Sore knees
TheDon
Sore knees
Postby TheDon » Mon Aug 04, 2014 8:37 pm
Swapped to speedplay pedals recently. Both knees now sore after riding. Thinking I might need to drop saddle a touch to account for reduced stack height. Thoughts?
rodneycc
Re: Sore knees
Postby rodneycc » Mon Aug 04, 2014 9:52 pm
Hi mate, maybe we should compare notes/pain :-). I've been told the following which I'm working through fyi
Back of knee pain = Seat to high
Front of knee pain = seat too low.
Inner side knee pain = cleat too far on inside of shoe.
Outer side knee pain = cleat too centred or outside of shoe.
Or you might need to open up the float a bit more. I screwed my zeros out to the max limit which I think has helped a little.
rodneycc
Re: Sore knees
Postby rodneycc » Thu Aug 07, 2014 5:09 pm
Also just a quick note on seat too high. I find that's my usual problem after I've "played with my bike settings". I always find I have a lot more dramas with my knees from seat too high rather than seat too low so always better to err on the lower side I find. I did it again this week actually. Forgot to do my usual check of heal touching the pedal with the pedal straight down (the guys off here at BNA have given me that tip that is easy to check and has helped me heaps to find the right height).
foo on patrol
Re: Sore knees
Postby foo on patrol » Sat Aug 09, 2014 10:21 am
You also have too take into account the seat back or forward part, when lifting and lowering the height. :idea:
Foo
Goal 6000km
Dr_Mutley
Sore knees
Postby Dr_Mutley » Sun Aug 10, 2014 12:32 am
Assuming same cleat position behind the 1st metatarsophalangeal (MTP) joint, u will need to drop your saddle a little as the speedplay setup has the lowest stack height of most of the common pedal systems...
wgc138
Re: Sore knees
Postby wgc138 » Thu Sep 04, 2014 12:43 pm
Thanks will certainly remember these :D
rodneycc wrote:Hi mate, maybe we should compare notes/pain :-). I've been told the following which I'm working through fyi
Blinding
Re: Sore knees
Postby Blinding » Sun Oct 05, 2014 11:29 am
I picked up my road bike friday and got a fit with it too went for a 95k ride the next day and about halfway through my right calf felt crampy so we took a few breaks and made it home, once home though I noticed a tightness in the back of my knee but only on the right side again. Im wondering if this is more to do with cleat positioning rather than seat being too high as it is only on the right side??
(Sorry for the threadjack)
2017 Giant Contend SL1 Disc
outnabike
Re: Sore knees
Postby outnabike » Sun Oct 05, 2014 4:16 pm
