what do you eat when the 3pm munchies strike?
westab
Re: what do you eat when the 3pm munchies strike?
Postby westab » Fri Jun 22, 2012 5:30 pm
I indulge in a big cup of Milo (and usually a heaped teaspoon full of milo too) in all but summer - in summer it doesn't happen as I drink heaps of water.
Sometimes I go the odd packet of chips - I am not good but I will not worry about it as long as my weight stays between 70 & 80 kg. If I do go above 80kg I just force myself to stay above 30km/h on the shared path all the time on the way home and watch the snacks I eat. Presto 3 weeks later I am back where I should be - keep going one more week because fast is fun and then usually stuff up again.
It also only seems to happen this time of the year. :(
Not fast, no style, but still get there.
Addictr3
Postby Addictr3 » Mon Jun 25, 2012 4:32 pm
PawPaw wrote:
Addictr3 wrote:Estimating Requirements
The simplest method is to base your intake on a standard 'calories per unit of weight (usually kilograms)'. Typically:
- 26 to 30 kcals/kg/day for normal, healthy individuals with sedentary lifestyles doing little physical activity [12.0-14 kcal/pound]
Hmmm....
I am a male, 87kg, 20% bodyfat. BMR is ~1800 Cals, TDEE = 2300. 30 * 87 = 2610 Cals.
That 300 Calorie overestimate is going to see me with 14kg extra fat at the end of a year.
For an 87kg 'normal' woman, BMR = 1650Cals and TDEE = 2100 Cals. So they'll be 23kg heavier at the end of the year.
87kg normal woman ay
If you can't explain it simply, then you don't understand it well enough.
Gerry.M
Postby Gerry.M » Tue Jun 26, 2012 8:49 am
westab wrote:......
Sometimes I go the odd packet of chips - I am not good but I will not worry about it as long as my weight stays between 70 & 80 kg......
I used to do this, eat the little snack size ones in the afternoon, until I started taking more notice of the Nutritional section on the back.
Most I find are at least 30% fat so I now avoid them completely
PawPaw
Postby PawPaw » Tue Jun 26, 2012 10:11 am
Addictr3 wrote:87kg normal woman ay
imagine a 60kg woman who'd been following your dietary advice for 14 mths.
DaveOZ
Postby DaveOZ » Tue Jun 26, 2012 10:17 am
I ride home at ~ 3:30pm. This sort of helps me avoid the afternoon munchies. I drink some water before and during the ride and I have a small handful of nuts when I get home. We always have dinner around 6pm. I find I get the munchies worse when I don't ride and chips are my enemy.
KillerHeadWind
Postby KillerHeadWind » Tue Jun 26, 2012 5:36 pm
If I am home then ice cream always enters my mind with strawberry topping (yummmmmmm).... but luckily I am working most of the time and have a lovely variety of fruit :D
Keep climbing until the air is too thin
2006 Gitane Mach 2400, 2007 Giant OCR3 (RIP), 2009 Custom built Stealth, 2010 Pedal Force SRAM Red Rocket
RIP Dad
10:10pm 02/02/2011
Meditator
Postby Meditator » Wed Jun 27, 2012 7:37 pm
It depends but if i got hungry tonight i might have weetbix, milk and honey. Other times i'd have toast butter vegemite.
