Shimano release STEPS (again)
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Mon Nov 11, 2013 10:16 pm
I have been awaiting news on the much anticipated Shimano E-Bike system and it has the same name as their original system - STEPS.
The original system was an integrated system but never really took off. I will include the details - it is due out in 2014 for manufacturers so will be a while until it would appear.
SHIMANO ENTERS THE E-BIKE MARKET WITH STEPS
In 2014 SHIMANO will introduce a new groupset dedicated for E-bikes, called STEPS. STEPS will be a totally integrated E-bike groupset. From drive unit to battery, front gear set, cycle computer and chain.
STEPS is developed with the idea of system component design. Which means that every individual component works better when the other STEPS components are also integrated in the groupset. STEPS is a pedelec system which engages when a rider is pedaling and cuts out once 25km/h is reached. The STEPS drive unit has a compact design and with weight of 3.1 kg, it is one of the lightest drive units in the market. The compact and lightweight design improves rider control in all conditions and is easier to handle by a wider range of riders. Talking about range, STEPS has three types of power support modes; eco, normal and high. The preferred mode can be selected by an easy to operate switch. The eco mode has a range up to 120km. Normal mode 100km and the high mode 80km*. The STEPS cycling computer gives feedback about the selected mode, battery life, riding speed, distance, etc.
The STEPS battery has a capacity of 418Wh and it takes four hours to completely charge the battery. There are two position types of batteries. A rear carrier type and a down tube type. The battery life is 1.000 cycles. After 1.000 cycles the battery still charges more than 250Wh.
STEPS has the possibility to integrate with SHIMANO’s Di2 internal hub gears. This integration gives STEPS a number of valuable advantages. First the SHIMANO Di2 internal hub gears maintain shifting performance under high chain tension by reducing motor power while shifting. Besides the shifting performance also the total integration is an important feature. All individual components are designed to work as a flawless system. Another advantage is the possibility to connect STEPS to a PC via SHIMANO’s E-tube* project. E-tube gives quick and easy access to the STEPS system for simple installation and set-up options. For instance changing the function of the buttons on the switch, firmware updates and diagnostic analyses.
Special for the STEPS system, SHIMANO made a reinforced chain dedicated for E-bike usage. It is treated with SIL-TEC* coating and for front single gear only.
SHIMANO’s STEPS components are designed to be ridden all year round. STEPS can be used from 10 degrees Celsius below zero to 50 degrees Celsius.
For advice and service SHIMANO has a strong and proven European wide service network.
Pilot project with BIKE&CO and ZEG
From February to August 2014 SHIMANO will run a pilot project for STEPS with dealer associations BIKE&CO and ZEG in the German market. Both companies will develop E-bikes with the STEPS drive unit which will be sold at their German dealers. Besides the production bikes, both BIKE&CO and ZEG will organize bikes to try (supported by SHIMANO) at their selected dealers where consumers can try the new E-bikes with the STEPS drive unit.
Frank Peiffer, managing director Shimano Europe:”The E-bike market is a new segment for SHIMANO. Our service to the OEM’s, dealers and consumers is key at the introduction of our STEPS system. That is why we chose for a phased approach. The pilot project is a limited quantity in a limited sales channel with a direct service access. If there we gain experience and are convinced the product works, we expand it further to other players in Germany and the rest of Europe.”
eldavo
Re: Shimano release STEPS (again)
Postby eldavo » Mon Nov 11, 2013 11:16 pm
Will be interesting to see if they use the Bosch unit dimensions for existing frame manufacturers, or ignored it and kept their own design priorities. Or the world may move on before they get there and it won't matter, again ;)
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Tue Nov 12, 2013 11:19 pm
I didn't think the Bosch system really caught on. While this can suit a step-over type frame more comfortably, the hub motors have tended to become the default (which I admit is purely my own personal observation).
Original Steps
Bosch
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Tue Nov 26, 2013 11:38 pm
Pictures now out: Shimano Steps ebike system (Click through for more)
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Wed Feb 05, 2014 9:23 am
There is a review of Shimano Steps up on Bike Europe.
Actually very light on any real details with 7 paragraphs but little 'reviewing' this however it is an important product and for those interested: Shimano Steps Review on Bike Europe
