Rock Shox SID RL - PushLoc delete
dmwill
Postby dmwill » Wed Feb 01, 2017 2:53 pm
I have a set of RockShox SID RLs (on a 2014 XTC Adv 29er).
Looking to remove the PushLoc remote for a cleaner bar setup. Prefer to have simple knob on the fork.
How easy would this be and what cartridge/insert would I need? I spent last night googling and looking at parts lists, but there is no definitive answer. (I've serviced and rebuilt RS forks before, so pretty comfortable with DIY).
Re: Rock Shox SID RL - PushLoc delete
Postby Duck! » Thu Feb 02, 2017 2:02 pm
You need to replace the compression damper. The remote type has a return spring on the shaft so it opens when the lock is released. Non-remote ("Turnkey") dampers have no spring. It's not difficult to swap dampers, just unscrew the old one & drop the new one in.
dmwill
Postby dmwill » Thu Feb 02, 2017 3:22 pm
Thanks Duck.
Managed to narrow it down to this part number: 11.4015.544.270
In the meantime I've just removed the remote and adjusted (and trimmed) the cable so it's technically jammed open.
