Spots on thighs, anyone else get these?
lammy
Postby lammy » Fri Apr 26, 2013 1:10 pm
Not sure if anybody else has come across this, but I noticed recently that I am getting a lot of spots on my thighs, presumably down to my cycling shorts?
I put a clean pair on to commute to work, then shower, I hang the knicks up to dry outside and by end of day they are perfectly dry for the ride home. Once I get home they are thrown in the wash and I shower again. New shorts the next day obviously. Problem is these random spots keep appearing all over my thighs, anybody got any remedies. (not spots on my torso due to the jersey btw).
jlh
Re: Spots on thighs, anyone else get these?
Postby jlh » Fri Apr 26, 2013 1:12 pm
Could be something related to hair follicles bring irritated? I have had that with other sporting uniforms.
HLC
Postby HLC » Fri Apr 26, 2013 1:15 pm
jasonlheath wrote:Could be something related to hair follicles bring irritated? I have had that with other sporting uniforms.
This.
Using an exfoliating mitt in the shower helps. Especially if you are shaving your legs.
gorilla monsoon
Postby gorilla monsoon » Fri Apr 26, 2013 5:48 pm
Pox. :roll:
Won't climb, can't sprint.
Roger Ramjet: Giant CRX3
Lady Penelope: Avanti Cadent
Barry Allen: Specialized Sirrus Expert
Summernight
Postby Summernight » Mon Apr 29, 2013 4:24 pm
Heat rash? Although you'd probably know about those as they hurt.
VRE
Postby VRE » Mon Apr 29, 2013 5:20 pm
I occasionally get grease spots on my thighs - an occupational hazard for a frequent cyclist, I guess :wink: .
simmo71
Postby simmo71 » Mon Apr 29, 2013 5:34 pm
Are your cycling knicks rubbing the hairs off your legs? Spots may be a result of ingrown hairs. If the problem is in grown hairs then there is cream that you can get which will help. I believe the cream softens the hairs and alleviates the problem.
Have you looked in the cycling health section for an answer? Also may I suggest that this thread may be better placed in the health section.
Good luck finding a resolution. :D
kukamunga
Postby kukamunga » Mon Apr 29, 2013 8:40 pm
I find common 20% solution Tea Tree Oil good for spots, infected ingrown hair follicles, saddle sores, tinea, fungal rashes etc.
