Summary of Australian Road Rules for Cyclists
donnaeastman
Re: Summary of Australian Road Rules for Cyclists
Postby donnaeastman » Tue Apr 24, 2018 3:18 pm
Thanks for this post! This is very helpful, now I know when and how to use my bike properly.
roberto73
Postby roberto73 » Mon Apr 30, 2018 9:51 pm
Rule 119 says cyclists have to give way to "exiting vehicles" on two lane roundabouts. I assume this doesn't mean giving way to a vehicle behind you in the same lane, if they entered the roundabout at the same entry as you, because you wouldn't know what they were intending? If they entered on your right (at the entry 90 deg around from you) just after you entered you might see their indicator, so do you have to stop or slow to allow them to exit, even it they are behind you in the same lane? It is a pretty big ask to expect a cyclist to be aware of every other vehicles intentention in and approaching a roundabout.
Postby find_bruce » Tue May 01, 2018 10:35 am
Bob you need to read rule 119 in the context of Part 9 of the road rules which deals with roundabouts. Rule 111 provides the rules for 2 lane roundabouts, the simple version of which is turn left from the left lane, turn right from the right lane & straight ahead from either lane.
The exception for bicycles is that they can stay in the left lane and turn right. The rule applies to a car that entered from the same entry but in the right hand lane - they are entitled to go straight ahead & the cyclist must give way to them before turning right
If they entered from the left lane the same as the cyclist, it cannot arise as the car must turn left or go straight ahead.
If they entered from the next entry, it shouldn't arise as they should be using the same exit as the cyclist
In my experience the default rules never apply at multi-lane roundabouts & there are always traffic arrows intended for the usual traffic flow.
Do you have a particular multi-lane roundabout in mind
I prefer to avoid multi-lane roundabouts and when I can't, I enter the roundabout in accordance with the usual vehicle rules - ie if I'm turning right I will be in the right hand lane.
A common misconception is about cars approaching a roundabout - there is no right to enter a roundabout at the speed limit & no-one is required to give way to a car approaching a roundabout.
A single lane roundabout near me that illustrate that this behaviour makes roundabouts dangerous. Sibbick St, Bilby St & Byrne Ave Abbotsford - cars traveling on Bilby St approach the roundabout as if everybody must give way to them - they are then unable or unwilling to stop when I enter the roundabout from Sibbick St turning right.
Cycleops70
Postby Cycleops70 » Wed May 16, 2018 2:07 pm
I have a question related to the scope of the WA road traffic code 200 (section 2)
It states that;
4 . Scope of regulations
(1) Unless the context requires otherwise, these regulations apply to persons, vehicles and things on roads only, and where a provision of these regulations requires, or prohibits, the doing of any act or thing, that requirement or prohibition relates to the doing of that act or thing, on a road.
(2) Where a provision of these regulations requires, or prohibits, the doing of any act or thing on a path, that requirement or prohibition only relates to the doing of that act or thing, on the path if the path forms a part of a road.
How I understand this is; everything contained in the road traffic code 2000 only applies if you are on the road, not a path.
Anything within the code can only be applied to paths, if that particular code specifically refers to a path, & that path forms part of the road.
Putting aside whether a path "forms part of the road" by simply being within the road reserve. There are a lot of rules within the code (including helmets & phones) that do not include the term paths. And if they did, would not be applicable on a path not associated with a road. For example, through parks where there is no road.
Am I reading too much from this?
To me it reads like the RTC 2000 is not applicable on any path, unless it is within the road reserve, and the a regulation specifically includes paths.
I'm not sure if I'm willing to test this with regard to helmets, but I'm interested in others interpretation.
Scott_C
Postby Scott_C » Wed May 16, 2018 2:46 pm
Cycleops70 wrote:I have a question related to the scope of the WA road traffic code 200 (section 2)
This is one of those questions that probably won't be satisfactorily resolved without an actual lawyer or possibly a judge but, for what it is worth, it is my understanding that the RTC2000 does not apply on a path away from a road/outside of a road reserve. In areas away from roads the relevant council bylaws apply instead (and may include restrictions on cycling and helmets).
The definition of road used in the Code is sufficiently wide that I believe it includes all paths within the road reserve as being part of a 'road'. The term Carriageway is used in the Code to refer to what a layperson calls a road.
Thoglette
Postby Thoglette » Wed May 16, 2018 5:20 pm
...it was discussed at length in the Western Australia sub-forum a few years back. The discussion involved a number of people with access to legal advice and case law (as part of their day job) and the collective opinion was that Scott's view is correct.
The caveat is that section 73 of the act notes that "Certain offences extend to driving or attempting to drive in public places" applies to certain motor vehicle offences. In fact, most of the interesting ones (DUI, stopping at accidents etc). However it does not include Section 111 under which the Regulations are made.
There are other references to public places and car parks (e.g. around road rage etc.) within the act. Some of these may affect cyclists.
Cycleops70
Postby Cycleops70 » Thu May 17, 2018 2:34 pm
I had a quick look in my local bylaws & couldn't find anything related to bikes, or helmets.
Would police be able to enforce bylaws? Or is that the responsibility of local government only?
Thoglette, are you referring to the road traffic act 1974, not the road traffic code 2000?
If so, I agree, the drink driving law within that is clearly applicable to any public place. But refers to motor vehicles only.
I can't find any reference to bicycle helmets within the RTA 1974.
Thoglette
Postby Thoglette » Fri May 25, 2018 5:44 pm
Cycleops70 wrote:Thoglette, are you referring to the road traffic act 1974, not the road traffic code 2000?
The Act.
Cycleops70 wrote:If so, I agree, the drink driving law within that is clearly applicable to any public place. But refers to motor vehicles only.
Agreed.
Cycleops70 wrote:I can't find any reference to bicycle helmets within the RTA 1974.
There's a mention of PPE in the powers of the Guvnor to make regulations (111. 2 c (ii) "requiring the drivers and passengers ....to wear prescribed items of equipment"). I presume this power is also used for regulations on seat belts and m'cycle helmets.
Postby find_bruce » Mon Jun 04, 2018 4:45 pm
An actual lawyer won't resolve this either - all they can do is set out their opinion which a court may disagree - I haven't been able to find any decision that touches on it. The 2nd paragraph was a new provision in 2000 & didn't appear in the Road Traffic Code 1975.
It seems a decent argument, but I wouldn't recommend going out of your way to test it.
ColinOldnCranky
Postby ColinOldnCranky » Tue Jun 05, 2018 10:29 am
It states that;
The term "Road" includes the path. What you and I think of as the roadway is, in regs and statute, referred to as the "carriageway".
However, you have specified the bit that makes it legal to, for example, ride a bike around the river in South Perth without a helmet as the paths there are NOT part of any "roadway". Contrary to popular opinion it is perfectly legal to ride on many paths in many public places without a helmet. I posed that once to a cop at a cylcling event once and was gratified that he knew that level of detail wrt to cylists.
An example of an exception applying more broadly than roads is reckless driving in shopping centre car parks. It used to be legal but, in WA at least, they regulated some common sense into the regs many years ago. You can also be done for dink driving in those same car parks.
Bendo
Postby Bendo » Wed Aug 22, 2018 12:50 pm
The link in the first post on Victorian road rules is not very user-friendly. Here are two more that are:
https://www.vicroads.vic.gov.au/safety-and-road-rules/road-rules/a-to-z-of-road-rules/bicycles
And the Victorian Law Foundation has done a great job too:
https://www.victorialawfoundation.org.au/publication/bike-law
One little-known Victorian law (at least from observing cyclist behaviour) is that you don't have to signal to turn left. Ever.
I also thought that signalling to turn right was only required when safe to do so, however the VLF's summary says you have to at all times. I'll keep searching for the wording of this.
Obviously it improves safety if drivers know you're going to turn right or merge right. But there's also a point where continuing to signal throughout the turn decreases safety, e.g. around a roundabout or negotiating an intersection with tram tracks. Gusting winds and slippery roads makes keeping your hands on the bars even more important.
Three laws I'm looking forward to in Vic:
1) riding on the footpath
2) left turn at any time
3) one way street exemption
b
Postby find_bruce » Wed Aug 22, 2018 1:56 pm
Bendo wrote:The link in the first post on Victorian road rules is not very user-friendly. Here are two more that are:
Sorry Bendo but the pages you link to are not the road rules, but rather someones interpretation of the road rules. These have no legal force and can be wildly different from the actual rules. The example that springs to mind was that various such publications stated that a safe passing distance from a bicycle was 1 m. This however was markedly different from the interpretation adopted by the police who thought that a safe passing distance was the thickness of a coat of paint - no blood no foul.
Left turn signals are covered by road rule 46 - "This rule does not apply to a driver if the driver’s vehicle is not fitted with direction indicator lights." remembering of course that driver includes rider and vehicle includes bicycle
Right turn signals are covered by road rule 48 which has a couple of minor exceptions for bicycles
Bendo
Postby Bendo » Wed Aug 22, 2018 4:21 pm
find_bruce wrote:Sorry Bendo but the pages you link to are not the road rules, but rather someones interpretation of the road rules...
Um, "someone's"? WADR, VicRoads is more than just someone, as is the Victorian Law Foundation. However I do take your point, that to some extent the law is whatever the cop who has pulled you over says it is, at least until you go to court about it.
Those links you just supplied were much more user-friendly, thanks! b
Changes direction to the right is defined in rule 45(3).
(2) The driver must give the change of direction signal for long enough to give sufficient warning to other drivers and pedestrians.
(3) If the driver is about to change direction by moving from a stationary position at the side of the road or in a median strip parking area, the driver must give the change of direction signal for at least 5 seconds before the driver changes direction.
Note
Median strip parking area is defined in the dictionary.
(3A) Subrule (3) does not apply to the rider of a bicycle that is stopped in traffic but not parked.
(4) The driver must stop giving the change of direction signal as soon as the driver completes the change of direction.
Penalty: 3 penalty units.
(5) This rule does not apply to—
(a) the driver of a tram that is not fitted with direction indicator lights; or
(b) the rider of a bicycle making a hook turn.
Jmuzz
Postby Jmuzz » Fri Oct 26, 2018 12:38 pm
It's still just some employee, probably junior, told to create a friendly version of the rules.
Those re-interpreted rules are full of little mistakes and word substitutions which can change the meaning.
The legislation is the official version, which is fairly straightforward in the Road Rules but gets a bit complex in a few cases where other acts also apply.
Users browsing this forum: fat and old, Quency
