PINS AND NEEDLES IN MY FINGERS
rabbit stew
Postby rabbit stew » Sat Oct 26, 2013 9:31 pm
Ive been mtb=ing for a few years, due to work i only did about 3 rides in 10 months. For the last 3 months iv been riding a road bike every day anywhere from 9km to 35km a day. the last week every time i ride my fingers are getting very pins and needly.
Anyone know what it could be from.
I,m not quiet. I just dont plan murders out aloud.
sogood
Re: PINS AND NEEDLES IN MY FINGERS
Postby sogood » Sat Oct 26, 2013 9:39 pm
You are probably putting too much weight in your hands. Take a look at your setup. Try to bend your elbows, and gently hold the bar, not putting all your weight on the bar.
casual_cyclist
Postby casual_cyclist » Tue Oct 29, 2013 10:49 pm
sogood wrote:You are probably putting too much weight in your hands. Take a look at your setup. Try to bend your elbows, and gently hold the bar, not putting all your weight on the bar.
Yep. I had this problem when I first started cycling. My seat was too low and too far forward. The problem resolved with a correct bike set up.
<removed by request>
Gordonhooker
Postby Gordonhooker » Wed Oct 30, 2013 9:23 am
Sogood is right I found the same thing when I first got back into cycling and have worked out it was incorrect setup and putting too much weight on the handlebars. all fixed now.... :)
OI onya bike!!!
casual_cyclist
Postby casual_cyclist » Wed Oct 30, 2013 12:17 pm
Gordonhooker wrote:Sogood is right I found the same thing when I first got back into cycling and have worked out it was incorrect setup and putting too much weight on the handlebars. all fixed now.... :)
And more comfortable to ride now too? I have found it is. :D
