campagnolo 11 shifters....on shimano wheel.
boyracer
Postby boyracer » Wed Jan 31, 2018 11:15 pm
Hey all.
I am building a new rig and wish to run Campagnolo 11 shifters and derailluer with a shimano 11 cassette and freewheel. Cable not EPS.
Heard it is technically possible, anyone out there actually running it?
i haven't built /bought wheels yet but shimano wheels opens a lot of options and their cassettes are 'cheaper' with better ranges.
Yes, i have seen the Campagnolo centaur 11-32 offering.
Thinking 1 x .
I will run Campagnolo regardless , just not sure on which wheels/hubs now there is possible choice.
Thoughts?
2wheels_mond
Re: campagnolo 11 shifters....on shimano wheel.
Postby 2wheels_mond » Thu Feb 01, 2018 7:41 am
Yep, running Potenza here with an 11-32 Shimano 105 cassette as my wheels had a Shimano hub on them. Works fine.
KGB
Postby KGB » Thu Feb 01, 2018 3:13 pm
AFAIK, the main problem previously was that Campag ran progressive spacing from one end of the cassette to the other, while Shimano/SRAM had linear cog spacing. With 11s, I believe the progressive spacing is gone and the tolerances between different systems are much smaller, allowing cross-brand combinations.
eeksll
Postby eeksll » Mon Feb 05, 2018 11:44 pm
how picky are you with shifting and quietness?
it def works, I use a sram cassette on a shimano freehub on the trainer and a campag cassette on the road. I don't get any mis shifts etc. hard to give opinion on noise as its on the trainer.
I am running a 11 speed sram cassette on a 10 speed shimano hub with a few spacers behind the cassette, this is so that I dont have to get all fiddly with the gear cable adjustment when I swap wheels for the trainer. Does mean I only get 9 workable gears, but thats cause i spaced it outboard.
Many wheels also have the option of switching freehubs, probably a good reason to spec such a hub ?
regarding gearing all shimano 11 speed cassettes have a 11 tooth as the smallest gear with the following exceptions (I didn't want the 11 tooth as I'd never use it)
12-25 (25 is too small for my easiest gear)
14-28 (this is kinda interesting)
12-28 (dura ace only with dura ace price tag)
campag make a 11 speed 12-29 cassette (chorus its $150 not cheap but still cheaper than dura ace)
Stovepipe
Postby Stovepipe » Fri Aug 24, 2018 7:47 am
Not at all helpful but just as a side, I've got an 8spd veloce groupset. Super record cassette on a shamal, and a veloce cassette on velocities. Could never get either to shift right.
Put on my 8spd shimano zipps and now it shifts like clockwork without any adjustment required.
Comedian
Postby Comedian » Fri Aug 24, 2018 1:16 pm
ValleyForge
Postby ValleyForge » Sat Aug 25, 2018 10:23 pm
I've got a selection of DT Swiss wheels; changing the mount from Campy to Shimano is simple.
They are also incredibly reliable in my world. And smooth.
Ha ha ha! Cookies on dowels.
Postby Duck! » Mon Aug 27, 2018 7:03 pm
KGB wrote:AFAIK, the main problem previously was that Campag ran progressive spacing from one end of the cassette to the other, while Shimano/SRAM had linear cog spacing. With 11s, I believe the progressive spacing is gone and the tolerances between different systems are much smaller, allowing cross-brand combinations.
Campag still has unequal gear spacing with 11-sp, but due to the overall cassette width being virtually identical to Shimano/SRAM (Campag 10-sp. was considerably wider than S/S), the differences are a lot less apparent, so can be tuned out a lot better.
