Maxxis Tread Lite - any experience with these?
- RonK
Postby RonK » Wed May 06, 2015 10:18 am
The weight is reasonable for a 29er tyre. Any comments on speed and durability?
Or are other tyres you would recommend? Also considering Schwalbe ThunderBurt and Racing Ralph, perhaps Conti Race King.
- jbchybridrider
Re: Maxxis Tread Lite - any experience with these?
Postby jbchybridrider » Wed May 06, 2015 11:36 am
- Duck!
Postby Duck! » Wed May 06, 2015 1:27 pm
I'm not familiar with the Tread Lites, but my regular MTB tyres are Maxxis Crossmarks. Good general purpose, but wet/muddy is their weak point.
Postby Snuffy » Thu May 07, 2015 8:16 am
The thing I like about the Crossmark on gravel is that it transitions well as you tip the bike over in a corner and it doesn't tend to suddenly let go.
RaRas are fine too, as long as you buy the right variant. As Ducky points out, some of their lighter variants are made of cheese. Have ridden one of the... err.. Evo SS TR (I think?) variants all over Buller and the Youies and it's been fine.
- RonK
Postby RonK » Thu May 07, 2015 11:54 am
I was thinking RaRas, actually could probably even go the ThunderBurts if as you say the right variant is chosen. I've read a horror story about them but I think it was the lightweight variant.Snuffy wrote:RaRas are fine too, as long as you buy the right variant. As Ducky points out, some of their lighter variants are made of cheese. Have ridden one of the... err.. Evo SS TR (I think?) variants all over Buller and the Youies and it's been fine.
- RonK
Postby RonK » Thu May 07, 2015 6:44 pm
Interesting that while researching this question I discovered the web site Bicycle Rolling Resistance. Their review of the Small Block 8 is not encouraging.jbchybridrider wrote:Check out the Kenda Small Block 8 tyres.
- silentbutdeadly
Postby silentbutdeadly » Sun May 10, 2015 8:53 am
I do have RaRa's on the CX bike...good for single track but only OK for rolling on road and gravel unless pumped up to silly pressures.
Personally I'd look more to a fat gravel touring tyre rather than thin 29er tyre if you aren't doing singletrack.
- RonK
Postby RonK » Sun May 10, 2015 9:49 am
Refuse to consider heavy touring tyres - I'm simply not having them.
Thunder Burt is still looking the least compromising combination of weight, grip and rolling resistance in a tubeless tyre.
- silentbutdeadly
Postby silentbutdeadly » Tue May 12, 2015 9:36 am
My thoughts too. Just ordered one yesterday because it seems the carcass of the rear tyre on the duallie has seemingly fractured after four years (even though the tread is barely worn) and it squirms. We'll see how it goes.RonK wrote:Thunder Burt is still looking the least compromising combination of weight, grip and rolling resistance in a tubeless tyre.
Another option is the Rubena Zephyros which might seem large at 2.25 claimed but seems to be running smaller in width in the real world...closer to 2 seems to be the call. Well priced too http://shop.rubena.com.au/product/zefyr ... 29-x-2-25/" onclick="window.open(this.href);return false;
- RonK
Postby RonK » Tue May 12, 2015 10:36 am
Another that looks good is the Conti Race King.
- silentbutdeadly
Postby silentbutdeadly » Tue May 12, 2015 10:46 am
They are a fast rolling tyre though I'd have thought the Speed King RS might be more up your alley... http://www.pursuitsports.com.au/shop/pr ... 400&page=1" onclick="window.open(this.href);return false; It is worth remembering that Continental tend towards an actual width on their carcasses...so 2.2 might be a bit fat for you.RonK wrote:Another that looks good is the Conti Race King.
- RonK
Postby RonK » Tue May 12, 2015 12:36 pm
- silentbutdeadly
Postby silentbutdeadly » Tue May 12, 2015 7:45 pm
- RonK
Postby RonK » Wed May 13, 2015 4:46 pm
Yeah, I will be interested to know how it goes too.silentbutdeadly wrote:My thoughts too. Just ordered one yesterday because it seems the carcass of the rear tyre on the duallie has seemingly fractured after four years (even though the tread is barely worn) and it squirms. We'll see how it goes.RonK wrote:Thunder Burt is still looking the least compromising combination of weight, grip and rolling resistance in a tubeless tyre.
- trailgumby
Postby trailgumby » Wed May 13, 2015 10:42 pm
No, you don't see much of Kenda any more.'They're heavy too.RonK wrote:Interesting that while researching this question I discovered the web site Bicycle Rolling Resistance. Their review of the Small Block 8 is not encouraging.jbchybridrider wrote:Check out the Kenda Small Block 8 tyres.
Regarding Rubena, I've been running the Kratos and Scylla combo for about ten months as my XC 29er training wheelset tyre. They rode like a much bigger tyre and their grip was confidence inspiring. Wear has been pretty darn good. They've been reasonably tough, but the Scylla's sidewall developed a small tear right down by the bead a couple of weeks ago where the rubber parted from around the kevlar bead, so it's been replaced. I can confirm that Kevlar is indeed yellow.
While the grip is good, it is my feeling that rolling resistance isn't quite as good as the Schwalbe RoRo/RaRa combo I have on my race wheelset.
I'm interested to have a look at the Conti range for my next 29er purchase.
Postby Espresso_ » Mon May 25, 2015 11:47 am
I'm in the process of building a bit of a ghetto version of your bike - a steel rigid dirt road tourer - within similar intentions in mind (multi-day bikepacking on hard dirt, gravel with a bit of paved roads too). Like you, I suspect, my bike is likely to also see a bit of more gnarly off-road from time to time, because you just never know what's out there or how the weather affects the trail. Mine's a 26" version, though, built from cheapy bits.
I had been looking at wider 2.25 to 2.35 tyres as I need a bit of extra cushioning given it's all rigid.
I'm watching this thread with interest. One other suggestion that's been recommended by my LBS is a Schwalbe Marathon Extreme 2.35 (now discontinued,I believe).
E
- RonK
Postby RonK » Mon May 25, 2015 12:49 pm
Racing Ralph and Race King remain the front runners for now - I'm leaning toward the Race Kings. But if I get good feedback about Thunder Burt they're still in the mix.
Whatever the choice, they just have to be capable of lasting for about 1200kms of gravel roads with a little asphalt and some single track thrown in - doesn't seem a big ask.
Still a way to go before committing I think.
Postby Espresso_ » Mon May 25, 2015 1:14 pm
The Marathon Extreme is 660g in 26x2.35 guise so it's not super heavy, at least compared to other Marathons.RonK wrote:None of the Marathons will make the cut - they are far too heavy in the large sizes. And I want to go tubeless.
I want tubeless too. Are Marathons all not tubeless compatible? I'm running tubeless on another set of tyres that do not state tubeless compatibility so I hadn't even bothered to check.
I've currently got Nobby Nics so they're an option for me too.
Have you ruled out balloon slicks like the Super Moto, Big Ben etc for lack of gravel grip?
E
- RonK
Postby RonK » Mon May 25, 2015 1:27 pm
The balloon tyres are heavy and not tubeless compatible, and have poor edge grip.
With Rara's and TBurt you have to make sure you get the right carcass selection too. Gotta be Snakeskin, Tubeless Ready.
- silentbutdeadly
Postby silentbutdeadly » Mon May 25, 2015 2:13 pm
My only caveat about these tyres and a touring load is...I'm not convinced the carcass is quite what it needed. Like my Vredestein Spotted Cat tyre, the sidewall is not much thicker than tissue paper despite being Snakeskin and tubeless ready. Great for racing but touring?
I still can't help thinking that a slightly heavier carcassed tubeless tyre like the Vittoria TNT range (eg AKA) might be better. I've run one of these now for nearly 4 years and the only thing that has now killed it is running low pressures (around 30 psi) during XC racing which makes the sidewalls really squirm during braking and cornering...so the sidewalls has 'fractured' and cornering on hard surfaces makes it feel flat. If I run the thing at 45 it'd still be very very much alive...though I'd probably have hurt myself!
Espresso, don't be tempted by the fat tyres unless you plan on using comparatively fat rims. On a gravel road, they have the rolling resistance of a dead cow and they squirm like dog poo under bare feet. The only way to counteract these tendencies is to inflate them to stupid levels...at which point, wear and handling characteristics become untenable.
- RonK
Postby RonK » Mon May 25, 2015 2:40 pm
Such eloquence!silentbutdeadly wrote:On a gravel road, they have the rolling resistance of a dead cow and they squirm like dog poo under bare feet.
I've been seeing more and more favourable reviews of the TBurt.
Not concerned about the sidewalls - been running Supremes with Liteskin sidewalls for the last three tours without any problems even on the gravel. Next trip will be bikepacking so load will be lighter, and Snakeskin sidewalls even tougher.
- Marx
Postby Marx » Mon May 25, 2015 3:09 pm
http://www.mtbr.com/cat/tires-and-wheel ... 51crx.aspx" onclick="window.open(this.href);return false;
Thinking of running these (in a 2.0) next on my 'everything else bike' which is a hardtail 29er with rack & guards.
: One for commuters too?
If anyone has any reason these should not be used?
A bike and a place to ride.
- RonK
Postby RonK » Mon May 25, 2015 3:23 pm
But this discussion is about identifying fast and light tyres for backroads bikepacking.
At 680gm for a 622x2.1 they are too heavy for mine.
Postby Espresso_ » Mon May 25, 2015 6:08 pm
OK, sounds like good advice. So gravel is best tackled with thinner (say, 2.1) tyres?silentbutdeadly wrote:Espresso, don't be tempted by the fat tyres unless you plan on using comparatively fat rims. On a gravel road, they have the rolling resistance of a dead cow and they squirm like dog poo under bare feet. The only way to counteract these tendencies is to inflate them to stupid levels...at which point, wear and handling characteristics become untenable.
But what does "fat" mean in this context? I have 28mm wide rims, I think - so not really fat at all. They hold my current 2.25's fine, and once held a 2.35 fine too.
PS. I've also been warned off Thunder Burt's by my LBS because they say theyre performance tyres and not really up to what I was looking to do with them. It's a moot point for me anyway - they don't come in 26"
E
- RonK
Postby RonK » Mon May 25, 2015 6:31 pm
Not at concerned what the lbs thinks. Quite obviously TBurts are lightweight performance tyres. That is why we are considering them. And as I've already noted, they are offered with three different carcase constructions, the lightweight carcases are not under consideration.Espresso_ wrote:OK, sounds like good advice. So gravel is best tackled with thinner (say, 2.1) tyres?silentbutdeadly wrote:Espresso, don't be tempted by the fat tyres unless you plan on using comparatively fat rims. On a gravel road, they have the rolling resistance of a dead cow and they squirm like dog poo under bare feet. The only way to counteract these tendencies is to inflate them to stupid levels...at which point, wear and handling characteristics become untenable.
I'll be going for the 622 x 2.1 size.
