DengFu FM098 Di2 Build
winstonw
Re: DengFu FM098 Di2 Build
Postby winstonw » Mon Nov 26, 2012 8:10 pm
Do you have to remove the seat post to charge the battery? Is the seat post alloy or carbon?
Crawf
Postby Crawf » Tue Nov 27, 2012 8:52 am
asmc wrote:ah cheers for the photos, the bike looks amazing :D I would want something similar with maybe a red stripe on the inside of the fork :P
so i got quoted on velobuild around $520 for a small frame, seem right to you? and another $500 for 38mm carbon clinchers
I think mine was just over $600 delivered from velobuild, that was some 4-5 mths ago, so yours is a good price.
Crawf
Postby Crawf » Tue Nov 27, 2012 8:53 am
winstonw wrote:Do you have to remove the seat post to charge the battery? Is the seat post alloy or carbon?
Yes, have to remove the SP to charge, it's all carbon.
15wilsonwu
Postby 15wilsonwu » Thu Feb 07, 2013 10:06 pm
Hi, did you use the Neco headset that came with the frame? If so, did it take you a bit of an effort to insert bottom bearing of the headset into the headtube? Casue for some odd reason, my bottom bearing requires a reasonable amount fo force to get it in when the top bearing just slides in.
Thanks,
Wilson.
2015 BMC TimeMachine TMR02
- Ultegra 6800
- Shimano RS31
Crawf
Postby Crawf » Thu Feb 07, 2013 11:09 pm
Yes used the neco. The race is always tight but the bearings go in with some pressure.
Check for overpaint on the head tube, possibly a very, very light sand needed to seat the bearing?
15wilsonwu
Postby 15wilsonwu » Thu Feb 07, 2013 11:13 pm
Crawf wrote:Yes used the neco. The race is always tight but the bearings go in with some pressure.
Oh I see, what signs are there to indicate it's a overpaint?
Its my first carbon frame, so.... forgive me, lol.
- Ultegra 6800
- Shimano RS31
Crawf
Postby Crawf » Fri Feb 08, 2013 9:26 am
Take a look were the bearings are supposed to sit and check for overspray, the Chinese frames are notorious for little things like this, it could mean the difference between being a pain and easily slotting in.
If you are having trouble getting the race on (the silver washer looking thing that goes on the base of the tapered fork tube) then just slice it and it will slide on.
15wilsonwu
Postby 15wilsonwu » Fri Feb 08, 2013 6:20 pm
Oh, ok. Cause im able to actually get it in but it couldnt move freely in there.
Thats fine right?
- Ultegra 6800
- Shimano RS31
Crawf
Postby Crawf » Fri Feb 08, 2013 7:55 pm
Yes snug is fine, as long as it's seated completely and evenly.
15wilsonwu
Postby 15wilsonwu » Fri Feb 08, 2013 8:24 pm
Oh ok. Thank you so much!
- Ultegra 6800
- Shimano RS31
