Australian Cycling Forum Reopened
News from Bicycles Network Australia and the Australian Cycling Forums
Re: Australian Cycling Forum Reopened
Postby AUbicycles » Fri Feb 03, 2012 8:51 am
Re work computers - often work environments have proxies which can't be bypassed and may have older versions of the site.
On Mac, I used shift reload to (usually) attempt to reload the page from the originating server. though shift relaod doesn't always work.
I am emptying the forum cache (in 2 minutes) which will ensure that old pages that may show access errors are cleared out. keep me updated.
AUbicycles
Site Admin
Site Admin
by Forum Ads » Fri Feb 03, 2012 9:56 am
Postby PawPaw » Fri Feb 03, 2012 9:56 am
Just advising that the forum is loading noticeably faster in Brisbane since the change.
PawPaw
Postby Mulger bill » Fri Feb 03, 2012 9:58 am
Fingers crossed I can get it at work tonight, gets bl00dy boring between trains.
Postby ft_critical » Fri Feb 03, 2012 10:45 am
Is it going to be the case that we cannot 'View Active Topics' unless we are logged in? I am getting a no permissions to search error when not logged on. My blackberry doesn't stay logged in, so this would be a problem...
ft_critical
Postby Aushiker » Fri Feb 03, 2012 10:48 am
Interesting ... I justed VPN into work and then attempted to connect via the proxy server ...
index.php returned a 404 error message instead of previous notice HOWEVER http://www.bicycles.net.au/ gave me access to the file structure of the website. Only disconnecting the VPN and coming back outside of the proxy server gives me access to the forums.
Postby twizzle » Fri Feb 03, 2012 11:39 am
Yep, I had the same, everything broken and able to see the directory structure, tapatalk went offline as well.
Re. stuff being cached locally, that's why I was trying random searches off google, ie. "pickle", "random" to try and find pages I had never been to before so that they were unlikely to be in the proxy.
But... seems to all be working fine now, and I'm accessing it from work finally.
I ride, therefore I am.
twizzle
Postby Boognoss » Fri Feb 03, 2012 12:21 pm
No problems for me at work, and on our 100Mbps fibre it's faster than ever.
Well done AUBicycles!
Avanti Quantum, Salsa Casseroll, Specialized Tricross
Boognoss
Postby Mulger bill » Fri Feb 03, 2012 3:31 pm
Boognoss wrote:No problems for me at work, and on our 100Mbps fibre it's faster than ever.
Agree on point 2. Huge job done well.
So Boogs, what hardware are you running (AT) work? I'm stuck on a HP toaster (thin client, citrix), and it is the equivalent of a saddle sore on a haemorrhoid :roll:
Postby Boognoss » Fri Feb 03, 2012 3:37 pm
PIPE fibre 100MBps up/down with unlimited data allowance (read: SWEET).
Standard client/server network. i7/6GB/W7x64 laptop for me.
A pox on thin clients I say!
Boognoss
Postby Mulger bill » Fri Feb 03, 2012 3:54 pm
Not wrong Boogs, no sound card, videos never stream properly, no optical drive, thumbdrives awkward, printing large files impossible unless I muck around transferring them to thumb then run them on our non networked "black" box which is a direct USB connect to the printer (Shhh, don't tell the IT crowd! :wink: )
Postby Boognoss » Fri Feb 03, 2012 4:45 pm
LOL Shaun your secret's safe with me. At my company I AM the IT crowd so most of the secrets are mine ;-).
Cheers, Simon
Sent from my iPhone using Tapatalk
Boognoss
Postby AUbicycles » Fri Feb 03, 2012 8:32 pm
Thanks for the additional reports and details.
On new setting to the forums now are that you now need to be logged in in order to search. The search function does put a bit of a load on the server so we are going through each step.
AUbicycles
Site Admin
Site Admin
Postby Mulger bill » Fri Feb 03, 2012 8:53 pm
Works! Yeeeeeahhhh! 8)
Postby }SkOrPn--7 » Sun Feb 05, 2012 11:30 am
Nice upgrade noticed a huge difference first time I signed back in plus the new look is a great outcome so congrats Chris.
Ricky
}SkOrPn--7
Previous
Return to Info / announcements
