Sore Arms/Lats I must be doing it wrong...
TonyMax
Postby TonyMax » Thu Feb 20, 2014 8:56 am
Hi,
I come home from 80+km rides often with sore triceps/lats/shoulders. I would have thought my legs should be the bits that hurt.
Other than somehow consciously trying to hold my upper body up with my core/abs how can I prevent this?
Tony
g-boaf
Re: Sore Arms/Lats I must be doing it wrong...
Postby g-boaf » Thu Feb 20, 2014 10:42 am
I reckon this is a bike fit issue - maybe stem length, angle of the hoods on the drop bars.
I've had the sore arms a bit too. Have you tried sitting up and pedaling without your hands on the bars for a while? Do you have your shoulders tensed up, or relaxed? Do you get down on the drop section of the bars and keep your arms bent a little bit when doing it. Also try standing and pedaling for a little while.
I can't pin-point exactly the cause, but those things are what I'd try if I were you. Changing your position on the bike occasionally might reduce the soreness temporarily until you can get the bike fit checked.
TonyMax
Postby TonyMax » Thu Feb 20, 2014 10:55 am
g-boaf wrote:I reckon this is a bike fit issue - maybe stem length, angle of the hoods on the drop bars.
I've played with the bars and rotated them downwards, but I still have the issue. Pedalling while sitting up no handed relieves things. I do tend to lean on my arms, and have them straight making bumps not very pleasant.
The only thing I can think of is maybe bring my seat forward in the rails a little? See if that helps?
I very rarely use the drops.
brentono
Postby brentono » Thu Feb 20, 2014 10:58 am
TonyMax(just got your update) :)
You should be riding mainly on the tops. You weight should be evenly distributed between
your hands and your r's. Maybe you need to drop your seat a cm to try, or raise your head-stem a cm,
to balance it all out. Give it a try.
:mrgreen:
Lone Rider- I rode on the long, dark road... before I danced under the lights.
g-boaf
Postby g-boaf » Thu Feb 20, 2014 11:00 am
Brentono seems to be on the money.
TheBikeShed
Postby TheBikeShed » Fri Feb 21, 2014 5:23 pm
If your lats are getting sore, it's also possible that you're also pulling on your bars a lot while you're riding—I find that I start doing this near the end of a ride when I'm tired and going uphill. If your fit is a bit off, that could be contributing, too. But next time you go out, pay attention to how much you're pulling back.
foo on patrol
Postby foo on patrol » Fri Feb 21, 2014 8:08 pm
To me, it sounds like you are placing to much weight on your upper body, so as Brenton suggested try dropping the seat and play with a slightly longer stem or lift it up a bit. :idea:
Foo
Goal 6000km
kenwstr
Postby kenwstr » Fri Mar 14, 2014 5:10 pm
If you don't do core upper body work, it could just be that. A little fixed it for me anyway but I had already recognised a lack in this.
Ken
