoal » Sat Apr 14, 2012 7:44 pm
Good idea, I'll give it a go.
Thankfoo very much.
lump_a_charcoal
Postby greyhoundtom » Sun Apr 15, 2012 6:12 pm
If you are getting pain in the arch of the foot the most likely cause IMHO is repetitive strain to the Plantar Fascia which is a fibrous band that runs from the heel to the base of the toes.
Therefore the cleat setup could be contributing to the problem, and it would be worth checking the cleat position on the shoes to ensure it lines up correctly with the centre of the joint where the toes connect to the foot.
greyhoundtom
Return to Cycling Health
