SRAM goes electric with E-matic e-bike power system
Positive discussion on ebikes and pedal assist bicycles
Postby Aushiker » Sun Mar 18, 2012 1:51 pm
It’s taken SRAM a while to get into the e-bike game, and what they’ve come up with is, essentially, a 135mm OLD hub and battery pack combo. The E-matic electric assist system, to give it its full title, will fit on to any normal frame that has rack mounts, and runs any normal single-speed drivetrain (the company recommends a 44/17 gear ratio, but it’s really up to you). Then the SRAM-designed rack and battery pack unit attaches to the bike like any ordinary rack, and the battery connects to a hub via a single wire. And that’s it. No gears or handlebar controls; no unsightly bulbous ‘design’ bits on the frame; nothing.
The hub houses a processor, automatic transmission and motor, and power delivery is controlled by a ’sophisticated algorithm’. Which means, claims the company, that power is delivered intelligently, when you need it, and doesn’t take away from the bike-y feel of the bike. It also tails off the power gently, to prevent you hitting the wall when the maximum assisted speed is reached. In Europe, that’s 25km/h; in the States, that’s 20mph. Who likes hitting the wall at 25km/h? And who knew that Americans were allowed to go faster?
There are three battery pack options, weighing between 1 and 1.5kg, which give a claimed 60-95km maximum range - the largest pack being the top end. And you can run either rim or disc brakes.
Source: Road.cc
This looks actually interesting to me for summer commuting. Pity will it is not going to be an aftermarket fit at this stage.
by Forum Ads » Sun Mar 18, 2012 2:21 pm
Re: SRAM goes electric with E-matic e-bike power system
Postby trailgumby » Sun Mar 18, 2012 2:21 pm
Traitors! :evil:
:wink:
Postby MattyK » Thu Mar 22, 2012 3:13 pm
I assume there's some sort of torque sensing pedelec system going on inside the hub? Otherwise it's unclear how you activate it.
Maybe it's just me, but I prefer the battery in the main triangle for aesthetics, weight distribution, and the ability to choose my own rack (eg Topeak MTX)
MattyK
Postby cachexian » Wed Apr 04, 2012 9:18 pm
MattyK wrote:I assume there's some sort of torque sensing pedelec system going on inside the hub? Otherwise it's unclear how you activate it.
Agreed. I mounted my battery in the triangle on a frame that I built myself for my latest bike build. Much better weight distribution. It's nearly ready for pictures. still need to pretty it up a bit...
Scott Sub 40 with 200W, 36v Ezee geared front hub motor
and...
Trek Madonne 3.1 driven by left leg and right leg
cachexian
Return to Electric Bicycles
