Page 2 of 3
Re: Constant tightness
Posted: Sat Feb 01, 2014 12:14 pm
by foo on patrol
Well got the results from the scan and there is a 3cm cyst there. :x The Dr though doesn't think that it is the cyst but pressure on a nerve that is causing the problem. I'm trying some magnesium and calcium tables to see if the eases the constant threat of cramping and will go from there. :|
Foo
Posted: Sun Jul 20, 2014 2:05 pm
by foo on patrol
May need to go and have this checked out again. This mornings ride after stopping for coffee and something to eat, it inflicted plenty of grief on me, why more than any other time. I just couldn't power up the leg without a string of naughty words flowing. :(
Foo
Posted: Sun Jul 20, 2014 3:25 pm
by Dr_Mutley
Did u have the bakers cyst needled?
Posted: Sun Jul 20, 2014 6:56 pm
by foo on patrol
No and that is why I think I need to get it checked out again. It always lets me know it's there but this time no matter what I did, it did no relieve the pain.
Foo
Posted: Sun Jul 20, 2014 9:23 pm
by chriscole
foo on patrol wrote:Here a wobbly question. In the area I have circled, there is a constant tightness like a cramp about to happen when not on the bike and when on the bike, depending on how hard I am riding it increases in tightness. It is yet to get to a full on cramp but is not far off. So any suggestions on a possible cause? :?
This is behind the right leg and more towards the outside. :(
Foo
Sent from my GT-I9210T using Tapatalk
- Baker's cyst
- Lipoma
- DVT
- Alien implant
Posted: Fri Jan 30, 2015 10:05 am
by foo on patrol
Update on this mongrel thing. I'm going to push/dummy spit/rip a Drs head off :twisted: to have it syringed as it is driving me up the wall now and impacting to much on my riding. :evil:
Foo
Posted: Fri Jan 30, 2015 7:51 pm
by greyhoundtom
Have you had a look at this?
http://www.youtube.com/watch?v=kH6of0ipfXw
Posted: Sat Jan 31, 2015 6:44 am
by foo on patrol
I have now, thanks. :)
Foo
Posted: Sun Feb 01, 2015 11:07 am
by CXCommuter
Foo
- Baker's cyst
- Lipoma
- DVT
- Alien implant
Speaking from experience my alien implant was not inserted into the back of my knee :?
Posted: Fri May 08, 2015 4:57 pm
by foo on patrol
Saw the Orthopedic Specialist today and the verdict is still not totally clear yet. It would seem however, that I may have a torn Medial Meniscus and this maybe the root cause of the problems. MRI scan is going to happen and a course of action, will taken from there. :wink:
Foo
Posted: Fri May 08, 2015 5:26 pm
by CKinnard
well a Baker's Cyst is a symptom, not a cause. It occurs when you have an effusion in the knee joint. And an effusion happens when you have damaged tissue in the joint causing an inflammatory response with associated fluid ingress to the joint space.
So draining a cyst often only gives temporary pressure relief. When you go stir up the damaged tissue again, the swelling starts all over again.
For a guy your age, I'd put money on the medial meniscus being a mess. There's a few orthopedic tests the surgeon could have done in less than 60 seconds to confirm....but some don't like to get their hands dirty, unless in theatre. Transverse tears often have no other symptoms apart from an effusion with activity. The surgeon will most likely offer to trim or remove the meniscus arthroscopically. But that won't necessarily get you pain free on the bike.
Posted: Fri May 08, 2015 6:50 pm
by foo on patrol
What, you sayin I'm old? :P
He did some movement tests and pressure tests and said I still have good mobility and condition in my knees, for my age. :mrgreen:
Oh and he wants me to have a hard ride before the MRI so he can see what's happening under load. :wink:
Foo
Posted: Fri May 08, 2015 9:20 pm
by CKinnard
foo on patrol wrote:What, you sayin I'm old? :P
Foo
you also have damaged tissue that's been causing a recurrent effusion! :D
I know some surgeons would advise not to ride hard before hand because it will just light up everything! but it's his call.
Posted: Sat May 09, 2015 6:05 pm
by foo on patrol
I'm curious, CK! I would have thought that you would (not you personally) want to see how things were reacting when, the area was aggravated when put under load? :? Not having a crack at you, just curious for info. :)
Foo
Posted: Sat May 09, 2015 6:54 pm
by CKinnard
foo on patrol wrote:I'm curious, CK! I would have thought that you would (not you personally) want to see how things were reacting when, the area was aggravated when put under load? :? Not having a crack at you, just curious for info. :)
Foo
have a crack at me... everyone else does :)
if the knee is painful at the drop of a hat, then the pathology should be clear without stirring it up.
the risk of going for a hard ride is you will pull a lot of fluid into the joint, and activate a lot of inflammation, which is the source of 'lighting up' everything.
most orthopods won't do a mri in the early stages of a traumatic joint injury because everything is 'hot' or lit up. To get a clearer picture of which tissue is damaged, it helps to wait for the inflammation to calm down.
anyway, the guy might know something others don't...or he might request a certain T1/2 weighting from the radiologist.
and keep in mind a MRI is only as accurate as the radiologist's interpretation.
Interestingly, I think services like this will become more common in the future.
https://www.diagnose.me/
I just see so much compromised health care these days. And my older GP mates agree.
I'm spending 6 hours next Saturday at St Andrew's hospital in Brisbane with 4 orthopods and various sports specialists, and this Wed night with 5 shoulder specialists....so will raise the hot mri thing with both groups :)
Posted: Sat May 09, 2015 7:35 pm
by foo on patrol
Ok thanks but mine is not painful all the time and there is no set pattern for it to play up, as I look for patterns when I have physical problems that occur. If I see a pattern, then I look for ways of working around it but I notice the tightness there all the time, it just doesn't give me curry when riding every time. :? I can PM his name to you and see if he is at this seminar. :idea:
Foo
Posted: Sat May 09, 2015 7:57 pm
by CKinnard
if he's a Brisbane or Redcliffe Peninsula orthopod, I'll know him.
if your knee plays up intermittently, that's pretty much what many meniscal tears do. when they tear, they can have a loose flap, and sometimes the flap will fold over or bunch on itself. causing pain. fluid leakage can be constant due to irritating the tissue every time you stand walk.
you may also have some loose or damaged cartilage on the end of the femur, esp on the medial side where the meniscus is damaged. (the meniscus when healthy acts as a cushion to preserve the cartilage.
Posted: Wed May 13, 2015 11:07 pm
by CKinnard
Foo, I spoke with a sharp ortho tonight. he said it's ok to stir your knee up immediately before MR imaging...as long as you do an MR arthrogram.
This is where gadolinium dye is taken to contrast enhance the most recent damage. Talk to your dr about gado MR. gado can be given orally or injection. and ask about toxicity!
Posted: Fri May 15, 2015 4:27 pm
by foo on patrol
Ok thanks, CK.
Foo
Posted: Sat May 23, 2015 12:00 pm
by foo on patrol
Had the MRI scan last night, it took that long that I fell asleep! :lol:
Foo
Posted: Fri May 29, 2015 2:20 pm
by foo on patrol
The verdict is.........half the gristle is gone from under the knee cap, I have a cyst in the bone but is of no concern. Plus there is no op to take place. :D
I have been told that my knee is good for at least another ten years, yaaay so that means I can now hook in, with the help of some anti inflammatories to control the pain and discomfort. 8) Happy dance! :lol:
Foo
Posted: Fri May 29, 2015 6:42 pm
by greyhoundtom
foo on patrol wrote:The verdict is.........half the gristle is gone from under the knee cap, I have a cyst in the bone but is of no concern. Plus there is no op to take place. :D
Foo
That is good news however.........
The knee is good for ten years if you give it a good hiding? Or is it good for ten years if you take it very gently?
Posted: Fri May 29, 2015 6:46 pm
by foo on patrol
No he said that cycling is the best form of exercise for my type of problem and I'm right to do hill work. :mrgreen:
Foo
Posted: Sat May 30, 2015 5:07 am
by greyhoundtom
foo on patrol wrote:No he said that cycling is the best form of exercise for my type of problem and I'm right to do hill work. :mrgreen:
Foo
That is so excellent. :D
No doctors ever give me good news like that........most of the time I get told to stop doing whatever I'm doing before I stuff it up some more. :oops:
Posted: Sat May 30, 2015 3:06 pm
by foo on patrol
That's a bugger, Greyhoundtom! :(
Foo
