Scott Foil Rear Light?
trippyho
Postby trippyho » Sun Jun 30, 2013 8:30 am
Hi All,
I have just purchased a new Scott Foil and just want to ask other Scott Foil owners what rear light do you use to attach to the frame / seat post?
All my current rear lights don't fit on the ero frame, and I can't find anything online that might work. Any suggestions / recommendations? I do a lot of early morning training rides and need one for the cold dark winter mornings. Btw a saddle bag is out of the question as I carry everything in a tool bottle, so attaching one onto a saddle bag is a no go for me :)
So any help welcome. Thanks in advance :)
ab012
Re: Scott Foil Rear Light?
Postby ab012 » Sun Jun 30, 2013 8:45 am
congrats on the foil!
I use a Lezyne Micro Drive Rear light - the elastic band easily wraps around the post.
http://www.lezyne.com/en/micro-drive-rear
(not the cheapest - but i personally quite like it :) )
santacruzscott
Postby santacruzscott » Sun Jun 30, 2013 4:09 pm
I bought a Moon Gem 3.0
Fits with a stretchy rubber strap , usb charging , and super bright.
http://www.moon-sport.com/product-detail.php?id=15
Image Image
LinzOC
Postby LinzOC » Sun Jun 30, 2013 8:30 pm
I use a Serfas Thunderbolt (with the elastic wraparound) with the bottom of the light resting on the lip of the downtube.
trippyho
Postby trippyho » Sun Jun 30, 2013 10:48 pm
Thanks for the responses. Will check each one out and compare. And hopefully have something by mid week :)
trippyho
Postby trippyho » Mon Jul 01, 2013 6:57 am
LinzOC wrote:I use a Serfas Thunderbolt (with the elastic wraparound) with the bottom of the light resting on the lip of the downtube.
Have you got a photo by any chance? Want to see how it looks on your foil? And is it bright enough?
Crawf
Postby Crawf » Mon Jul 01, 2013 11:59 am
A Boomer will fit stretch around that SP no worries.
http://www.wiggle.co.uk/knog-boomer-1-l ... ight-pair/
LinzOC
Postby LinzOC » Mon Jul 01, 2013 8:33 pm
Sure do, but cannot work out how to attach them. Brightness is bloody good, easy to see at quite a distance.
Postby Mulger bill » Mon Jul 01, 2013 8:43 pm
LinzOC wrote:Sure do, but cannot work out how to attach them. Brightness is bloody good, easy to see at quite a distance.
HERE you go :)
fingy
Postby fingy » Mon Jul 01, 2013 8:58 pm
If you have a Fizik saddle, Cateye do an ICS bracket forRapid 1,3 and 5 lights.
An option for non-round posts (Giant owners) :)
LinzOC
Postby LinzOC » Wed Jul 03, 2013 1:43 pm
I can get another one further back if needed.
trippyho
Postby trippyho » Wed Jul 03, 2013 5:20 pm
Thanks for the picture. I ended up ordering the same light (serfas thinderbolt) based on how neat it attaches and reviews.
Might look into the fizik seat light integration a bit later down the track once I have a bit more money. :)
Thanks for all the responses :)
open roader
Postby open roader » Wed Jul 03, 2013 5:48 pm
And if you don't have a Fizik saddle (damn handy that Fizik clip in backet) then Cateye have a saddle rail bracket mount RM-1 which keeps your light tucked awayneatly, nice and high for better visibility and well away from tyre fling.
Crawf
Postby Crawf » Thu Jul 04, 2013 10:46 am
open roader wrote:And if you don't have a Fizik saddle (damn handy that Fizik clip in backet) then Cateye have a saddle rail bracket mount RM-1 which keeps your light tucked awayneatly, nice and high for better visibility and well away from tyre fling.
Any chance you could measure the distance C-C between those two mounting bolts?
Wakatuki
Postby Wakatuki » Thu Jul 04, 2013 4:13 pm
I knew mine wasn't the only one that needs a wash!
I use the Knog Frog in lime green :) for normal riding and if at night (full dark, no street lights around me) I use a second smart 1/2 watt (wiggle) steady light on the saddlebag. But really like the look of the comet that a mate rides with tucked under his saddle, similar to pictures on here. I'm growing up now and thinking of moving away from the saddlebag! Stuff it in the Jersey! Spare tyre taped to the seatpost.... Game on!
Enjoy the Foil, mine still makes me feel special. My backside not so much... Still searching for the holy saddle!
open roader
Postby open roader » Thu Jul 04, 2013 5:11 pm
Crawf wrote:Any chance you could measure the distance C-C between those two mounting bolts?
Cateye RM-1 under saddle rear light clamp/bracket
35mm C to C for the mounting bolts.
The clamp blocks are 77mm wide.
pawnii
Postby pawnii » Thu Aug 08, 2013 12:51 pm
boomer looks the best
yes, I'm an overweight weight weenie
2012 Scott Foil Premium
