Post-ride hurl - what's that all about?
BandedRail
Postby BandedRail » Fri Mar 29, 2013 10:36 pm
Lately after I've been on a longish and hard ride I feel nauseous and often end up having a hurl. Sometimes it can be over an hour after the ride and I feel ok(ish) after I've been sick. I can't put it down to hydration as it has occurred a number of times under different temperature & hydration conditions, then only common factor I can pick up on is that I've usually had an extended period of riding with a high heart rate. Not too worried (yet) but it's not a nice way to end a ride. Does anyone else get this?
foo on patrol
Re: Post-ride hurl - what's that all about?
Postby foo on patrol » Sat Mar 30, 2013 8:37 am
I didn't ever have that problem but one of my mates would constantly throw up after, a real hard session. :shock: (on the bike that is) :wink:
How hard were you pushing yourself? Some people will do this quite regularly after extreme exertion for whatever reason. :?
Foo
Comedian
Postby Comedian » Sat Mar 30, 2013 10:50 am
Congratulations... you are riding so hard you're making yourself hurl!
Try not to do it too often. If you don't want to hurl, try riding a little slower. :)
Howzat
Postby Howzat » Sat Mar 30, 2013 10:15 pm
Could be worth visiting your GP for a test or two; you might be in need of a supplement of some kind.
greyhoundtom
Postby greyhoundtom » Sun Mar 31, 2013 7:16 am
If you suffer exercise induced nausea you are doing something wrong.
It can be caused by over exertion when not fit enough for that level of effort, or from not cooling down slowly enough after strenuous exercise.
However, the most common cause appears to be drinking too much water, before, during, or after strenuous exercise.
