BNA Losers Club 2018
tcdev
Re: BNA Losers Club 2018
Postby tcdev » Mon Jun 18, 2018 4:59 pm
Rorschach wrote:Honestly, thats the way I want to go. If I start restricting everything and not being able to do some of the things I want, I won't do it. It's happened before and I binned the whole thing pretty quickly.
I think that's the key for the vast majority of people. That and making baby steps is what has been working for me. Inevitably you'll plateau somewhere and have to stop and re-evaluate your choices, but more incremental changes are easier to make as you go.
I counted calories for a few months just to learn more about diet and nutrition; and it's probably high time I gave myself a refresher course. That was eye-opening and also helps with portion control. It's way too tedious to maintain indefinitely, but once you get the gist of what you're putting in your mouth, you can wing it from thereon in. I personally don't see the utility in the pre-prepared meals as ultimately you have to learn how to cook properly for yourself. Plus it's expensive.
Just a caveat - and you've probably been told already by absolutely everyone you know with kids - your free time factor will plummet and your fatigue level will sky-rocket. For a while at least. So avoid making grandiose exercise plans before he/she arrives! I started riding when my daughter was two, and then when my son was born soon after, my km reduced drastically. Zwift has made a huge difference there!
Good luck!
2015 Giant XTC Advanced 29er 1, Suunto Ambit2 Black
2011 Schwinn Sporterra Comp
Rorschach
Postby Rorschach » Mon Jun 18, 2018 5:14 pm
tcdev wrote:
Rorschach wrote:Just a caveat - and you've probably been told already by absolutely everyone you know with kids - your free time factor will plummet and your fatigue level will sky-rocket. For a while at least. So avoid making grandiose exercise plans before he/she arrives! I started riding when my daughter was two, and then when my son was born soon after, my km reduced drastically. Zwift has made a huge difference there!
This is something I've considered, although won't know until I get there.
I'm mainly trying to build positive habits now so that I can at least try and maintain a semblance when things kick off. This would be waaay harder try to start afterwards!
RobertL
Postby RobertL » Tue Jun 19, 2018 9:41 am
Latest check in:
Date Height Weight Waist BMI WtHR
30/06/2015 189.5 120 ?? 33.42 ??
06/01/2017 189.5 108.2 112 30.13 0.591
25/01/2017 189.5 107.8 111 30.02 0.586
16/02/2017 189.5 106.8 110 29.74 0.580
03/04/2017 189.5 105.9 107 29.49 0.565
01/06/2017 189.5 105.3 106 29.32 0.559
13/07/2017 189.5 104.6 105 29.13 0.554
07/08/2017 189.5 103.7 105 28.88 0.554
04/09/2017 189.5 102.1 104 28.43 0.549
22/11/2017 189.5 101.6 103 28.29 0.544
04/01/2018 189.5 100.7 102 28.04 0.538
14/02/2018 189.5 99.1 101 27.60 0.533
30/04/2018 189.5 98.5 100 27.43 0.528
21/05/2018 189.5 97.1 98 27.04 0.517
18/06/2018 189.5 96.4 98 26.84 0.517
So, down another 0.7kg, but no change to my waist.
I actually find it quite difficult to get an accurate waist measurement, so I'm not too worried about it. And looking at that progression of waist measurements, I may have measured it too small last time.
tcdev
Postby tcdev » Tue Jun 19, 2018 11:26 pm
Rorschach wrote:I'm mainly trying to build positive habits now so that I can at least try and maintain a semblance when things kick off. This would be waaay harder try to start afterwards!
Good plan, absolutely. Not meaning to discourage you in any way.
Just don't feel you're failing and throw in the towel when your bundle of joy arrives and your weekly/monthly/yearly goals (if you have them) evaporate for a while. That's likely true for diet as well as exercise - although to a lesser degree - until things settle down. And you probably won't have to worry about eating out too often either! ;)
Good luck and keep checking in here with your results! :D
Rorschach
Postby Rorschach » Wed Jun 20, 2018 11:23 am
Cheers!
I've been in this position before and getting back on the horse is the hardest part. Anyone can make the commitment but following through when you're at the low point is the big test of character!
Patt0
Postby Patt0 » Sat Jun 30, 2018 3:23 pm
Patt0 wrote:
Patt0 wrote:
Height=183cm
WtHtr = 0.44
Weight=82kg
Waist= 80cm
Same same. Time to try something new.
84kg so gained two kilo.oh well it was fun.
Grilled chicken and pork, ice cream and vast amount of beer for a month. I honestly knew it wouldn’t work but it was fun. Now I am back home, I I am going to do what worked best last year. Moderate carbs and protein and low fat.one meal per day. Oh I will also do some pedalling too.
tcdev
Postby tcdev » Sun Jul 01, 2018 10:28 pm
June check-in!
Started this journey mid-2014 at 114.5kg.
As of 2018:
12/2018: Weight=95kg
01/2018: Weight=94.1kg, WtHR=0.55, BMI=29.7
02/2018: Weight=93.2kg, WtHR=0.55, BMI=29.41
03/2018: Weight=91.0kg, WtHR=0.54, BMI=28.72
04/2018: Weight=90.5kg, WtHR=0.53, BMI=28.56
05/2018: Weight=90.2kg, WtHR=0.53, BMI=28.79
06/2018 (Jul 1st):
Weight = 90.2kg (same)
WtHR = 0.53 (same) (consider action)
BMI = 28.79 (same)
Brought it back from a disastrous first half of the month. Injuries, health issues, and family health issues all compounded with careless diet (mainly dinners and drinks with visitors) and the results were absolutely as expected. Back on track in the latter half of the month to negate the damage. May not have made any progress this month but feel good that I am able to turn things around when required. Thoroughly enjoying all aspects of the exercise, predominantly cycling, so no issues with motivation on that aspect!
Work will get busy this month so it'll be interesting!
nemo57
Postby nemo57 » Mon Jul 02, 2018 5:37 pm
Nearly 3 months, 1500K longwise and 10K upwards later, I've lost about 1.5Kg. Now sitting just under 86. The overall mass reduction has slowed very much, but my dimensions continue to shrink. My pants are starting to look like they've got bigger in the wash. It's been a very long time since I had a 36" waist, that's for sure!
I'm not really expecting much more weight to drop off: not prepared to change the diet, which is reasonably balanced but allows for some indulgence; the exercise part is more likely to further densify me than reduce mass.
nemo57
Postby nemo57 » Mon Jul 02, 2018 5:46 pm
tcdev wrote:June check-in!
As of 2018:
06/2018 (Jul 1st):
BMI = 28.79 (same)
Mate, you could be all hair-shirt about it, but really, you've done a helluva job - and sustained it over 4 years. Are you significantly healthier now, even when life gets in the way, than you were then? Dumb question, I spose ...
tcdev
Postby tcdev » Wed Jul 04, 2018 10:29 am
nemo57 wrote:Mate, you could be all hair-shirt about it, but really, you've done a helluva job - and sustained it over 4 years. Are you significantly healthier now, even when life gets in the way, than you were then? Dumb question, I spose ...
Thanks! Still a work in progress after 4 years! Not sure of the end-game but suspect around 80kg, and that's likely a couple of years away.
Definitely healthier, reflected not only in my weight and fitness, but also my blood results - including blood pressure! My GP wants my pressure a tad lower due to the fact that I have one kidney but it's not too bad. As for diet, I am eating better but even when I do indulge a little, I at least think about what the effects are going to be. So those scales are always in the back of my mind! ;)
The older I get, the more I realise how critically important maintaining a healthy lifestyle is. In our youth we take our health and vitality for granted but at some point in life you have to really start working for it. I thoroughly enjoy my cycling (it's my current obsession), my weight training and my soccer so my main impediments for exercise are time and injuries rather than motivation. For this I am thankful I discovered cycling, and hopefully my enthusiasm for it won't wane. With any luck I'll be riding centuries in my 70's whilst some of my peers are parking in the mobility impaired parking spaces at the mall!
Patt0
Postby Patt0 » Fri Jul 06, 2018 2:12 pm
Patt0 wrote:before holiday~may
Height=183cm
WtHtr = 0.44
Weight=82kg
Waist= 80cm
29/6/18
6/7/18
Height=183cm
WtHtr = 0.45
Weight=84kg
Waist= 82cm
:oops:
