5th MT (little toe) stress injury anyone?
UpDownUp
Postby UpDownUp » Fri Mar 01, 2013 4:52 pm
Hi, has anyone had any experience with a 5th metatarsal (ie little toe) stress fracture or stress reaction caused by cycling? If you have did you change anything as a result?
I recently had a foot MRI and it showed bone marrow oedema in the 5th MT. It's sore to press near the joint (MTP joint). I both cycle and run. I suspect running is the main contributing problem but wanted to consider the whether cycling could be the cause or a contributor too?
elantra
Re: 5th MT (little toe) stress injury anyone?
Postby elantra » Fri Mar 01, 2013 5:59 pm
I think you will find this problem is due to running.
Cycling should be OK, within reason.
Users browsing this forum: Farmer Elvis
