Tubeless got screw in wheel what to do??? Fixed
tim on skin
Postby tim on skin » Mon Jan 24, 2011 11:43 pm
hi a few weeks back I picked this up in my back wheel
That a $0.20 cent coin
Pick that up about 2km's for home got home with it in wheel. Pulled it out, spinned the wheel a few times pumped up but will not hold over 35ish PSI.
It will seal and hold below that fine but is just a bit soft for we.
What should I do/try ????
No Pain No Game Man
HTFU
Uncle Grumpy
Re: Tubeless got screw in wheel what to do???
Postby Uncle Grumpy » Tue Jan 25, 2011 12:00 am
You are very tedious, and grumpy. Stay at home and give advice from your armchair.
- Stonedpirate, June 2010
tim on skin
Postby tim on skin » Tue Jan 25, 2011 12:31 am
Thanks :D
What sort of patch? One from a tube kit?? Or what to use as a boot?
No Pain No Game Man
HTFU
Uncle Grumpy
Postby Uncle Grumpy » Tue Jan 25, 2011 9:26 am
Did you open the link? It has pictures. Really useful pictures. And yes, if you look carefully you'll see they use a regular old tube patch.
You wouldn't need to use a boot with a hole from a screw. Boots are only useful when you have a slash in the tyre. In the case of tubeless, the sealant won't help you there so you'll need to put a tube in. The boot will stop the inflated tube herniating out of the cut in the tyre. You can use a lot of things, snack bar wrapper, 5 dollar note (bit messy when it gets sealant all over it though) or if you're me, you cut a section of sidewall out of a worn out tyre.
A boot is meant to just sit in loose, not be glued in place like a patch.
Grumps
tim on skin
Postby tim on skin » Tue Jan 25, 2011 8:01 pm
Yes i did look at link thanks for that Just was not sure if it was a tube patch or not
No Pain No Game Man
HTFU
Wild Turkey
Postby Wild Turkey » Tue Jan 25, 2011 8:56 pm
Sounds like your screwed?
Gabe
Postby Gabe » Sat Jan 29, 2011 1:19 pm
I cringed every time I read the word "tire"
jimmy87
Postby jimmy87 » Mon Jan 31, 2011 5:34 pm
my rear tubeless tyre randomly goes down when um not using my bike for a week or so!!
Uncle Grumpy
Postby Uncle Grumpy » Mon Jan 31, 2011 10:11 pm
Gabe wrote:I cringed every time I read the word "tire"
Why? It's an American website. That's how they do it.
What annoys me is when local media spells things the American way. Like jail, donuts and color. Eugh...
Grumps
Users browsing this forum: thomagreg
