Best way to boost iron levels
Nitram
Postby Nitram » Thu Sep 20, 2018 6:04 am
My blood tests come back with low-ish iron, and the Dr said to take iron tablets. Last time I did that I ended up with severe constipation :shock: which is something I struggle a bit with at the best of times, particularly when I'm riding a fair bit.
Any suggestions as to get the iron levels up without this side effect ?
Ta
Nitram
Nobody
Re: Best way to boost iron levels
Postby Nobody » Thu Sep 20, 2018 8:51 am
Nitram wrote:My blood tests come back with low-ish iron, and the Dr said to take iron tablets. Last time I did that I ended up with severe constipation :shock: which is something I struggle a bit with at the best of times, particularly when I'm riding a fair bit.
Ta
Nitram
Could you post you iron studies results? Or do you remember what the numbers were? Were any of your red blood cell markers low? The reason I ask is that what the medical industry flags as low can be different to what the science says is low. Higher iron levels carry a higher cancer risk, so it's a good idea to be careful about the level of supplementation.
ValleyForge
Postby ValleyForge » Thu Sep 20, 2018 9:01 am
Ta
Nitram
Definitely. If your blood profile is normal and your iron studies are low normal then no amount of iron supplements will increase the numbers.
If you are iron-deficient then that's a completely different matter.
The bigger issue is what is your end-point? Do you want to have a better test result? :D
Ha ha ha! Cookies on dowels.
Mububban
Postby Mububban » Fri Sep 21, 2018 10:46 am
A friend who is a GP said he always prescribes a mild laxative whenever he prescribes iron tablets, for this exact reason.
ValleyForge
Postby ValleyForge » Fri Sep 21, 2018 12:22 pm
Mububban wrote:A friend who is a GP said he always prescribes a mild laxative whenever he prescribes iron tablets, for this exact reason.
Not necessary if you use the gluconate preparation.
brumby33
Postby brumby33 » Fri Sep 21, 2018 4:42 pm
Eat a lot of steak & mushrooms :)
VWR -2013
Baalzamon
Postby Baalzamon » Fri Sep 21, 2018 6:41 pm
Cook with a cast iron pan. And cook that steak & mushrooms in said cast iron
