used dura ace vs new ultegra
RRalphy
Postby RRalphy » Fri Sep 27, 2013 5:07 pm
I am currently getting a groupset together for a build and have the option following options and dont really know what to do, opinions would be valued:
option 1: dura ace 7900 groupset slightly used (~1000km) for $900
option 2: mix matched groupset new ultegra (chain cassette brakes) and used (500km) dura ace (RD FD cranks and shifters) for $800
option 3: brand new ultegra 6800 (11 spd) from the UK for $860
which would you go for? is dura ace so much better than ultegra to warrant me getting moderately used parts instead of getting brand new ultegra? I know the dura ace will weigh less (http://www.totalcycling.com/component-weights.html)
jaseyjase
Re: used dura ace vs new ultegra
Postby jaseyjase » Fri Sep 27, 2013 5:29 pm
i think thats a pretty good price for 7900 in that condition
Do you have wheels? cos you'll need to factor that in if you go 11spd 6800.
DoubleSpeeded
Postby DoubleSpeeded » Fri Sep 27, 2013 5:36 pm
RRalphy wrote:I am currently getting a groupset together for a build and have the option following options and dont really know what to do, opinions would be valued:
others may think differently but personally... id go for the brand new ULTEGRA... peace of mind
you say its "slightly used" how slightly, is ...slightly?
1000km?... i dont recall groupsets having odometers... so you only can go by what people tell you and take their word for it.
i clean my chain every 30km ride... yes thats excessive... but 1000km with TLC i assume would be different to 1000km of someone that cleans the drivetrain once in a while.
my TT bike came with Full ultegra groupset except for the chain and the shifter.
i swapped it all to Dura-ace..just for the sake of it.. for the status..everything..rear + front derailleur, chain & even the composite $300AUD+ Pedals.
except for the crankset which i installed a Vision/FSA for the carbon look.
To be honest, feeling wise.... i don't really notice much of a difference.. and i dont think you will notice either.
same as the ceramic bearing jockey wheels and ceramic bottom bracket bb30 that costed just under $300... there was really no difference felt.
unless maybe the placebo effect.
imo... Ultegras work real flawlessly and seem to be based on the Dura-Ace designs.... some things almost look identical
Last edited by DoubleSpeeded on Fri Sep 27, 2013 5:41 pm, edited 3 times in total.
Tim
Postby Tim » Fri Sep 27, 2013 5:39 pm
I have been riding a bike fitted with DA7900 for about the last 4 years and recently bought a new bike fitted with Dura Ace 9000, 11 speed.
DA 9000 is vastly more impressive than DA 7900 in terms of smoothness, ease and precision of gear changes.
I am presuming that the quality and design of the new Ultegra 11 speed is very similar to DA9000.
I'd go the new Ultegra.
My DA7900 has never changed gears in a crisp manner. It has always felt sloppy despite mine and several other peoples (including LBS and several "old hands")attempts to tune it up. I have read other like criticism of DA7900.
macca33
Postby macca33 » Fri Sep 27, 2013 6:29 pm
NEW Ultegra 6800 - no question - unless you will have issues with having / buying an 11-speed compatible wheelset.
RRalphy
Postby RRalphy » Fri Sep 27, 2013 7:37 pm
I have dura ace c24 wheels with an 11 speed hub so no issues there
biker jk
Postby biker jk » Fri Sep 27, 2013 7:56 pm
Tim wrote:I have been riding a bike fitted with DA7900 for about the last 4 years and recently bought a new bike fitted with Dura Ace 9000, 11 speed.
+1. Shifting is better on Ultegra 6800 versus Dura-Ace 7900. Brakes are better as well. Cassettes and chains will be a lot cheaper to replace.
Postby Duck! » Fri Sep 27, 2013 10:28 pm
Grab the 6800 Ultegra. The shift quality is vastly superior to 7900. (Many say 9000/6800 is the step above 7800 that 7900 should have been.)
Dr_Mutley
Postby Dr_Mutley » Sat Sep 28, 2013 1:33 am
I couldn't get rid of 7900 DA quick enough... I hated it... Terrible... My 7800 DA was a thousand times better... I ditched it for 7970 Di2 and it was the best thing I ever did..,
Postby RonK » Sat Sep 28, 2013 10:01 am
DoubleSpeeded wrote:i clean my chain every 30km ride... yes thats excessive... but 1000km with TLC i assume would be different to 1000km of someone that cleans the drivetrain once in a while.
Hehe - that is a severe case of OCD. What would you do on a 100km ride, stop twice to clean your chain? :lol:
1000km is only one month's riding for me - with a wipe down and lube using R'n'R Gold once a week.
Assuming that the 1000km of use is correct, then that is nothing for a group that is built to handle a pro rider's 30,000 p.a. base kilometres.
The real question here is whether 10sp DA or 11sp Ultegra is better. Personally I'd go 11sp but I can understand the appeal of DA. However it is astonishing that a change to 11sp requires a new wheelset if that is true.
Postby Duck! » Sat Sep 28, 2013 10:48 am
RonK wrote:However it is astonishing that a change to 11sp requires a new wheelset if that is true.
What's so astonishing about needing a new wheel to suit the wider cassette?
dale79
Postby dale79 » Sat Sep 28, 2013 10:54 am
you don't need a new wheel set... the cycling industry just relies on people with too much money and no skills to do anything but swipe their credit card
that's a 10 speed shimano free hub and a 11 speed cassette
that's a 11 speed cassette on said 10 speed shimano hub
how about a 10 speed zipp free hub
ive done DT swiss and novatec free hubs as well..
Postby Duck! » Sat Sep 28, 2013 11:13 am
It's cheaper to buy an appropriate wheel than the equipment to do that kind of modification....
dale79
Postby dale79 » Sat Sep 28, 2013 11:29 am
its not exactly hard to find someone with the right equipment to do it. most will do it for a lazy $20 as its not exactly precision machining or time consuming..
warthog1
Postby warthog1 » Sat Sep 28, 2013 11:29 am
Fantastic that you have done that, but from the back ground in your photo, it looks like a lathe is required?
dale79
Postby dale79 » Sat Sep 28, 2013 11:30 am
you could do it with a dremel or file if you were so inclined just might take a little bit longer lol
Postby RonK » Sat Sep 28, 2013 1:24 pm
There is no need to change or modify wheels to use Campy 11sp. Campy freehubs are compatible with 9,10 and 11sp.
Postby Duck! » Sat Sep 28, 2013 1:34 pm
Campag cassettes have traditionally been wider than their Shimano equivalents, although 9-sp. was pretty close. That allowed a bit more space to pack the 11th gear in than Shimano's setup. As a side note, Mavic Shimano-pattern hubs have always required a 2mm spacer behind the cassette (my guess is it's a compensatory measure to correct for the flange spacing allowing the longer Campag-pattern freewheel body, although it's curious that no other manufacturer does this). As such, they're about the only older wheels that are 11-sp. compatible by removing this spacer.
Pottsy
Postby Pottsy » Sat Sep 28, 2013 11:19 pm
if your wheels is campy compatible just do this
http://velonews.competitor.com/2013/09/ ... ght_303199
