10 Speed Campag Rear Mech with 12-30t Cassette
Krank
Postby Krank » Sun Oct 02, 2016 2:04 pm
Hello all.
Can i still use the 2006 10 speed campag centaur short cage rear mech with the campag 12-30T cassette and 53/39 front rings?
How to test this?
Krank
Uncle Just
Re: 10 Speed Campag Rear Mech with 12-30t Cassette
Postby Uncle Just » Sun Oct 02, 2016 6:06 pm
Nothing new under the sun they say and it's been asked before ...http://forums.roadbikereview.com/compon ... 64212.html
My take would be to err on the safe side and get a medium cage RD although some on that forum claim it works using your RD. If you go with your existing RD install the 12-30 cassette, maybe lengthen the chain if needed and test it on the work stand although out on the road it may be problematic. Don't cross chain either.
I know with a previous Shimano setup I could easily exceed their recommended max tooth size for a 7800 and 7900 RD (going from a 27t to a 30t) because my rear derailleur hanger was long enough to make it work. Other frames may not be so accommodating.
Krank
Postby Krank » Sun Oct 02, 2016 6:30 pm
Thanks.
I would like to buy the MC rear mech in Centaur or Record but they only exist in USA, second hand at vey inflated prices :-(. Not interested in Veloice.
Krnak
Postby Duck! » Sun Oct 02, 2016 8:25 pm
I haven't closely studied the details of Campag's big-sprocket-compatible derailleurs, but I have a feeling their approach is similar to that of SRAM, in that the derailleurs intended for larger than 27 or 28T have a longer main body as well as cage, in order to get the clearance, unlike Shimano who use the same body for both long and short versions, which means if a short cage doesn't have the clearance for a big sprocket, the long version of the same model won't either.
Uncle Just
Postby Uncle Just » Sun Oct 02, 2016 8:50 pm
This may offer some further insight ...http://branfordbike.com/articles/rear-d ... s-pg62.htm
Postby RonK » Sun Oct 02, 2016 10:14 pm
Krank wrote:Hello all.
How to test this?
Krank
How to test this? RTFM
Campagnolo Rear Derailleur
Campagnolo Cassette
Postby RonK » Sun Oct 02, 2016 10:15 pm
double post
Krank
Postby Krank » Sun Oct 02, 2016 11:05 pm
Some great links there guys - thank you!
However, I read conflicting data from the different links provided:
Brandfordbikes - "...it is important to understand that any 1999 to 2008, Campagnolo 10 speed rear derailleur, will shift up to a 29 tooth cog and down to an 11 tooth cog. The problem you will run into is that the derailleur cage may not be long enough to take up all the slack in the chain for a wide range. Thus Campagnolo recommends using a short cage derailleur with a maximum cassette cog size of 26 teeth even though it will shift to a 29 tooth cog..."
Campag Spec -
    CAPACITY (TEETH) 32
    MAX SPROCKET (TEETH) 30
    MIN SPROCKET (TEETH) 11
    CHAINRING FRONT DIFFERENCE (TEETH) 16
Brandford Bikes imply no, campag imply yes.
Still unclear on this one...???
Krank
dalai47
Postby dalai47 » Mon Oct 03, 2016 10:09 am
I bought a new Centaur 10 Speed medium cage when I set up my road bike for OS climbing trips so I could run a 13-29. I read the conflicting discussions and decided to err on the side of caution. Even though I always travel with a spare rear derailleur hanger and a few spokes, it would be a sad end to the trip if you damaged the bike mid holiday!
Postby RonK » Mon Oct 03, 2016 11:33 am
OK, let's calculate the required capacity.
Capacity = (large chainring – small chainring) + (large rear cog – small rear cog)
= 53 - 39 + 30 - 11
= 14 + 19
= 33
So - with this chainset, at 32t capacity a short cage actually does have enough for 29t , but not enough for a 30t sprocket.
It's marginal, and a short cage derailleur may very well work, but a medium cage derailleur has a capacity of 37t and is really the one you should use.
And I just remembered I have a barely used medium cage Chorus derailleur sitting in the cupboard. Yours for $75 plus postage.
Krank
Postby Krank » Mon Oct 03, 2016 2:27 pm
Thanks Ron
The cassette is 30-12, so one less cog to consider and a total capacity of 32.
Does this reduced capacity (by 1 x cog) help improve the likelihood of being able to utilise the existing chain set?
Where does Chorus sit in terms of quality of build with Re Ors and Cenraur for the rear mech in 10 speed?
What year is your MC rear mech?
Send pics to:
Camhird@gmail.com
Krank
dalai47
Postby dalai47 » Mon Oct 03, 2016 3:39 pm
Krank wrote:Where does Chorus sit in terms of quality of build with Record and Centaur for the rear mech in 10 speed?
5 second google search... :roll: Back in 10 speed time Campagnolo order of groupsets was Record, Chorus and then Centaur.
http://www.cyclingnews.com/features/cam ... -the-time/
Postby RonK » Mon Oct 03, 2016 4:48 pm
Krank wrote:The cassette is 30-12, so one less cog to consider and a total capacity of 32.
OK - I missed that your cassette starts with a 12. According to Campy a short cage will work with your setup.
After finding my derailleur I realised it has a carbon body and is worth a lot more, so sorry but offer withdrawn.
Krank
Postby Krank » Mon Oct 03, 2016 5:55 pm
hi ron.
PM sent.
krank
Postby RonK » Wed Oct 05, 2016 7:55 pm
OK, this is the correct method for sizing a Campy chain, and ensures the longest possible chain so the maximum derailleur capacity is available.
Feed the chain through both derailleurs and onto the smallest chain ring and sprocket. Take care to feed the chain under the two retainer tabs on the rear derailleur cage.
Then adjust the length so you have around 10mm (a fingertip) clearance between the chain and the rear derailleur cage and cut the chain accordingly.
Remember - if you are going to join the chain with a link you need each end to have an inner link. If you are going to use a pin then you need an inner and an outer link.
Watch the video. Note the red text at about 1:23.
Postby Duck! » Wed Oct 05, 2016 9:00 pm
^^ Absolutely THE BEST way to fit a chain to a bike - allows every possible cassette option within the spec of the groupset to be fitted.
Krank
Postby Krank » Thu Oct 06, 2016 4:34 am
Fantastic!
Thanks guys.
Great help as always :-)
krank
