MTB trails close to stations in Melbourne
tekapo
Postby tekapo » Sun Oct 06, 2013 7:23 pm
Any suggestions for trails that starts near train stations in Melbourne? i.e. don't have a car.
su-pista
Re: MTB trails close to stations in Melbourne
Postby su-pista » Sun Oct 06, 2013 9:08 pm
Heidelberg, access from base of Burgundy St. Eltham, to Westerfolds park!
Sent from my Nexus 4 using Tapatalk 2
clackers
Postby clackers » Mon Oct 07, 2013 12:07 am
From Hurstbridge you can head to Smith's Gulley and Kinglake. If you're fit you can get to Lysterfield from Belgrave, as well as the trails around the Thousand Steps.
clackers
Postby clackers » Mon Oct 07, 2013 12:09 am
tekapo wrote:Any suggestions for trails that starts near train stations in Melbourne? i.e. don't have a car.
su-pista wrote:Heidelberg, access from base of Burgundy St. Eltham, to Westerfolds park!
And fron there on to Candlebark Park.
Mugglechops
Postby Mugglechops » Mon Oct 07, 2013 10:23 am
Little River is pretty close to the You Yangs
Postby Duck! » Mon Oct 07, 2013 1:45 pm
clackers wrote:From Hurstbridge you can head to Smith's Gulley and Kinglake. If you're fit you can get to Lysterfield from Belgrave, as well as the trails around the Thousand Steps.
Hallam is closer to Lysterfield.
tekapo
Postby tekapo » Mon Oct 07, 2013 4:44 pm
clackers wrote: Lysterfield from Belgrave, as well as the trails around the Thousand Steps.
Thanks, looks good from the maps. How hilly is the terrain, I will probably try ride Belgrave to Dandenong station via Lysterfield. Looks to be about 15-20ks.
ProCelebrityGolf
Postby ProCelebrityGolf » Mon Oct 07, 2013 9:49 pm
not exactly trails but great fun on a mountain bike - check out the route maps on http://melbournegravelgrinders.blogspot.com.au/
clackers
Postby clackers » Thu Oct 10, 2013 12:12 pm
I've never ridden it, but others have and there are apparently off road bits. The drive is up and down, mostly down.
Hallam is closer, as Duck points out, but more time spent with traffic I suspect, and a nice climb up North Hallam Road. :)
antigee
Location: just off the Yarra Trail but not lurking in the bushes
Postby antigee » Tue Oct 22, 2013 10:26 am
as you say not MTB but that's a great link for me as I ride my CX on gravel as much as ride MTB and there's some nice routes there THANKS :P
Blakeylonger
Postby Blakeylonger » Tue Oct 22, 2013 11:32 am
Join us this Saturday then!
MGG returns after a long hiatus with Scooter's Century.
Stay tuned for the Night Grinder!
nezumi
Postby nezumi » Wed Oct 23, 2013 10:18 am
Recommended tyres/pressure for gravel grinding?
I currently have my CX commuter shod with Schwalbe Marathon Plus 28s, but I also have the folding Conti CX 35s that came on the bike.
2014 Merida Cyclo Cross 4
2015 Merida Scultura 5000
Blakeylonger
Postby Blakeylonger » Wed Oct 23, 2013 11:11 am
First, burn the marathon plus'. Heavy & dead.
Second, high enough not to pinch flat, which depends on tyre width, your weight and riding style, personally I'm around the 30-35psi mark. Slicks are usually fine unless it's muddy. The routes are mostly dirt/gravel roads after all.
Contis would be the best of your options.
nezumi
Postby nezumi » Wed Oct 23, 2013 11:57 am
Blakeylonger wrote:First, burn the marathon plus'. Heavy & dead.
Hey, it's a commuter - I need the puncture protection :P
I'm at about 85 Kgs at the moment.
I'm still new to riding with any form of slick tyre, so I am a bit wary of a smooth tyre on gravel - I keep thinking the punctures will happen all the time.
I run the SMPs at around 80 PSI for the commute.
Blakeylonger
Postby Blakeylonger » Wed Oct 23, 2013 12:35 pm
nezumi wrote:I run the SMPs at around 80 PSI for the commute.
Off topic tyrechat:
I commute on Ultremo ZX 28mm tyres at ~50-60psi or Grand Bois Hetres 650bx42mm, ~30-40psi (~60kg).
No puncture belts, no liners, just very supple carcasses and high quality rubber.
No flats either. ;)
If you want a nicer slick around the 30mm mark, try the 700x35mm Kojak (kevlar), or Resist Nomad (wire, cheap, 28/35/45mm). I also love Challenge Parigi-Roubaix (or the new L'Eroica) & Grand Bois Cerf (26/30/32mm), but they're a bit more $.
The Durano (not the plus!) can be had in 700x28, they're less than half the weight of your bricks, will roll much better and have a bit more protection than the ultremo. But if you must use Marathon's, at least get the 35mm Racer version.
shakes
Postby shakes » Thu Jan 23, 2014 10:06 pm
From belgrave you drop straight into 'birds land' and onto gravel. an easy warm up before you hit the trails.
On google maps it doesnt look like it from Hallam>?
