What an RAF pilot can teach us about being safe on the road
Posted: Fri Nov 09, 2012 2:26 pm
Interesting blog post at the London Cyclist. Please click through for the full post as it provides the background to the recommendations for cyclists ...
and
Two important takeaways for cyclists: Increasing your contrast helps you be seen. Think flashing bike lights. Also, remember the importance of good road positioning.
and
AndrewCyclists and motorcyclists:
- Recognise the risk of being in a saccade. High contrast clothing and lights help. In particular, flashing LED’s (front and rear) are especially effective for cyclists as they create contrast and the on-off flashing attracts the peripheral vision in the same manner that movement does. There’s nothing wrong with leaving these on during the day. (Especially if they are rechargeable)
- The relatively slower speed of bicycles means that they will be closer to a point of collision if a vehicle begins to pull into their path. Turn this to advantage – when passing junctions, look at the head of the driver that is approaching or has stopped. The head of the driver will naturally stop and centre upon you if you have been seen. If the driver’s head sweeps through you without pausing, then the chances are that you are in a saccade – you must assume that you have not been seen and expect the driver to pull out!
- Recognise that with a low sun, a dirty windscreen or one with rain beating against it drivers are likely to have less of a chance of seeing you.
- Cycle instructors have been saying it for years: Ride in a position further out from the kerb as a driver is more likely to be looking in this location. See: How to make your next bike ride safer than the last.
