Page 1 of 1
Bought first pair of spd shoes..... aching feet
Posted: Mon Dec 17, 2012 4:47 pm
by nuttzo32
Hi i just recently purchased a set of shimano spd shoes and went on my first 10km commute with them today and within a few minutes of riding i started to develop aching feet under the balls/arch area of the feet.Is this due to incorrect cleat positioning or is this just because my feet aren't used to pulling up the pedals?
Re: Bought first pair of spd shoes..... aching feet
Posted: Mon Dec 17, 2012 5:19 pm
by Venus62
I'm no expert but I did my first ride (~20km) in cleats on the weekend and had no foot pain at all, so I'd suspect incorrect placement.
Posted: Mon Dec 17, 2012 5:24 pm
by ball bearing
Youtube has many cleat positioning videos.
Posted: Mon Dec 17, 2012 5:42 pm
by DoogleDave
Your feet shouldn't hurt when wearing your cycling shoes.
Here's a few links which might be helpful reading:
http://www.stevehoggbikefitting.com/blog/2011/04/power-to-the-pedal-cleat-position/
http://www.livestrong.com/article/246381-bicycle-pedal-adjustment-foot-pain/
When I first started wearing my cycling shoes (MTB shoes with SPD), I was getting sore feet every now and again and after adjusting my cleats further back my feet have been fine ever since.
Dave
Posted: Mon Dec 17, 2012 5:50 pm
by grantw
A few minutes? Crikey.
Cleat position aside, how tight did you do them up? It's easy to get carried away with the cams and whatnot. Less is more I find.
Posted: Mon Dec 17, 2012 6:01 pm
by nuttzo32
I will try positioning the cleats further back and see how it goes tomorrow.
Posted: Mon Dec 17, 2012 7:43 pm
by wombatK
Why are you trying to pull-up ? You might be over-thinking it and straining your legs.
There's good research that there's not much benefit in consciously pulling up - see for example
Perfect Pedal Strokes
If you try to consciously pull-up, you'll be engaging different muscles in your feet and calves.
Not only will they hurt, but their blood flow and metabolic demands could mean you'll get less
power out of your down-strokes. Think of the upstroke as recovery time.
The primary benefit of clip-ins is that you can start your down-stroke right at pedal top, without
risk of your foot slipping forward off the pedal. And similarly, you can continue it right to the
pedal bottom without slippage. Thats how you can increase your power output without having to
engage a whole different set of muscles.
The secondary benefit of clip-ins is that everyone else gets a good laugh when you clip-stack :)
Posted: Mon Dec 17, 2012 7:56 pm
by DoogleDave
wombatK wrote:The secondary benefit of clip-ins is that everyone else gets a good laugh when you clip-stack :)
YES....+1 :lol:
Posted: Mon Dec 17, 2012 10:04 pm
by nuttzo32
wombatK wrote:Why are you trying to pull-up ? You might be over-thinking it and straining your legs.
Ok thanks for the info, i'm not sure if i am consciously pulling up but maybe i am pulling instead of pushing down and letting the pedals circle. And i did come close to having a clip stack today when i pulled out my right foot and went to lean on the left foot while it was still clipped in but i managed to get it out just in time.
Posted: Thu Dec 20, 2012 2:47 pm
by nuttzo32
Moving the cleats further back and loosening straps on the shoe has made quite a difference, my left foot was only slightly sore today but much better than a few days ago. I think i may be slightly twisting my left foot when pedalling but a few more days breaking in the shoes and there should be no more discomfort.
Posted: Thu Dec 20, 2012 6:45 pm
by uncle arthur
Your competent LBS owner may be able to help you out with a bike fitting which (when I had mine) includes your cycling shoes for cleat placement. I've never had a sore foot.
Posted: Mon Dec 24, 2012 7:32 am
by Xplora
Cleats WILL cause dramas that you didn't have with flats if they aren't set up right, nuttz, because you are locked into a cycling motion. You aren't inflicted with such motion with flats because you can float, readjust, all over the place. I noticed my feet moved HEAPS on my MTB flats riding with the kids yesterday, and I 99% of the time wear SPDs.
Posted: Fri Dec 28, 2012 11:55 pm
by nuttzo32
No longer getting any foot pain at all on my short 9km and back commutes, i think my feet just needed to get used to being clipped in. In a few weeks when i am on leave from work i am going to try 20km or more and see how i feel.
