Ultegra 11spd
Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 07, 2013 4:52 pm
HAKS wrote:
Xplora wrote:Want to know if the 6800 crank nondriveside is compatible with the 6700... would definitely be the tipping point for a Stages power meter for me...
I'll check on the weekend for you when i do the swap.
If there was ever a need for a "like" button, spurious as they are...
Re: Ultegra 11spd
Postby jasonc » Wed Aug 07, 2013 5:03 pm
Xplora wrote:If there was ever a need for a "like" button, spurious as they are...
+1
the more you write about it, the more I'll read
having to wait til jan for di2 is going to be hard
Re: Ultegra 11spd
Postby Duck! » Wed Aug 07, 2013 7:54 pm
It'll fit. Spindle diameter & spline haven't changed since the two-piece setup appeared on 7800 D-A.
Duck! wrote:
Xplora wrote:Had a look online, Shimano's compatibility chart says 9000 doesn't go with anything else, and saw a few forum comments that said the new teeth might be susceptible to excessive misshifts with the 10 speed chain as it shifts. Then again... if you wanted to get a new crank now and move to 11 speed by Christmas, that might not be a bad idea.
They said the same thing ten years ago when 10-speed was The New Thing, and it quickly became apparent that there's more compatibilty than Shimano would like us to believe. Heck, they're even marketing certain stuff as 9/10-sp. compatible. Sure there's some bits that are specific, but cranks tend to not be too fussy.
I fitted a 6650 Ultegra Compact to a customer's 9000-specced bike for a trip to France a few weeks ago (due to unavailability of compact rings for the 9000 crank). She brought the bike back in today to have the crank swapped back, and I asked her if the 10-sp crank had any effect with the 11-sp. chain. She said it worked perfectly the entire time.
Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 07, 2013 9:19 pm
Ok smartypants; will there be a significant stiffness difference between the arms? (I assume it wouldn't be too different?)
Cmon I'm serious, 105 arm is calliiiiiinnnnnnngggggggggggggggggggggggggggg
Re: Ultegra 11spd
Postby Duck! » Wed Aug 07, 2013 11:27 pm
Not that the average human could detect. There is a small weight increase with each step down the ranks though, as the hole up the guts gets smaller (105 & better have hollow arms, Tiagra & below are solid). There would be vastly more flex in your frame.
Xplora
Re: Ultegra 11spd
Postby Xplora » Thu Aug 08, 2013 8:24 am
Grand sexy time! I've got to shuffle the deck chairs but its time for power. 105 crankarm in black doesn't have to match perfectly. The price is right at 700 us bucks.
HAKS
Re: Ultegra 11spd
Postby HAKS » Sun Aug 11, 2013 4:36 pm
Haven't fitted my groupset yet (waiting for i-link cables to arrive) but I did check the crank compatibility with a 6700 set I had lying around. No probs using a 6700 left arm on the 6800 right arm/rings.
Current Ride: Trek Madone 6.5 (2013)
Xplora
Re: Ultegra 11spd
Postby Xplora » Sun Aug 11, 2013 8:08 pm
Legend
HAKS
Re: Ultegra 11spd
Postby HAKS » Tue Aug 20, 2013 9:17 pm
So I ended up with a Trek 2013 Madone frame which meant I need to get some dual post brakes to fit the frame. Ordered some Ultegra 6810 aero brakes which arrived today. Planning on the full 6800 build this weekend now I have the brakes.
Some slightly used 6800 brakes going in the market place ;)
Xplora
Re: Ultegra 11spd
Postby Xplora » Tue Aug 20, 2013 10:16 pm
Didn't realise they had the aero brakes available yet? I'm not unhappy with my Bontrager stock brakes... good on you for getting a real bike ;)
HAKS
Re: Ultegra 11spd
Postby HAKS » Wed Aug 21, 2013 5:01 am
Xplora wrote:Didn't realise they had the aero brakes available yet? I'm not unhappy with my Bontrager stock brakes... good on you for getting a real bike ;)
not many shops stocking them yet. Found some at http://www.westbrookcycles.co.uk/ though and they were pretty well priced.
mikesbytes
Re: Ultegra 11spd
Postby mikesbytes » Wed Aug 21, 2013 10:00 am
Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 21, 2013 11:49 am
Trek Madone 2013+ for one. I'm guessing most of the TT bikes and "aero" road bikes too. They sit flat against the fork, I'm not sure if they work with standard forks?
HAKS
Re: Ultegra 11spd
Postby HAKS » Wed Aug 21, 2013 12:18 pm
They need dual brake post mounts for a start.
Re: Ultegra 11spd
Postby Duck! » Wed Aug 21, 2013 2:08 pm
They'll only work on specifically-designed frames & forks. They won't work with ones designed for v-brake style aero brakes, because the mounts are in a different location.
Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 21, 2013 3:34 pm
HAKS wrote:They need dual brake post mounts for a start.
Cough cough time for cough cough upgrade cough... gee what happened to my lungs?? :lol:
AndyRevill
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:01 pm
So my Domane came with mostly 6700 Ultegra but the cranks are non-series. I'm thinking about upgrading them to Ultegra and it seems logical (to me at least :D ) that if I do that I may as well go for the latest 6800 variant. I know these are aimed at 11 speed but is there any reason they won't work with 6700 shifters?
I've tried trawling google but I can't seem to come up with anything so hoping the combined wisdom on here can guide me.
cheers, Andy
Trek 1.7 dec.
Trek Domane 4.5
Re: Ultegra 11spd
Postby jasonc » Thu Aug 22, 2013 2:10 pm
AndyRevill wrote:So my Domane came with mostly 6700 Ultegra but the cranks are non-series. I'm thinking about upgrading them to Ultegra and it seems logical (to me at least :D ) that if I do that I may as well go for the latest 6800 variant. I know these are aimed at 11 speed but is there any reason they won't work with 6700 shifters?
6700 shifters won't work with the 6800 deraillers (well, at least the rear one won't)
you'll also have to check that your wheel hub is capable of holding an 11 speed cassette (they are wider)
re your crank - you'll have to check your bottom bracket/frame are capable of running a 24mm spindle BB that is the correct width for the shimano cranks
Re: Ultegra 11spd
Postby Duck! » Thu Aug 22, 2013 2:17 pm
Did you even read the question?
There is no problem mixing the 6800 crank with a different series of shifters/derailleurs/etc.
Re: Ultegra 11spd
Postby jasonc » Thu Aug 22, 2013 2:27 pm
the upgrading them to me he's going to be upgrading more than 1 component
them - Pronoun
Used as the object of a verb or preposition to refer to two or more people or things previously mentioned or easily identified.
AndyRevill
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:29 pm
Duck! wrote:Did you even read the question?
Thanks, I thought that should be the case but nice to have some confirmation :D
cheers, Andy
Trek 1.7 dec.
Trek Domane 4.5
AndyRevill
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:41 pm
them - Pronoun
Sorry, my bad. I used cranks as in plural of crank. In my mind a bike has two cranks if the definition of a crank is "an arm attached at right angles to a rotating shaft" there's one on each side. I should more correctly have used crankset, then I could have used "upgrade it". Won't do it again, honest :D and thanks for trying to help.
cheers, Andy
Trek 1.7 dec.
Trek Domane 4.5
Xplora
Re: Ultegra 11spd
Postby Xplora » Thu Aug 22, 2013 8:58 pm
Andy, definitely get yourself 6800 cranks if you are upgrading. Make sure you get the standard cranks because I'm sure it is cheaper to pick up second hand compact chainrings for the 6800/9000 cranks, and you can swap them as needed. Even better to go TT chainrings LOL :)
Re: Ultegra 11spd
Postby Duck! » Thu Aug 22, 2013 11:57 pm
Well it may be a little while yet before secondhand rings start appearing, but the beauty of the 9000/6800 design is that the same crank spider will accept all ring sizes, so you don't need to change the whole crank if you wish to swap from standard to compact or vice-versa. :)
HAKS
Re: Ultegra 11spd
Postby HAKS » Fri Aug 23, 2013 6:51 am
Yet to see any Ultegra chainrings actually on the market. Will be interesting to see what they cost when they become available. I went the compact route but wouldn't mind a pair of standard rings for the month or two of the year (summer) when I only ride flat courses.
