X0 Type 2 vs X9 Type 2
Squigs
Postby Squigs » Sun Nov 24, 2013 3:15 pm
Currently I have a Sram X0 2x10 drivetrain on my MTB. I am looking to switch to 1x10 to save a bit of weight and make the bike more simplistic. I am planning to purchase a Sram Type 2 Rear Derailleur and a Wolf Tooth front chainring.
My question is is there a difference in shifting performance between a Sram X0 type 2 and an X9 Type 2 derailleur or is it just weight?
The X9 is about $100 cheaper than the X0 and is only 15g heavier. Am I missing something here or is the X9 just alot better deal?
mitzikatzi
Re: X0 Type 2 vs X9 Type 2
Postby mitzikatzi » Sun Nov 24, 2013 3:27 pm
Rear Derailleurs have a habit of breaking (collecting sticks). Never buy one if you can't afford a replacement.
ozdavo
Postby ozdavo » Sun Nov 24, 2013 3:29 pm
IMO the shifter has more to do with shift quality than the RD.
Sent from my iThingy using Tapatalk
march83
Postby march83 » Sun Nov 24, 2013 3:33 pm
i had come to the decision that 15g was less critical to me than $100 and i have spec'd x9 on my current build, but i have no performance data to back up my position, sorry :D
Squigs
Postby Squigs » Sun Nov 24, 2013 3:49 pm
Or the other option I have is sticking with the current rear derailleur which doesn't have a clutch mechanism, and then buying a chain guide and a MRP Bling Ring. This will then cost about the same price because the a new derailleur costs as much as a good cross country chain guide.
ozdavo
Postby ozdavo » Sun Nov 24, 2013 10:42 pm
Lots of anecdotal evidence the Wide narrow chainring does a lot more than a clutched rear mech. Run your current RD until you have cause to change it.
Postby toolonglegs » Sun Nov 24, 2013 10:48 pm
XX1 will be out in a cheaper version soon surely... maybe worth the "weight" :P
Blakeylonger
Postby Blakeylonger » Mon Nov 25, 2013 9:29 am
ozdavo wrote:Lots of anecdotal evidence the Wide narrow chainring does a lot more than a clutched rear mech. Run your current RD until you have cause to change it.
I haven't used a wide/narrow ring but I have a clutched x9 and a non clutched x0, chainslap is a thing of the past with the type 2. It does wonders for retention compared to an non clutched mech.
In comparison the x0 has lighter weight parts (hollow bolts etc). I'd save the money and get an x7t2 or x9t2.
Postby trailgumby » Tue Nov 26, 2013 7:23 am
X0 has a ballraced upper pulley. Noticeably lower friction over the bushed unit.
Alternatively for thirty bucks you might be able to fit a pair of Rollerboys but check first ... x9 used to use a bushing with off center bolt holes with 9 speed, which sucked... Rollerboys not compatible.
X01 still needs a new rear freewheel - may not be available for your wheelset.
Sent from my android thingy using Crapatalk
silentbutdeadly
Postby silentbutdeadly » Tue Nov 26, 2013 11:12 am
...and I can vouch for it. At least in terms of pure XC. But it does work even better (quieter) with a clutched derailleur.
But in terms of the original question, I'd pick an X9 RD - in fact I did. The other bike (dually XC) has a Zee.
jaffaman
Postby jaffaman » Mon Dec 16, 2013 10:10 pm
I have X0 shifters with X0 FD, X9 cranks and X9 clutched RD. It seemed to me the best compromise of cost and performance. It all works great and was a little cheaper than a whole X0 set.
Postby ldrcycles » Mon Dec 16, 2013 10:18 pm
ozdavo wrote:IMO the shifter has more to do with shift quality than the RD.
+1
Postby Duck! » Tue Dec 17, 2013 10:34 pm
trailgumby wrote:X01 still needs a new rear freewheel - may not be available for your wheelset.
Shimano is apparently the only major wheel manufacturer to not offer the X-drive freewheel body required for XX1/X01 cassettes.
