Very sore perineum skin
• Page 1 of 2 • 1, 2
Very sore perineum skinI'm finding that the skin in my perineum region is very sore. I use Aussie Butt Cream before I ride too.
Do you think I should apply some on mid ride too? Does this go away with more riding (tougher skin)?
Re: Very sore perineum skinAssuming of course, that your position is correct and your saddle is appropriate, are you applying enough cream to the chamois?
Watch the movie "Hell on Wheels" and see how Eric Zabel's soigneur applies chamois cream to his knicks. You might be surprised. Cycle touring blog and tour journals: whispering wheels...
Re: Very sore perineum skinThe skin will get used to it. But two items,
1) Stand often. 2) Wear good quality cycling shorts/bib. It reduces the skin wear. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
I did ask on another thread about whether you should apply just the skin or to the chamois (or padded area) too. I just grab a little and rub it into my skin for a second. I guess I'll try some more!
I'm assuming my position is correct and I got my sit bones measured (went from 132 to 143 saddle).
I don't do this enough!
I mainly wear Santini bib knicks (from Prendas).
And I replied and assumed you had read it (and didn't believe me). That's why I suggested you watch the movie to see how the pro's use it. Cycle touring blog and tour journals: whispering wheels...
Re: Very sore perineum skinFact is, most recreational riders riding 100 or even 150km/day have not depended on chamois cream. Unless you have massive ride volume, the most likely reason is that you don't ride enough and have not developed the endurance down there. Build it up over time. Otherwise, sore skin is trivial compared to full blown saddle sores and other neurological problems.
Re: Very sore perineum skinI’m more inclined to think that either the saddle is unsuitable for the OP, or the saddle angle on the bike is incorrect.
The weight should be carried on the sitbones with very little pressure on the perineum, and therefore the skin in that area should not be getting sore.
Re: Very sore perineum skinIt's just the edges, not the entire centre area. I thought maybe because I'm carrying a bit of fat around the legs.
Perhaps if I angle my seat forward just a smidge?
It's certainly worth a try. That is of course assuming you wear your knicks commando without underdacks to irritate the area.
You assume correctly! Absolutely no underwear under lycra!
If its just the edges might the knicks be a size too big for you? I've had something similar recently and I suspect its because my knicks are now too big for me. ![]()
I dunno where you get that idea from. I regularly ride from 60 - 100 km rides and have always used chamois creme for more than 30 years of cycling. If I didn't use it, I'd almost certainly have serious saddle sores. Cycle touring blog and tour journals: whispering wheels...
More likely you need to move the saddle forward so you are not sitting on the narrow part. Cycle touring blog and tour journals: whispering wheels...
Ah yes I think I did move it back a little when I fitted the new saddle. I'll give that a go. And extra dollops of Aussie Butt Cream too! Thanks for the advice
If I didn't use the word "most" in my earlier post, then I would certainly be in your firing line. Bianchi, Ridley, Montague, GT, Garmin and All things Apple
Re: Very sore perineum skinI think (obviously) saddle fit and positioning has everything to do with it.
I took the two-wheels back up in late October and have done around 1500Km since - without too much trouble - however, when I went to rides over 40Km in duration, I found the shortcoming of the cheap saddle I had fitted to my bike - it caused me soreness for almost a week. Once I replaced it with a proper saddle the soreness disappeared and I'm doing 60Km+ rides no worries now. I've heard of 'butt' creams, however, have never seemed to need to use them. Good luck with your nethers! 'dale CAAD10 - Ultegra6700 | Giant Defy 1 - DA7800
Re: Very sore perineum skinI've just bought a Specialized Toupe saddle! I hope it wasn't a bad choice..
Because of numbness in the perineum area I bought a Specialized Romin Saddle which is a bit cheaper than the Toupe but with the same cut out section, and it seems to have solved that problem.
I'll experiment with positioning first starting by sliding it forward a few mm, perhaps tilt it forward ever so slightly.
Is it the skin that is sore or the flesh underneath? If skin, it sounds more like the fit of your knicks. ![]()
One adjustment at a time please or you'll never be sure which is the problem. ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Re: Very sore perineum skinI use an ISM Adamo saddle so my perineum floats in mid-air.
I'll set these at forward a few mm then.
Re: Very sore perineum skinI replaced my saddle recently with an inflateable seat and so dispensed with the sheepskin that I had used for all my riding - it was on to distribute the pressure more evenly.
Anyway, about my second 50km I started getting discomfort in the same area and it seemed that the seat was gripping me too well so that tissue was constantly being stretched - on miillimetres but that is many thousands of times a trip. So I put the sheepskin back on as it does have a certain amount of lateral give. Problem solved. I have tried to do without it again and it seemed that the same thing was happening. Perhaps you can learn from my experience and somehow break any gripiness between your seat and your nether regions. Unicyclist's don't need a training wheel
