Cycling apparel for women
Got Questions? Need advice?
Postby Aria2 » Thu Jan 26, 2012 7:39 pm
Can anyone recommend a cycling apparel manufacturer that makes larger sizes? I find it a bit like gym clothes. They think if you are exercising you must be no more than a size 12. Managed to find a good pair of netti shorts in a size 18 (normally a 14 to 16 max) but the jerseys are all too small. :D :)
Aria2
by Forum Ads » Fri Jan 27, 2012 9:21 am
Re: Cycling apparel for women
Postby wallaby » Fri Jan 27, 2012 9:21 am
Have you considered looking for mens jerseys?? They would definately make them in those sizes. I myself have only ever bought cheap jerseys online (as I am just starting out). Usually they post the sizing/measurements and they are generally quite accurate.
Kym
2012 Giant Avail 1 (black and white, not pink!)
wallaby
Postby RonK » Fri Jan 27, 2012 9:46 am
US sites are your best bet - they are more likely to stock larger sizes.
Try Bicyclinghub.com, they have a good range and reasonable prices and shipping charges.
Another site is teamestrogen.com, but I haven't had any dealings with them.
Postby Mel.b » Sun Jan 29, 2012 6:36 pm
I wear a size 20 - 22 normally and have found www.aerotechdesigns.com in the US great for larger sized cycling stuff. I have padded shorts, a jersey and leggins all from them. Check out both the women's and the plus size section as there is a bigger range in the women's section, and a lot of it still goes to larger sizes but is not listed in the plus section.
Mel.b
Postby summercyclist » Thu Feb 16, 2012 5:43 pm
These are very good tips. Will definitely look into them, since I was facing the same problem and have been looking everywhere. Thanks a lot :)
summercyclist
Postby goneriding » Thu Feb 16, 2012 8:34 pm
Try this site http://bellavelo.com.au/. They have a good range of sizes and their gear is good quality.
goneriding
Return to Women's Cycling
cron
