Electric Bike Range Simulator
Postby Aushiker » Wed Mar 26, 2014 5:36 pm
I just came across this electric bike range simulator. It is based on Google maps so a little clunky in terms of routing but I liked how you can add variables such as headwinds along with rider and bike parameters. It then computes you time etc (see image).
geebee
Re: Electric Bike Range Simulator
Postby geebee » Wed Mar 26, 2014 9:58 pm
That is actually pretty impressive and is in the ball park for a known ride maybe uses a bit more battery than real life, the variable for pedalling is great and erring on to much power used is preferable.
I just used the nominal motor wattage of 250W but my mid drive peaks around 600w (rated as 250W) but it shows too high a power usage at that setting, which makes sense as I never make the motor run at peak power for any length of time.
The battery life is as per expected in theory, but my battery is 3 years old and still runs pretty close to new range wise, got to get lucky sometimes :)
Postby Aushiker » Thu Mar 27, 2014 11:21 am
There is another one, called the [url="http://www.electricbikesimulator.com/index.html"]Electric Bike Simulator[/url].
