The new and interesting touring gear thread...
- RonK
Re: The new and interesting gear thread...
Postby RonK » Thu Jul 14, 2016 11:42 am
Of particular interest I thought was the battery save mode which Garmin claim extends battery life up to 50 percent while still tracking ride detail.
If the claimed battery life of up to 15 hours can be extended by 50 percent that would be a boon to cycle tourists.
Postby avolve » Thu Jul 14, 2016 3:08 pm
I purchased a basic Edge 200(?) a few years back, and it barely gets used based on limited battery life (interface notwithstanding).
- il padrone
Postby il padrone » Thu Jul 14, 2016 5:08 pm
Never carried any more than one 2L fuel bottle with my Trangia, even on a 3 month tour into the desert. We had to carry up to 6-7 days of food, and fuel. We were cooking together so did carry a stove and fuel bottle each though, and being the outback, often enough we could ease the fuel consumption with a cooking fire - often enough we had a fire for evening light and warmth.Trevtassie wrote:About that in volume. Maybe a touch less in weight, but then you may need two bottles which tips the scales up again. Depends on your usage, light usage, making the odd cup of tea and re-hydrating a freeze dried something, alcohol is good option, especially if it's a shorter trip where the extra weight penalty of a whisperlite comes in to play. Long trips with heavy usage then Shellite or kero is the go from a weight and space point of view. I've even been known to have a hot shower using my camelback if I'm in the bush for over a week. Luxury.avolve wrote:I have never taken a Trangia myself. So they use a lot more (double?) fuel?Trevtassie wrote: Same as a Trangia I guess, what you gain on the swings (size, weight) you lose on the roundabout (needing to carry double the fuel compared to shellite or kero)
Postby Trevtassie » Thu Jul 14, 2016 8:07 pm
I had a chance to compare both, working as a walking track ranger in Tasmania. 9 day stints, carrying everything. Factoring in the starting temperature of the water is important too. If the water is at 8C it takes a shed load more fuel to get it boiling. It was lighter to carry a high kilojoule fuel after about 4 days. When your pack starts at 32kg you get gram conscious. Worst was when I had to carry in some hessian to line a composting toilet cage, 37kg. That sucked.il padrone wrote:Never carried any more than one 2L fuel bottle with my Trangia, even on a 3 month tour into the desert. We had to carry up to 6-7 days of food, and fuel. We were cooking together so did carry a stove and fuel bottle each though, and being the outback, often enough we could ease the fuel consumption with a cooking fire - often enough we had a fire for evening light and warmth.Trevtassie wrote:About that in volume. Maybe a touch less in weight, but then you may need two bottles which tips the scales up again. Depends on your usage, light usage, making the odd cup of tea and re-hydrating a freeze dried something, alcohol is good option, especially if it's a shorter trip where the extra weight penalty of a whisperlite comes in to play. Long trips with heavy usage then Shellite or kero is the go from a weight and space point of view. I've even been known to have a hot shower using my camelback if I'm in the bush for over a week. Luxury.avolve wrote:
- il padrone
Postby il padrone » Thu Jul 14, 2016 9:08 pm
On a bike the weight significance is much reduced when it is the bike frame that is carrying it. And anyway, on a bike tour alcohol has no weight
Postby Trevtassie » Thu Jul 14, 2016 11:20 pm
Volume also comes into it. I used 1.5L of shellite for 9 days. 3L of meths takes up a lot of room. Plus I'm an impatient bugger. I like my morning coffee fast!il padrone wrote:32 kgs?? Only just over half of what we were pcking on our bikes in Central Australia
- il padrone
Postby il padrone » Fri Jul 15, 2016 12:23 am
- rifraf
Postby rifraf » Sat Jul 16, 2016 7:12 pm
http://www.bikerumor.com/2016/05/30/roh ... ore-130323
Sorry if its been mentioned before. I tried the search engine without luck but am unsure if its working properly yet.
- RonK
Postby RonK » Sat Jul 23, 2016 3:43 pm
T-Ratchet Multi-Tool and Ti-Torque Travel Torque Extension
- Aushiker
Postby Aushiker » Tue Jul 26, 2016 11:47 pm
Aushiker.com
- RonK
Postby RonK » Thu Aug 04, 2016 12:02 pm
On my next NZ tour later this year I'll have to cross around 30 river fords. The Zem barefoot shoes I used last time were not a success, so I'm going to get a pair of these.
Postby ball bearing » Thu Aug 04, 2016 12:12 pm
I didn't see this post so I mentioned these items in the tools thread.RonK wrote:There is an interesting new tool made by Silca (of frame pump fame) on offer via Kickstarter. I had to have one.
The kickstarter buying options require careful reading. The $100 offer that includes the apron does not include the Ti Torque device! Not sure why they offer the T Ratchet without the really interesting torque wrench.
I caught my mistake and changed my pledge choice. I would have been very disappointed otherwise.
- Leaf T
Postby Leaf T » Wed Sep 14, 2016 5:20 pm
"Scientists invent super thin, flexible fabric that generates electricity from light and movement"
http://www.abc.net.au/news/2016-09-13/s ... ty/7837744
- baabaa
Postby baabaa » Thu Sep 15, 2016 8:51 am
http://www.spiegel.de/video/russisches- ... 96886.html
- Wingnut
Postby Wingnut » Sun Sep 25, 2016 10:22 pm
https://bedrocksandals.com/collections/ ... 0735722630
- Leaf T
Postby Leaf T » Mon Sep 26, 2016 9:27 am
- RonK
Postby RonK » Thu Sep 29, 2016 10:12 pm
- RonK
Postby RonK » Fri Sep 30, 2016 6:07 pm
Universal wireless gear shifter
Postby }SkOrPn--7 » Sat Oct 01, 2016 3:10 pm
Been giving this some thought I really like the fact you can micro tune it uses USB to charge and in my case get rid of long cables perfect for a recumbent. I'm slowing coming around to this idea and being universal is the clincher.RonK wrote:Holy cow, look at this. electronic shifting for the masses. I want...
Good find Ron
Ricky
- Wingnut
Postby Wingnut » Sun Oct 02, 2016 9:06 pm
Do you really need it for touring to bikepacking?
- RonK
Postby RonK » Sun Oct 02, 2016 9:47 pm
Being able to program in sequential shifting could work well for a recumbent.}SkOrPn--7 wrote:Been giving this some thought I really like the fact you can micro tune it uses USB to charge and in my case get rid of long cables perfect for a recumbent.
- Aushiker
Postby Aushiker » Sun Oct 02, 2016 10:24 pm
That was my first thought too. Just another electronic piece that needs charging, another piece of technology that could cause problems and maybe not be simply doubt with out on the road.Wingnut wrote:But why?
Yesterday I was riding into Coolgardie; chain needed lubing. Easily done on the side of the road. Now if this wireless shifting died on me, maybe a seriously bigger problem. Not much help out here.
Aushiker.com
- Aushiker
Postby Aushiker » Sun Oct 02, 2016 10:44 pm
Aushiker.com
Postby avolve » Mon Oct 03, 2016 2:56 pm
Planning on getting one as wellRonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
- il padrone
Postby il padrone » Mon Oct 03, 2016 10:44 pm
I remain convinced that the Mondial continues to be the best tyre Schwalbe has for the combination of dirt and tarmac. Good side knobs for rough stuff; much nicer broad centre pads for tarmac. Some may argue that the closer knobs will clog up in sticky mud, but most tyres will do this, and that scenario is thankfully rare in my experience of touring in the bush.Aushiker wrote:For those who like chasing the dirt on their touring bike, as I do, these new tyres from Schwalble might be of interest. The tyre in question is the Smart Sam Plus HS 476. Aimed at the e-bike market but I think with cross-over to touring.
