Thanks Ron. Kicked in a pledge.RonK wrote:Quick Caps - neat little QR locks...
Postby Aushiker » Tue Sep 30, 2014 7:21 pm
Postby Leaf T » Wed Oct 01, 2014 10:44 am
Postby TouringPhil » Wed Oct 01, 2014 10:57 am
Postby Aushiker » Wed Oct 01, 2014 11:02 am
I have them on my Surly Long Haul Trucker but these will do for the other two bikes to protect my dynamo hubs.Andy wrote:I like the excellent but pricey Pitlock skewers but these look good as well.
Postby il padrone » Wed Oct 01, 2014 2:14 pm
Postby zebee » Fri Oct 03, 2014 6:23 am
Postby outnabike » Fri Oct 03, 2014 8:46 am
Postby Wingnut » Fri Oct 03, 2014 9:25 am
Postby il padrone » Fri Oct 03, 2014 10:01 am
Postby outnabike » Fri Oct 03, 2014 11:41 am
Postby chillimagnum » Wed Oct 08, 2014 11:58 pm
Postby chillimagnum » Sat Oct 11, 2014 11:48 pm
Hi Andrew - any recent thoughts on this product? Looking for a cache battery for a dynamo charger. Cheers.Aushiker wrote:I now have one ex Japan. Very solid feel to it, charging my phone as I type. Seems to be quick with the charging. I got it from ebay seller, tokyofreaks23 for US$62.00.Aushiker wrote:The Anker Astro E5 15000 mAh looks like a reasonable compromise for me ... 10,500 to 12,000 mAh in reality which isn't to bad, two USB outputs at 1 amp and 2 amp and USB charging at 1.5 amp if going just for a battery.
Postby Aushiker » Mon Oct 13, 2014 12:24 am
Not really other than it works at home. I have yet to use it on the road.chillimagnum wrote:Hi Andrew - any recent thoughts on this product? Looking for a cache battery for a dynamo charger. Cheers.
Postby il padrone » Mon Oct 13, 2014 12:35 pm
Postby chillimagnum » Wed Oct 15, 2014 8:41 pm
Postby }SkOrPn--7 » Thu Oct 16, 2014 7:04 am
Thanks Pete I just ordered one to power my lights it seems to suit my needs.il padrone wrote:A similar battery with a really robust case, is the NewTrent PowerPak Ultra 14000 mAh battery. Two ouputs 1A & 2.1A, and 2A input. It has a waterproof, shockproof, and dustproof case.
Postby il padrone » Thu Oct 16, 2014 8:48 am
It will do that apparently. The only reservation that I have about it is the micro-USB charging port. On a previous cheapie battery this broke off on me when charging it from the bike with the battery in the handlebar bag - I'm guessing that movement stressed it and busted it. The one advantage of the Powermonkey Extreme is its full-size USP charging port - never looks like coming out or breaking.chillimagnum wrote:If it supports simultaneous charge in while using charge out it could be perfect.
Postby dalai47 » Thu Oct 16, 2014 9:59 am
Sounds great except weighs nearly 500g!il padrone wrote:A similar battery with a really robust case, is the NewTrent PowerPak Ultra 14000 mAh battery. Two ouputs 1A & 2.1A, and 2A input. It has a waterproof, shockproof, and dustproof case.
Postby il padrone » Thu Oct 16, 2014 12:45 pm
368g by my conversion. Seems comparable with the Powermonkey Extreme battery that weighs 242g, seeing as it is 50% greater capacity.dalai47 wrote:Sounds great except weighs nearly 500g!
Postby Tim » Thu Oct 16, 2014 1:16 pm
Where from?}SkOrPn--7 wrote:Thanks Pete I just ordered one to power my lights it seems to suit my needs.
Ricky
Postby dalai47 » Thu Oct 16, 2014 1:37 pm
My mistake. Converted the packaged weight...il padrone wrote:368g by my conversion. Seems comparable with the Powermonkey Extreme battery that weighs 242g, seeing as it is 50% greater capacity.dalai47 wrote:Sounds great except weighs nearly 500g!
Postby il padrone » Thu Oct 16, 2014 2:22 pm
Yes, I found that too... and every other site I could find was US with their similar US-only trade.Tim wrote:Where from?
Amazon won't deliver to Aus for me and I'm not sure I can trust Aliexpress.
Postby }SkOrPn--7 » Thu Oct 16, 2014 4:25 pm
Place Pete saidTim wrote:Where from?}SkOrPn--7 wrote:Thanks Pete I just ordered one to power my lights it seems to suit my needs.
Ricky
