Skewer/Dropout Question
mattwilkinson
Postby mattwilkinson » Sun Aug 11, 2013 7:22 pm
Probably a massively noob questions
I am looking at getting some UST wheels for my Giant Anthem X2 2012.
Basically I understand I need a 15mm front wheel, Or one that can be converted to 15mm.
But I'm unsure of my rear wheels skewer. Is it 9mm? is it 12mm?
Will my frame only fit the specific skewer size, or are rear dropouts compatible with all skewer sizes?
Re: Skewer/Dropout Question
Postby Duck! » Sun Aug 11, 2013 7:52 pm
Your rear is a 135x10mm quick release.
Aside from a conventional Q/R, the only axle format that will fit is a 10mm bolt-up.
mattwilkinson
Postby mattwilkinson » Mon Aug 12, 2013 5:31 pm
thanks for that, So when buying rear wheels is there anything I need to look out for?
Does it have to be a 10mm skewer? Are they all generally this size?
Postby Mulger bill » Mon Aug 12, 2013 7:07 pm
Standard MTB rear end Matt, if an ad doesn't mention a different type then that's what it'll be.
Shaun
Postby Duck! » Tue Aug 13, 2013 1:33 am
mattwilkinson wrote:thanks for that, So when buying rear wheels is there anything I need to look out for?
The axle is 10mm. The skewer is considerably thinner, 'cos it goes through the guts of the axle.
Postby trailgumby » Tue Aug 13, 2013 7:56 am
Unless it mentions the alternate 142x12 Syntace standard it will be 135×10 QR.
silentbutdeadly
Postby silentbutdeadly » Tue Aug 13, 2013 11:02 am
trailgumby wrote:Unless it mentions the alternate 142x12 Syntace standard it will be 135×10 QR.
Correct...though Giant have now changed all their Anthem/XTC range across to the 142x12 'standard' in the rear end for 2014.
Postby Duck! » Tue Aug 13, 2013 1:43 pm
Not exactly correct. The new 27.5" frames are convertible, but the 29er frames, which are all carried over from last year remaim exclusively 135x10.
silentbutdeadly
Postby silentbutdeadly » Tue Aug 13, 2013 3:42 pm
Missed that...oh well 29ers are Old Hat anyway, eh? ;)
