2011 GT Avalanche
Peat
2011 GT Avalanche
Postby Peat » Sat Aug 11, 2012 2:28 pm
I have a 2011 GT Avalnche frame and was wondering if anybody knows the seat post size and also the seat post clamp size?
JustJames
Re: 2011 GT Avalanche
Postby JustJames » Sat Aug 11, 2012 5:31 pm
Likely to be the same as the 2008 unless anybody knows otherwise:
http://www.bikeradar.com/forums/viewtop ... p=17245420
My bike blog. Long on rumination, rambling and opinion. Why let facts ruin everything?
Mugglechops
Postby Mugglechops » Sat Aug 11, 2012 5:58 pm
Pull out your seatpost and it should be on there.
The clamp may also have it on the inside.
Peat
Postby Peat » Sat Aug 11, 2012 8:17 pm
Mugglechops wrote:Pull out your seatpost and it should be on there.
Would do that If I could.....building a bike from a brand new 2011 frame...no parts came with frame!
Peat
Postby Peat » Sat Aug 11, 2012 8:23 pm
JustJames wrote:Likely to be the same as the 2008 unless anybody knows otherwise:
Thanks for that but....not the correct size. I ride a 2004 gt and that has the same size as the 08. I know that won't fit the 11 frame.
thanks
pete
mitzikatzi
Postby mitzikatzi » Sat Aug 11, 2012 9:15 pm
Mugglechops
Postby Mugglechops » Sun Aug 12, 2012 12:28 pm
Oops my bad. Have you tried ringing a GT dealer?
Shifter
Postby Shifter » Tue Aug 14, 2012 11:09 am
'12 models are 30.9mm
Source:
http://www.gtbicycles.com/aus/2012/bikes/mountain/trail/2012-avalanche-1-0
Presume '11 would be the same as it'd a fairly standard seatpost size for a trail bike these days.
2017 Norco Optic C9.2
2010 Malvern Star Oppy A4
Shifter
Postby Shifter » Tue Aug 14, 2012 5:58 pm
Had a further sniff around and the description from the GT catalogue is the same for both years, except '11 omits the diameter.
