Motor cuts out issue
Positive discussion on ebikes and pedal assist bicycles
Postby hotdiggity » Sun Apr 22, 2012 9:55 am
With the battery charged and the system switched on, the battery level indicator on the handlebars displays all three lights - min, med and max. After applying the throttle grip the motor engages but cuts out after only 1 or 2 seconds (varies). The battery indicator glows and fades on "min". The system then needs to be switched off and on again to get the same result. When the back wheel is lifted off the ground and the throttle applied, ie. without a load on the bicycle, the motor doesn't cut out at all but keeps spinning with all three battery lights on. Any ideas out there please as to how to solve this issue?
hotdiggity
by Forum Ads » Sun Apr 22, 2012 12:42 pm
Re: Motor cuts out issue
Postby KenGS » Sun Apr 22, 2012 12:42 pm
Get a new battery?
--Ken
Helmets! Bells! Rego!
KenGS
Postby Joeblake » Tue Apr 24, 2012 1:50 pm
Yes, sounds very much like a battery issue. Cheapest option is to see if you can borrow a replacement battery for a couple of minutes and try the same thing. If it runs okay, there's the likely suspect.
I guess the next questions are (a) how old is the battery, (b) what type eg lead-acid NiMH, NiCad, (c) how often/much do you ride the bike?
Joe
To acquire immunity to eloquence is of the utmost importance to the citizens of a democracy
Bertrand Russell
Many people feel their lifestyle has a high price, but they're quite cool with that .. as long as somebody ELSE pays the price.
Joeblake
Postby r2160 » Tue Apr 24, 2012 2:58 pm
A battery can show good voltage, but have no capacity (current) to use once a load is applied to the motor.
the best thing to do is check that it is charging correctly first, and if this is OK, have the battery checked
Glenn
"Pain is temporary. It may last a minute, or an hour, or a day, or a year, but eventually it will subside and something else will take its place. If I quit, however, it lasts forever" Lance Armstrong
r2160
Postby nessbike » Wed May 02, 2012 2:32 pm
I concur with other respondees - had a similar problem with a bike recently. Swapping out the battery (after checking all connections and possible brake cutout issues) solved the problem. I suspect it may have been a dud cell as the original battery was new, but difficult to check without stipping the battery down. cheers Alex
nessbike
Postby cachexian » Tue May 08, 2012 6:08 am
Agreed with other responders.
The three lights are a crude measurement of voltage.
Here's what I think is happening:
When you are applying load to the motor (i.e. sitting on the bike) the controller is trying to take a lot of amps from your battery. This is causing the battery voltage to sag. It's sagging below the "low voltage cut off point" of your controller that then switches off to protect the battery.
Get a new battery and all will be well.
C
Scott Sub 40 with 200W, 36v Ezee geared front hub motor
and...
Trek Madonne 3.1 driven by left leg and right leg
cachexian
Postby cachexian » Tue May 08, 2012 6:14 am
Need a battery charger
by hotdiggity » Wed Feb 22, 2012 9:11 pm
Trying to buy on a charger for an unbranded ebike battery. It's a 35 volt battery, most probably Li-ion. I was recommended a 1.5 - 2 amp charger by the local ebike shop, however the chargers online mostly specify amp hours (10 or 12). Any clues?
Is this still the same battery for which you bought the charger? How did you end up charging it? Happy to have a look at it for you if you're in sydney but also you could go to glowworm bikes.
You might be better off having your motor and controller identified and getting a whole new battery and matched charger made up for you. Hyena Industries will make you up a lightweight battery and charger that will not sag under load and will be a better battery than you started with...
C
and...
cachexian
Return to Electric Bicycles
