suzie wrote:
I like the idea of the comfort of a cruiser (one with gears) however having never actually ridden one other than a quick test drive in a flat car park,I am worried about the following and wondering if anyone can offer advice:
Are they generally heavier than mountain bikes? I need to lift it up onto the bike rack at work.
Will it be much harder going up hills and slower going down hills?
I am prepared to spend up to $750. I like the idea of the Electra Townie despite being outside my budget - does anyone have experience with these or can anyone suggest something similar?
The Townie is a completely different riding position to an MTB, as you have no doubt experienced. They are designed for "Cruising", not for Hill Climbing. The Townie comes in all sorts of variations, from Single Speed up to a 24-Speed with racks etc all standard. I have a Townie 21D (as does my wife), which I use exclusively for "Cruising" or going up the local shops.
To answer your questions:
1) Are they heavier than an MTB? Well, "it depends". Personally, I don't think there is a huge difference, but the Townie has a longer wheelbase and this makes it a larger bike. What sort of bike rack are you having to lift onto? I don't have any issues with our Townies, but we also use the kick stands most of the time (swapped the standard issue ones for twin-leg ones instead)
2) Are they harder going up hills? Yes and no. Yes, because the riding position is relaxed on a Townie, you don't have the same leverage on the pedals. You can't stand up and pedal on a Townie (well, you can try, but it is not very stable!). I have climbed some pretty nasty hills on my Townie, with my son sitting in his BoBike seat on the handlebars. I was spinning like crazy in a ridiculous low gear that I would never use on an MTB (22x34) and doing about 7km/h, but I got up the hill
As for the downhills, you won'tbe breaking any speed records, but I have personally done close to 50km/h without concern. Just replace the oem brake pads before you do it! You'd probably go faster if the stock 2 inch wide tyres were slimmed down a bit.
