29er to be or not to be?
Mountainbiking central
Postby OrangeJuiceMan » Mon Oct 31, 2011 10:03 pm
Hi all,
Well i've finally become hooked on mtbing after my visit to Eagle on the Hill here in Adelaide. I have been using my old mtb I have had since i was 14 and with 4 months of uni holidays starting in a couple weeks I thought what a better way to kick them off than to buy a new bike :D . Being a roadie, my knowledge on mountain bikes is very little so I am hoping you guys can lend some advice.
I have been doing a little research and looking into what kind of bike I can get roughly for $1 - 1.5k. I've decided to go with a hard tail although unsure whether to go with a 29er or not. Being a pretty lanky lad (6ft, 63kg) i'm unsure if a 29er would be ideal for me. I have read mixed views on them, varying from giving you a softer ride to not being very ideal for single tracks.
I have had a look at a couple stores and have a found a couple bikes: Orbea - Satelite, about $1100 and also some GT bikes which are 29ers around $1300.
If any of you guys have any recommendations on bikes, or shops in Adelaide which specify in mtb's that would be great.
Thanks,
OJ
p.s. apologies for another 'what bike to buy' thread :P
OrangeJuiceMan
by Forum Ads » Tue Nov 01, 2011 9:08 am
Re: 29er to be or not to be?
Postby zero » Tue Nov 01, 2011 9:08 am
MTBs are generally intended for single tracks. I can't see how people can make claims that a 29er is going to be bad at it. My 26in bike has a long full suspension chassis, and compared to my road bike, turns like a supertanker, but it is still fine on single track, a 29er HT would have the same wheelbase as my full suspension bike.
You are tall enough that toe overlap shouldn't be a problem (unless you have real short arms) - ie there should be no problem riding a 29er.
I don't think there is much point/advantage to a full suspension 29er myself, and thus see no reason to change my bike, but if I was buying a HT or a rigid bike, it would be a 29er for sure. Once the wheel is hard attached to the frame the weight difference has less effect but the size advantage doesn't change.
zero
Postby Mugglechops » Tue Nov 01, 2011 11:03 am
I am with zero. For FS 26in seems to be still ok. Hardtail I would go 29er all the way. I never had issues with my old 29er been hard in singletrack.
I rode a mates XTC 29er on singletrack and it turned fine, much faster than my Reign on the same track.
Mugglechops
Postby Oxford » Tue Nov 01, 2011 11:15 am
I used to have both 29ers and 26ers (duallies and hard tails), though I have never owned a duallie 29er. having ridden both extensively on the same trails under all sorts of conditions etc etc I do think that 29ers are slightly harder on singletrack (I call it wrestling), but in saying that, not by a lot. I have ridden a duallie 29er (on a track I know very well) that I know was brilliantly set up and it was like riding a magic carpet. At your height I would probably go 29er and depending on where you ride stick with a hard tail.
- anonymous
Oxford
Postby OrangeJuiceMan » Tue Nov 01, 2011 9:17 pm
Thanks for the advice guys, I've decided that I will go with a hardtail 29er; just now unsure what bike :P , any recommendations with a budget around $1k - 1.5k?
OrangeJuiceMan
Postby ozdavo » Tue Nov 01, 2011 9:30 pm
Can't speak from personal experience, but the 2012 Trek Cobia looks like a lot of bike for the money!
ozdavo
Postby silentbutdeadly » Wed Nov 02, 2011 8:45 am
For that budget, I'd have a good look at the GT Karakoram 1.0 or 2.0. The 1.0 comes with XT/Deore 10spd components for around $1,400 while the 2.0 has a mix of Deore/Alivio 9spd for $200 less.
My personal choice however would be the 3.0. Whilst it's 8spd, a mix of Alivio/Acera and a Suntour fork (instead of basic Rockshox)...it's the same frame, cockpit & wheels as the others. And just $850. It'll certainly do the job!! Drive the driveline components into the ground and then replace with 10spd Deore group and hyd brakes for less than $400. If you want/need a better fork then a runout RS Reba or Fox F29 (both better than the stock RS XC28 or XC32 forks) can go for less than $400 - an X-Fusion or high spec Suntour is even cheaper.
silentbutdeadly
Postby steve-waters » Fri Nov 04, 2011 3:55 pm
What have Ginat got in the 29er range for that much - they seem to be value plus these days.
Merida also do some good stuff for really good prices not sure about price
Jump on BikeExchange and a do a search and see what comes up for that much money.
You could even get lucky and snare a good second hand bike for that much - I know over budget but by example there was an Anthem X 29 that sold for $1900 bucks on eBay.
But why not just get a custom Ti made by Moots or Baum? (just joking but it seems whenever someone asks about a bike on a budget someone has to suggest something that is four times the budget so thought it could be me this time)
Roadie: BeOne Black, SRAM Force, TWE 50mm full carbon clinchers, Vértebrae ceramic cable housings
MTB: Chin29er, Fox Terralogic, XT, 3T and TWE wheels
ex-MTB now commuter: Cannondale F900 (CAAD 4), Headshok, TWE wheels, XT and Elixr CR
steve-waters
Postby silentbutdeadly » Mon Nov 07, 2011 10:20 am
steve-waters wrote:What have Ginat got in the 29er range for that much - they seem to be value plus these days.
They've got the Talon for around $1,200 and I think the base XTC can be had for close to $1,500...
silentbutdeadly
Postby OrangeJuiceMan » Mon Nov 07, 2011 11:57 am
Thanks for the input guys, very helpful. I've been looking into bike exchange and have narrowed it down to a few. I plan on going to a couple shops later in the week to have a closer look.
This is what I've come down to:
Trek Cobia 29er - $1300 http://www.bikeexchange.com.au/bicycles/trek/29er/cobia-29er/mile-end/sa/100386102
Merida Big Nine - $1400 http://www.bikeexchange.com.au/bicycles/merida/29er/merida-big-nine-500-tfs-500-d/mile-end/sa/102007876
Giant Talon - $1200 http://www.bikeexchange.com.au/bicycles/giant/29er/talon-0-29r/adelaide/sa/100386567
Giant XTC - $1500 http://www.bikeexchange.com.au/bicycles/giant/29er/xtc-29er-2/glenelg/sa/100385998
GT Karakoram 1.0 or maybe the 2.0 - $1500 http://www.bikeexchange.com.au/bicycles/gt/29er/karakoram-1-0/norwood/sa/100280001
OrangeJuiceMan
Postby trailgumby » Mon Nov 07, 2011 12:03 pm
Out of the Giants, go for the XTC. It's a better frame and you won;t be overcapitalising with later component upgrades.
Postby steve-waters » Mon Nov 07, 2011 12:05 pm
For me it would be take the XTC and Merida for a ride and see what you think.
steve-waters
Postby Mugglechops » Mon Nov 07, 2011 5:25 pm
I finally convinced my wife to let me get another 29er.
I am looking at the TREK Superfly AL which I can get for $1800
I took the cheaper one for a ride today and I liked it a lot.
Mugglechops
Postby OrangeJuiceMan » Thu Nov 10, 2011 3:07 pm
Well i've finally been able to narrow it down to two bikes, the Giant XTC and the Trek Cobia. I went into one of my LBS and he said the Trek out specs the merida easily, although its slightly less attractive :P . Now im just stuck on if its worth paying an extra $200 for an xtc or not...
Im no expert on mtb components so if u guys could shed some light on the area that would be great. The cobia comes with sram x5 whilst the xtc is made up of shimano alivio and deore.
OrangeJuiceMan
Postby silentbutdeadly » Thu Nov 10, 2011 7:02 pm
Your LBS is lying to you. The Cobia X5 drivetrain is fine but not way above the Merida's Deore/Deore XT drivetrain. X5 is SRAM's entry level MTB range....Deore is well above entry level in the Shimano range (but admittedly the first 10sp). That said the Cobia fork (Rockshox Recon Silver) has better kudos than the Suntour...but the Suntour is still a very fine fork. Merida has better brakes.
Of the three....the XTC has probably the weakest drivetrain spec. But a fine front end with a tapered headtube and a 15 QR hub. Still not worth the extra $300 unless it is demonstrably better ride.
On specs alone....sorry....but I'd go for the Merida.
silentbutdeadly
Postby lucifuge » Sun Nov 13, 2011 7:58 pm
Hi mate
I've been riding a 26er dually for 3 months or so, and wanted to 29er HT as a backup bike and to mix things up. I managed to score a 2nd hand Trek Rig, which is a single speed (which is my preference). I have to say that the 29er is AMAZING. Climbs like you wouldn't believe and is not that bouncy etc on descends, actually its very quick. So, my first point here is definitely go a 29er, its fantastic. I think my dually is about to become my backup bike!!
My 2nd point is your price point/ bike lists you've come up with. The Trek Cobia is an entry level 29er HT and unfortunately your'e not really going to get a great fork/brakes etc. If I were you and you maximum is $1500 to spend, I would await a 2nd hand Trek X-Caliber or Paragon on EBAY (or equivalent). You should get it for around that price and and they are WAY better than the Cobia. I'm just worried your going want to upgrade fairly soon with something like the Cobia.
OrangeJuiceMan wrote:Well i've finally been able to narrow it down to two bikes, the Giant XTC and the Trek Cobia. I went into one of my LBS and he said the Trek out specs the merida easily, although its slightly less attractive :P . Now im just stuck on if its worth paying an extra $200 for an xtc or not...
lucifuge
Postby OrangeJuiceMan » Sun Nov 13, 2011 8:37 pm
Thanks for the advice mate, yea I have decided to rule out the Cobia took it for a test ride yesterday and wasn't anything flash. I also test rode the Merida and preferred that. Although as you said eBay is the other option and I have been keeping my eye on it to see if there is anything decent, just a matter of waiting, until something pops up :P
I have also been having a look at the GT bikes and they seem to be great value for money compared to what other bikes are on the retail market for that price. So hopefully might go take the karakoram 1.0 or 2.0 for a test ride in the next couple days at the LBS
http://www.gtbicycles.com/aus/2012/bike ... akoram-1-0
OrangeJuiceMan
Postby DarrylH » Wed Nov 16, 2011 12:21 pm
The Giant seems to be the only one with a 15QR front hub and that should stiffen the long front forks considereably. It also has sealed bearing hubs which need nil maintenance, while a couple of others have low level Shimano cup and cone. Swore last time I had them that I would never touch Shimano M475 or lower hubs ever!
DarrylH
Postby trailgumby » Wed Nov 16, 2011 6:52 pm
That would swing it to the Giant for me. 9mm QR forks on 29ers aren't ideal.
Better still would be a Lefty-equipped Cannondale.
Postby steve-waters » Wed Nov 16, 2011 7:33 pm
Yep go the giant
steve-waters
Postby OrangeJuiceMan » Sun Nov 20, 2011 4:31 pm
Well im sorry to disappoint some of you but I went into one of my LBS and was able to strike a deal with GT Karakoram 1.0 for $1200. I decided to go with this not only because of the price but as it was also a bit more unique than your standard giant/trek mtb etc. Im yet to take it on the dirt but it does run beautifully on the bitumen :D I plan on heading out to some trails tomorrow. Considering im still only a noob on mtbing and compared to what i was riding before it is a huge improvement. In time i'll probably invest in some better quality forks and then some wheels, but till then i'll just enjoy it and develop my skills. Appreciated all the advice you guys gave.
p.s. will post some pics eventually on the other thread.
OrangeJuiceMan
Postby Mugglechops » Sun Nov 20, 2011 7:33 pm
Good stuff I was checking out the GT in Sydney a few weeks ago. Have fun with it.
Mugglechops
Postby trailgumby » Sun Nov 20, 2011 8:19 pm
OrangeJuiceMan wrote:p.s. will post some pics eventually on the other thread.
Yair, c'mon, hurry up, pics or it didn't happen ;) :lol:
Postby silentbutdeadly » Mon Nov 21, 2011 7:47 am
Well done, sir. Now go ride!
silentbutdeadly
Postby bardynt » Mon Nov 21, 2011 2:39 pm
hey
same as that guy looking at different models same as him
is talon 0 for 29 for 1100 better to get or is xtc 26 1500 wheels better to get
i had offer of getting xt ice cool shimano brakes and rotors for 300
also what do people think about the treak 6000 its like 1200
bardynt
Return to MTB
