DA9000 cassette noise
mrgolf
Postby mrgolf » Tue Dec 16, 2014 11:39 am
Hi all. I know there was an issue with the top 4 gears in the cassette with noise associated with the ti cogs and carbon carrier which was remedied with an extra rivet being added.
I have some graunching noise coming from the cassette under out of the saddle accelerations. I have tried tightening it up more, adjusting rear mech, different wheels etc. I can't get rid of it. It seems worse some times than at other times.
Any thoughts? Similar issues? I should add it is not confined to the top 4 ratios. It's throughout the gear range.
Ross
Re: DA9000 cassette noise
Postby Ross » Tue Dec 16, 2014 1:14 pm
Change to a different cassette (try an Ultegra) and see if that fixes it.
greyhoundtom
Postby greyhoundtom » Tue Dec 16, 2014 1:22 pm
If you have done all that the noise is unlikely to be generated by the cassette and it's time to look further afield such as the free hub, jockey wheels, or whatever is flexing and rubbing as a result of you getting out of the saddle.
mick243
Postby mick243 » Tue Dec 16, 2014 1:27 pm
can you setup a gopro etc on the seatpost looking down at the gears, and go for a ride to reproduce the fault. might show whats causing said noises.
macca33
Postby macca33 » Tue Dec 16, 2014 1:44 pm
Haven't found anything untoward with my DA9000 cassette - well, no noisier than the Ult6800 cassettes I have on other bikes.
Good luck in workingit out.
CAAD10 Berzerker & Focus Mares CX & Ridley Noah SL
Carrots
Postby Carrots » Tue Dec 16, 2014 4:07 pm
The carbon inner spindle hasn't broken/cracked has it...?
mrgolf
Postby mrgolf » Thu Dec 18, 2014 5:12 pm
Cheers for the replies. Will check the spindle tonight. Anyone ever put grease on cassette body? Have read of this elsewhere but seems undesirable.
Ross
Postby Ross » Fri Dec 19, 2014 9:51 am
It may sound silly but have you checked you bidon cage is tight? I had a noise on my bike that I thought was coming from the rear wheel area and it turned out the cage was a bit loose.
