So, I bit the bullet and bought one...
The Fixer
Postby The Fixer » Fri May 04, 2018 1:27 pm
...off eBay for just under $900.00 new. A TODO 'Mountain Rider' 26" with a geared 250W rear-hub
motor. Three months and nearly 800 km later, and I'm loving it!
Everything was in the box, and everything was well padded and protected. Nothing was damaged
in transit. Nothing has failed, nothing has broken (well, one thing, but more of that later). It per-
forms as advertised in every way. I'm easily getting the advertised 40 km between charges, which
equals approx two days riding.
Tyres (Kenda) and tubes are t-shirt thin, so I've had issues with punctures due to 'cat-eye' thorns. I
used some 'tyre slime' in both tubes and that problem went away. I used 'Orange Seal' brand, highly
recommend the stuff.
Mechanical disc brakes perform well, wet or dry. Pads still holding-up well. Drive-train is Shimano
Tourney, but works well and has remained in adjustment. Frame is aluminium alloy. Weight 20.6 kg.
It easily maintains its top speed, and will climb reasonably long, steep grades, altho a bit of LPA
doesn't hurt. It isn't happy in the real rough stuff, but will cruise fire-trails and dirt roads all day
with no strain on bike or rider. Around town it's excellent.
I replaced the original nice-looking-but-rock-hard seat with something a bit kinder to the nether-
regions, and fitted a QD rear rack and a Go-Pro mount. Otherwise, nothing is modified.
Oh - the thing that broke? The speed-control clamp, because the bike was blown-over in a heavy
wind gust. Which could happen to anything. A couple of small cable-ties, though, and it's actually
more secure now than it was previously.
'Cheapie' it may be - junk it is not. I'm 100% happy with it so far.
I don't care if it's a $20 Huffy or a $20k Colnago, as long as you're riding, and you're happy.
The Fixer
Re: So, I bit the bullet and bought one...
Postby The Fixer » Mon May 07, 2018 8:52 pm
Yeah, OK.
I sometimes wonder why I bother.
This is one of those times.
leovendramini
Postby leovendramini » Mon May 07, 2018 9:39 pm
The Ebay one had an in frame battery but yours is outboard ?
Calvin27
Postby Calvin27 » Mon May 07, 2018 10:00 pm
Looks quite tidy for an ebay bike. Nice buying.
What speed is the cassette at the back? WOndering if it can take 8/9/10 speed because I'm thinking of swapping my mid drive to a hub motor.
Fast light bike
Cushy dirt bike
Workhorse bike
No brakes bike
Ebike :)
The Fixer
Postby The Fixer » Tue May 08, 2018 11:22 am
Calvin27 wrote:Looks quite tidy for an ebay bike. Nice buying.
This one is a seven.
Three at the front.
It does feel as if it could use an extra gear or two at anything over around 20km/h.
I generally leave it on the small cog at the rear, and shift between the intermediate
and large chain-rings on the front, when using the motor.
The Fixer
Postby The Fixer » Tue May 08, 2018 11:24 am
leovendramini wrote:The Ebay one had an in frame battery but yours is outboard ?
I believe they do a somewhat more 'up-market' model ( a 29.5", if I recall correctly) which does, indeed, have the battery integral with the frame.
Mububban
Postby Mububban » Tue May 08, 2018 5:06 pm
Three at the front.
Nice bargain. Getting it for a steal makes anything better :)
When I was using my 200W e-bike kit on my old MTB (3 x 7 gearing) I'd almost never get out of the big ring at the front. I'd just shift around the mid range of the cassette. Only proper hills would see me gearing down on the front.
My ebike kit has been relegated to the spare room to be sold off one day (dead battery, I'm looking for quotes to replace it), but I'll always have a soft spot for them as they got me back riding again, and when I'm older they'll help to keep me riding :)
I'm about to miss not having that motor going up the hills on Rottnest towing a heavy trailer full of the kids' backpacks and beach towels etc.....daddy pack mule is in for a tougher time this year than the last few :shock:
Calvin27
Postby Calvin27 » Thu May 10, 2018 1:26 pm
I run out of gears quite quickly on my 1x8 speed mid drive PAS. Cassette range is 11-30 but I think a 10 speed 11-36 might be perfect and not too expy.
Fast light bike
Cushy dirt bike
Workhorse bike
No brakes bike
Ebike :)
