Seat post slip
BJMcC
Seat post slip
Postby BJMcC » Fri Jan 26, 2018 4:15 pm
Hi, My seat post is slipping quite a bit. How do I tell if I have the right sized seat post for the frame? I bought the bike second hand, so I'm not sure if it's the original seat post. It seems to be reasonably tight when I remove the quick release clamp and move it up and down. I have the clamp very tight and it still drops after a ride.
Re: Seat post slip
Postby find_bruce » Fri Jan 26, 2018 5:17 pm
Now is a good time to check for cracks around the seat post clamp.
An easy fix is a drink can shim around the post
Bentnose
Re: Seat post slip
Postby Bentnose » Sat Jan 27, 2018 8:57 am
What bike is it, someone might know what size it is meant to be? Is it a carbon post? I had an issue on my MTB that was alu post and steel bike, a drink cam shim fixed that but it ended up cold welding itself to the frame because I left it too long between greasings. My road bike used to drop its carbon post in the carbon frame 10-15cm a ride, I ended up buying a new alu post and a clamp that was .2mm smaller than the one that came with it (it was an odd size), that was the only thing that could fix it.
No signature
mikgit
Re: Seat post slip
Postby mikgit » Sat Jan 27, 2018 2:26 pm
yeah what frame, what seatpost. I had a Manitou frame where the seatpost (Manitou/Ringle) would slip no matter what.
My current FS bike, carbon frame aluminium post was fine with the stock seatclamp, but when I switched to a QR clamp would slip a lot, carbon past helped a lot but it would still slip like 1-2 cm over a ride.
Look 675 Pro Team, Cervelo R3, GT Xizang, GT Zaskar, Scott Spark 710, Yeti ARC, DiamondBack Apex
Re: Seat post slip
Postby trailgumby » Sat Jan 27, 2018 9:52 pm
1-2cm during a ride would blow up my knees. I use carbon paste. No problems with slippage.
I only use a QR collar on the alloy-framed bike I share with my son. It's a Surly collar - quite a long lever and excellent locking geometry. Bolt-up collar on all the other frames, tightened to recommended torque.
BJMcC
Re: Seat post slip
Postby BJMcC » Sun Jan 28, 2018 11:48 am
Thanks for the responses. Its a Scott racing comp AL Evo 2, however there are no markings on the aluminium seat post. I just put in a drink can shim and I'll see how that goes. I'll be mindful not to let it coldweld itself to the frame. Failing that, I think the carbon paste is the next option.
mikgit
Re: Seat post slip
Postby mikgit » Mon Jan 29, 2018 7:51 pm
trailgumby wrote:1-2cm during a ride would blow up my knees. I use carbon paste. No problems with slippage.
Ha yeah doesn't blow me up on say a 1 hour ride, but I notice it. Usually the last 10 or so km of a ride is mostly DH so not such an issue. Went back to a bolt up clamp when I put on a dropper.
