Which tyres front & back ??
Mountainbiking central
Postby Newton » Tue Mar 03, 2009 5:48 pm
I have the following tyres, they where supplied fitted on the bike with the maxxis dynomite on the back and the maxxis ignitor on the front, when I look at the tread pattern it should probably be round the other way, the ignitor has chunkier tread - ??
Ignitor
dynomite
Image[/img]
Newton
by Forum Ads » Tue Mar 03, 2009 6:03 pm
Postby Deanj » Tue Mar 03, 2009 6:03 pm
No, keep the ignitor on the front.
Deanj
Postby Kalgrm » Tue Mar 03, 2009 6:11 pm
I agree with Dean. You don't want your front washing out before the rear one slides a little - once the front slides, you're heading for a world of pain.
A finer tread on the rear tyre also helps reduce the rolling resistance to some extent, since that's the one which bears most of your weight.
Graeme
Kalgrm
Postby Newton » Tue Mar 03, 2009 6:13 pm
Thanks, I understand
Newton
Postby Bnej » Tue Mar 03, 2009 8:45 pm
I have a 2.35 Ignitor front and a 2.1 Small Block 8 on the back.
The front is where all your control comes from so load it up with tread & chunky tyre.
Bnej
Postby trailgumby » Tue Mar 03, 2009 9:22 pm
+1. I run an ignitor front and either Larsen TT or Crossmark rear. You do not want the front to wash out before the rear - it hurts. A lot. :x
Return to MTB
